Old 10-06-2013, 07:50 PM   #99
aCab
aCab's Avatar
Drives: FR-S & S2k
Any updates?
Bilstein Damptronic Prototypes | Other silly bits
aCab is offline   Reply With Quote
Old 10-18-2013, 01:17 PM   #100
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
I figured out AFR on it.
Been testing it for several weeks now. The only issue is that the refresh rate on the ScanGuage is pretty slow for a PID of this nature but it works perfectly fine so long as you are not tuning with it. It is a good way to keep an eye on it if something were to go wrong.
Also keep in mind the AFR on these vehicles is pretty innacurate below 11.2:1 with the factory wideband so anything you see below that should be taken with a grain of salt. This is perfectly fine but just something you need to be aware of. The gauge will really not see anything below 10.8:1 and should not be used for tuning but rather general monitoring. I have datalogged the ScanGauge with EcuTek for comparison and other than the speed of display its good to go. I will post the codes later. I just don't happen to have them on me at the moment.
My current display setup for reference is Boost, AFR, IAT, and Oil Temp. The only PID I really wish I could figure out is the KR (knock retard). Other than that the ScanGauge is a great option that is super cheap compared to competition for general monitoring.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 12-16-2013, 02:14 PM   #101
Stephens
Stephens's Avatar
Drives: 2013 Scion FR-S - MT - Asphalt
Old thread, but here's the AFR code I got to work.
CANSF Alt A/F General - TXD: 07DF0144 RXF: 04414544 RXD: 2808 MTH: 05B900800000
Like AZFA20 said response is Meh and below 11.2ish is iffy. Also, the gauge won't read accurately until you've given the sensor time to heat up.
To succeed in life, one must go through it with a tenacious fiery spirit of twerk.
Stephens is offline   Reply With Quote
Old 05-15-2014, 03:30 AM   #102
Sharki
Drives: Toyota GT86
I bump this topic ^^
The ScanGauge E cannot be programmable for adding the Oil Temperature right ?
Also, the temperature can be change to F° in C° ?
Thanks
Sharki is offline   Reply With Quote
Old 05-15-2014, 03:32 AM   #103
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Yep you cannot put codes in for the e gauge. My temps are all in Celsius. Can't remember but i probably changed it in settings somewhere
86•BRZ is offline   Reply With Quote
Old 05-15-2014, 09:57 AM   #104
Sharki
Drives: Toyota GT86
Ok, and the ScanGauge E cannot read the oil temp out the box i suppose ?
We need the ScanGauge II to do that ?
Old 05-25-2014, 12:20 AM   #105
TmP
TmP's Avatar
Drives: A bunch of 'em...
This is awesome!
What a deal this gauge is for the money. Unreal.
I saw it before, but can't find it now.
Someone found a way to use the SG2 as a wide band?
If you know what I'm referring to, please guide me in the right direction.
TmP is offline   Reply With Quote
Old 06-05-2014, 04:06 PM   #106
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
That code is not working. This is the correct air fuel ratio (AFR) xgauge code for our cars I confirmed worked on multiple Scangauges on our cars:
TXD: 07DF0134
RXF: 044145340000
RDX: 2808
MTH: 05B900800000
stockysnail is offline   Reply With Quote
Old 06-05-2014, 05:31 PM   #107
TmP
TmP's Avatar
Man, I couldn't get the AFR to work to save my life.
Gotta try this.
Old 08-23-2014, 10:54 AM   #108
TmP
TmP's Avatar
OK, I need help.
Initially the oil temp worked great.
Then, I tried the AFR and ever since then the gauge has been fucked.
I for the life of me can't get the oil temp to work any more.
How can I reset the xgauge list to start over? Is there no way to undo the changes and go back to factory?
The reset option in the menue just changes shit like the color and engine displacement... :/
Old 08-26-2014, 03:33 AM   #109
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Remove the AF code. From memory you can erase a new PID by blanking the first character of one of the entry line. It's in the manual.
Old 08-26-2014, 06:51 PM   #110
TmP
TmP's Avatar
Thanks, I'll try that.
Old 01-09-2015, 06:00 PM   #111
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Has anyone been able to get the seat belt chime to turn off? I don't know how to send that command.
post_break is offline   Reply With Quote
Old 01-10-2015, 08:54 PM   #112
sam69
Drives: GT 86
Any one bought or used one of these .. http://www.ebay.com.au/itm/TurboGaug...item5b0a0e2faa .. and if so are they as good as a Scangauge 2 and do they have the ability to read oil temps etc like the Scan 2
sam69 is offline   Reply With Quote
Search this Thread:
Advanced Search
FT-86 low temp THERMOSTAT ft86-UAE Engine, Exhaust, Transmission 52 08-30-2016 03:46 PM
A/C Oil/Water temp gauge Exhaust Scion FR-S / Toyota 86 GT86 General Forum 16 02-07-2013 01:19 PM
Engine oil temp now available in Torque App Yruyur Engine, Exhaust, Transmission 8 02-03-2013 10:52 PM
exterior temp. gauge off? Rayme CANADA 8 01-23-2013 09:06 PM
Simple Oil Temp. Gauge Sportsguy83 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2013 08:25 PM
