06-30-2022, 06:13 PM | #169 |
Drives: 2015 Subaru BRZ Limited DGM
Reinstalled the old module. I am successfully back to square one. Which is good because I have an event this weekend. Pedal dance still not working, but 5sec hold works, so we'll be ok.
Again, any help or suggestions would be great. |
07-02-2022, 04:34 PM | #170 |
Drives: '13 BRZ 6MT WRB
Do you have an ODBII reader that can pull / reset codes from the ABS module?
IIRC, when I upgraded mine ABS module there were codes already in the ABS module and resetting them did the trick. See comment 131. |
01-03-2023, 03:52 PM | #171 |
Drives: 2013 BRZ sprintex SC
Hi,
I have a sept 2012 built car, used *60 pn unit, repined the vsc connector from 17 and 32 to 8 and 9. And i have cel plus abs and steering wheel error, the fault code is speed sensor and i have no odometer now and car reva to 4k. Can someone help? The unit ia from 2019 \2020 manual brz. Pls.help. |
01-03-2023, 04:58 PM | #172 | |
Don't understand what os the issue. The unit is from 2019 brz but it acts like i didnt repin the connector. The white speed sensor pin is from the vsc to the ecu? As an input to the ecu? Last edited by amirnew; 01-03-2023 at 10:59 PM. |
03-14-2023, 01:06 PM | #173 |
Drives: None
Anyone tried a gen 2 unit on a gen 1 yet?
03-14-2023, 01:10 PM | #174 |
Drives: 13 BRZ, 16 FiST, 05 WRX
03-14-2023, 01:16 PM | #175 |
Drives: None
No idea, but it'd be nice if the ABS was less intrusive since it'd have been calibrated for a PS4 rather than a Prius tire.
The Following User Says Thank You to RedReplicant For This Useful Post: | bhmax (03-14-2023) |
03-14-2023, 01:27 PM | #176 |
Drives: 22 BRZ limited
Hate to break it to you, but the second gen still comes with "Prius tires" and the same unit is used on the premium and limited.
03-14-2023, 01:54 PM | #177 |
Drives: None
That sucks. Same software calibration id?
03-14-2023, 02:05 PM | #178 |
Probably. I'm not sure if the ABS CAL ID is listed on the outside, or pulled by interfacing to the car. The Subaru parts diagram lists the same ABS unit for both trims.
03-14-2023, 02:09 PM | #179 | |
Drives: None
I was just hoping we'd be in a similar situation to MK60/MK60E1/MK60E5/MK100 where you can code the unit to different parameters that intervene less.
03-14-2023, 02:51 PM | #180 |
Drives: 2018 BRZ
When I test drove a '22 BRZ I found the stability and traction controls to be less intrusive when fully on - 1st to 2nd high RPM upshift chirped the wheels (would bog down my '18) and it allowed a nice amount of rear slip coming out of a stop sign and turning left (would feel brake intervention in my '18). I only drove with stability and traction fully on, so not sure if there is a different tuning in Track Mode.
But if your goal is just to have a "fully off" mode the 17+ is good enough, AFAIU. |
The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | bhmax (03-20-2023) |
03-14-2023, 04:41 PM | #181 |
I have the STi unit, and it's calibrated different than my previous 2019 version. ABS is less intrusive, ESP the same. My opinion it's calibrated for 18 inches rims, so I think the GR86 has a similar behaviour.
I'm tempted to try the JDM G type (same as the JDM 86 GR). this looks more track oriented than the others. |
The Following 2 Users Say Thank You to gpvecchi For This Useful Post: | RedReplicant (03-14-2023), Trap63 (03-15-2023) |
03-14-2023, 05:39 PM | #182 | |
Drives: None
I am assuming Brembo calibration is less intrusive too.
Similar Threads | ||||
Review of "Track Mode" on the MY17+ cars | trippinbillies40 | Tracking / Autocross / HPDE / Drifting | 85 | 02-22-2021 09:27 PM |
FS: Nameless muffled track pipe 2013-2016 | Dave-ROR | Engine, Exhaust, Bolt-Ons | 4 | 05-20-2020 11:27 PM |
Track mode vs. VSC sport | alex87f | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 10-30-2018 10:47 PM |
2017 Track mode on older model | Bobster | Engine, Exhaust, Transmission | 17 | 12-03-2017 10:34 PM |
