#71 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
The Scangauge is cheaper on Autozone.com with their coupon code they list on their site so instead of being $160 it's $127.99, so I bought one.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
| The Following 2 Users Say Thank You to stockysnail For This Useful Post: | heeltoe86 (04-05-2013), theredtape (03-25-2013) |
#72 | |
Drives: civic,vfr,BRZ
![]() Edit: And free shipping !
Because Racecar.
#73 |
Drives: '13 GBS Subaru BRZ
For those that have expressed interest in my 3D printed mount. I'm sorry but I'm not going to get into the business of selling them. However I have gone ahead and uploaded the design to a print on demand service where you can have it made and shipped to you. You can also buy the design there for a small fee and print it yourself if you happen to have access to a 3D printer.
http://cubify.com/store/creation.asp...nce=8FYGO8GFX2 I make no promises as to the quality of their parts, and offer no support, but if someone does try it please let me know how it turns out. If it works well I may submit other designs there.
| The Following User Says Thank You to neutron256 For This Useful Post: | TIE Pilot (03-26-2013) |
#74 | |
Because Racecar.
#75 |
Because Racecar.
#76 |
Drives: Firestorm FR-S 6MT
It doesn't have a temp sensor for MT. AT, on the other hand, has a temp sensor, but I don't if it is a dumb sensor or not
2013 Scion Firestorm FR-S MT
#77 | |
Hey everyone , Here is my mount set up for my scan gage. It's a combo between a 3d printed bracket , bent sheet metal, and a coat of plasti dip. I only wanted to use it for at a glance info between runs so I made a point of putting it out of my view while driving. It mounts using to bent sheet metal pieces trapped between the dash trim piece. Let me know what you guys think. I honestly probably could have gotten away with velcoing it right to the dash but I really hate the residue from the Velcro and this way it can't fall down on hot summer days.
Because Racecar.
#78 |
Drives: 2013 SWP BRZ
great info, thanks!
#79 | |
I followed all of the steps, and cannot get the Oil Temp to work? It is just blank. I went through and made sure I had all 4 codes entered correctly, and then double checked again. Firmware is version 4.12 Any help would be appreciated. Thanks! |
#80 |
Ok, update, for some reason the next time I started up the car the OIL temp showed?? Weird.
I did have one question though; what kind of Relative throttle % are you all seeing? The most I will see is 69.0% at WOT. Is that normal? |
#81 |
Drives: 2013 Firestorm FR-S
I've gotten oil temp working but I can't get air fuel working correctly. Can someone confirm that we can read the wideband?
2013 Firestorm FR-S, MTX, build date 1/13.
#82 | |
Drives: 86 GT
Got one just to see oil temps on the track and have a digital speedo so everything else is a bonus. Not sure what I did with the seat belt one, didn't get the right code show up but no chimes so problem solved either way.
Is it possible to program in distance to empty as a guage? I haven't investigated the trip functions as I want to keep it on the guage screen all the time. |
#83 |
Drives: FR-S ultramarine
I am looking at oil temp, water temp< ya the frs has one of those but no actual numbers. also, anybody with an auto get a transmission temp ????? That is my biggest concern as I want to check on getting a tranny cooler added if possible. I know when I am pounding this the auto is taking a beating.
#84 | ||
You can use the Add-a-Gauge function to add the distance to empty as a gauge.
| The Following User Says Thank You to pkny For This Useful Post: | dave- (06-11-2013) |
| FT-86 low temp THERMOSTAT | ft86-UAE | Engine, Exhaust, Transmission | 52 | 08-30-2016 03:46 PM |
| A/C Oil/Water temp gauge | Exhaust | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 02-07-2013 01:19 PM |
| Engine oil temp now available in Torque App | Yruyur | Engine, Exhaust, Transmission | 8 | 02-03-2013 10:52 PM |
| exterior temp. gauge off? | Rayme | CANADA | 8 | 01-23-2013 09:06 PM |
| Simple Oil Temp. Gauge | Sportsguy83 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-19-2013 08:25 PM |
