DIY (Do-It-Yourself) Guides For all DIYs. |
12-02-2021, 10:47 AM | #15 |
Drives: 2017 BRZ PP
Not a platform specific application of the theory at hand but a good write up none the less.
https://www.motortrend.com/how-to/pinion-angle-change/ It’ll will be interesting to see the measured pinion angles of transmission and rear carrier. I’m due for an oil change soon and will see what mine are. Have an axle exchange alum driveshaft along with all of the whiteline transmission and rear carrier inserts. |
12-02-2021, 10:39 PM | #16 |
Señor Member
I bought my carbon drive shaft used. At first I had horrible vibrations. It took me a few tries but eventually I found a driveshaft shop that both shimmed the uni joints to be centered and added balance weights and its been great ever since. I also have STi engine and gearbox mounts as well as a light flywheel so should be able to feel any new vibrations.
1974 TA22 Celica
2013 86 GT |
12-23-2021, 04:07 PM | #17 |
Drives: 2017 BRZ PP
So I just checked both pinion angles (rear diff side and trans side). Rear diff showed a +2 degrees of pinion angle while the trans side was at -5 degrees of pinion angle. This would put the trans side out of the ideal range of -3 degrees (assuming that ideal angles would be +/- 3 degrees at opposing ends.)
I have an axle exchange alum driveshaft, Perrin shifter bushing, and whiteline trans insert. Ideally I would be able to bring the trans side closer to -2degrees to match my opposing rear diff +2 however it looks like clearances are already very tight on the transmission side with the diameter of the driveshaft and it almost touching the perrin shifter mount. Any thoughts on potential ways to bring the trans side more in line? Has anyone else take taken pinion angles? |
The Following User Says Thank You to almostquick For This Useful Post: | gpvecchi (12-23-2021) |
12-23-2021, 05:06 PM | #18 |
The total ideal difference should be less than 1 degreee, and every side should be less than 3 degree. Your diff is ok, you have to correct the transmission angle.
You have to raise the gearbox, right? You should put a shim between the transmission support and its plate. Keep in mind that rising the gearbox will change the diff angle too. Last edited by gpvecchi; 12-24-2021 at 12:55 AM. |
12-29-2021, 11:59 AM | #19 | |
Drives: 2017 BRZ PP
Yes, ideally I would raise the transmission to be closer to the opposing +2 degrees on the diff end. The issue arises with the fact that I (and I assume anyone else with a alum 1-piece driveshaft) do not have the clearance on the trans side to shim the trans to raise it and get it to -2/-3 degrees, as the driveshaft is almost coming in contact with the rear shifter mount bushing. As a shear test to see if bringing the two inline will indeed fix the vibration problems we are experiencing, I might try to shim the diff to +5 degrees to be inline with the trans. This is not optimal but at least gets to the answer as to whether pinion angle is the culprit for the driveline vibration many experience. |
01-02-2022, 02:35 AM | #20 | |
Drives: 2015 FR-S
I would say using the face of "A" where U-joint bolts to would be the most accurate but that requires removing the driveshaft so the face is exposed. |
01-02-2022, 09:18 AM | #21 |
Tha "A" place. I saw somebody putting a metal ruler "between" the diff face and the driveshaft and then use it as a flat surface.
The Following User Says Thank You to gpvecchi For This Useful Post: | FrickingReallySlow (01-02-2022) |
01-02-2022, 07:39 PM | #22 |
Drives: 2017 BRZ PP
Location A. I had just enough surface area even with the driveshaft connected to put an angle finder on the face surface.
01-25-2022, 08:07 PM | #23 |
Drives: 2015 FR-S
Measured my angles, 3.4 in the front and about 3.1 at the diff. One way I think this can be reduced is with the STI engine mounts (perhaps others too). They're used by ppl that has ACE350 headers to raise the engine slightly to clear the big ACE overpipe from subframe. Raising the engine and keeping the pivot point of the trans mount the same would reduce both angles slightly since the tail bushing would now be pointed slightly downward and also start lower in height (reducing the height difference between it and the diff). I guess here a softer trans mount that is more compressible could help (at least statically) since the pivot point would be lowered slightly
01-26-2022, 03:45 AM | #24 |
I have the STi supports and bushings. They don't raise the position, but they will flex less. The only way to change the angles are shims and spacers.
Did you check the angle of your driveshaft too? |
01-26-2022, 12:01 PM | #25 | |
Drives: 2015 FR-S
Did you pull the trigger on your Carbon shaft purchase yet? |
01-27-2022, 02:59 AM | #26 |
No, I quitted the idea as I didn't want to spend quite a lot of money to have issues.
Your angles are not that bad, you could try to lower the gearbox support with washers and longer bolts. You need around 1.5 degrees, you shouldn't need big spacers. |
The Following User Says Thank You to gpvecchi For This Useful Post: | FrickingReallySlow (02-03-2022) |
02-05-2022, 03:49 AM | #27 | |
Drives: Toyota 86
02-07-2022, 05:07 PM | #28 |
Señor Member
Indrotech in Hallam. They didn't have the means to attach the balance weights to the shaft so they taped them in place and I had to then glue them on. I got Loctite involved and used their recommendation which worked perfectly. I can't remember what it all cost me though I am sorry.
1974 TA22 Celica
2013 86 GT |
Similar Threads | ||||
1 Piece aluminum driveshaft | Phothiraj | Engine, Exhaust, Transmission | 60 | 10-03-2016 05:53 PM |
Does anyone track their car with a 1 piece DSS driveshaft? | mhiscott | Tracking / Autocross / HPDE / Drifting | 3 | 08-10-2016 12:02 AM |
Aluminum 1-piece Driveshaft | Cjs_ | Engine, Exhaust, Transmission | 17 | 03-25-2015 04:45 PM |
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft | Evasive Motorsports | Engine, Exhaust, Transmission | 1 | 09-24-2013 02:27 PM |
