DIY (Do-It-Yourself) Guides For all DIYs. |
11-17-2020, 04:07 AM | #99 |
Wheels for Brains
If you want to avoid the trouble of removing the tube from the firewall, you can use a a 5/8" (16mm) ID Vacuum/Cooling Bypass Cap on the plastic sound generator "L" piece.
Admittedly, the fit is a little tight out of the box. The ID is probably a little less than 5/8" in actuality (probably closer to 15.4mm). I had one on there for a couple of years, but the stress was causing the rubber to crack. Additionally, it was a little bit of a fight to remove it. Just replaced it recently with another (luckily two are in the pack of assorted sizes from O'Reilley's for ~$5 when I bought them years ago [Dorman 02253]) and used a Dremmel to enlarge the ID by a tiny bit (~0.02" or 0.5mm). Combined with some rubber grease, it went on nicely. ----- Alternatively, you can try to put a plug there. I measured the opening of the plastic L to be approximately 11.3mm in diameter (or ~7/16"). I haven't verified or tried it myself, but it may give you a reference to start with if you prefer that method,. |
08-09-2022, 09:17 AM | #100 |
Drives: 2019 86 TRD SE
Probably one of the easiest, cheapest, and BEST mods I have ever done. Wish I had done it years ago on my FRS. Just did it on my 2019 TRD SE.
09-29-2022, 12:45 AM | #101 |
Drives: Scion FR-S Monogram (Whiteout)
The sound in the cabin is SOOO much quieter and it’s much much less drony. Really recommended mod! Why? Save your ears!
09-30-2022, 10:58 AM | #102 |
Drives: 2017 BRZ PP, 2004 WRX
Technically for street class autocross, I can't change the inlet to the Perrin tube or even simply remove and block off the sound tube. I did however add a stopper at the firewall in the passenger side footwell to keep the piped in sound at bay for now.
I envy you people not having to adhere to strict rulesets.
09-30-2022, 11:02 AM | #103 |
Drives: Subaru BRZ
I had a CAI installed, left the plumbing for the noise thing in place but had the pipe bunged up.. I just like the plumbing in place as it detracts from the other gubbins in the engine bay..
Similar Threads | ||||
Sound Generator to keep or not to keep? | FRS86edition#3 | Scion FR-S / Toyota 86 GT86 General Forum | 73 | 11-24-2013 01:26 AM |
Sound generator delete for $1.06 | PineappleFriedRice | Engine, Exhaust, Transmission | 13 | 11-10-2013 12:28 PM |
Sound Generator Tube Delete | Anthony | Engine, Exhaust, Transmission | 8 | 09-01-2013 04:25 AM |
WTB: OEM snorkle (not sound generator) | Laika | Engine, Exhaust, Bolt-Ons | 2 | 11-08-2012 11:31 AM |
