Tracking / Autocross / HPDE / Drifting What these cars were built for! |
05-09-2021, 03:52 PM | #1 |
Drives: FR-S Turbo
Anyone mounted up 255/40R17 Nankang CR1s?
I've heard these fit VERY wide - like 275/285ish.
Curious what people's experiences have been with our platform? I have run 255/40R17 AR1s without any rubbing or issues, but they only ran a touch oversize I believe. Also curious on feedback from anyone who has driven both these and A052's on track. A052s have pretty soft sidewalls - do the CR1s share this trait? |
The Following User Says Thank You to Turbo For This Useful Post: | smg1138 (05-09-2021) |
05-09-2021, 11:20 PM | #2 |
Drives: 2017 BRZ series.yellow
Hoping to mount some up as soon as they arrive.
I'm not sure about the 255's, but a buddy running STS with 225's, his 225 Yoks are wider then his 225 CR-1s. |
05-10-2021, 02:40 PM | #3 |
Drives: 2013 Raven FR-S
I'm really interested to see how fast they are compared to the A052's. Tread design on them is very similar.
05-10-2021, 04:56 PM | #4 |
Drives: '23 BRZ
https://philstireservice.com/wp-cont...CR-1-Specs.pdf
According to this, 255/40-17 have 259mm section width on 9" wheel. I'm running 245/40-17 on 9" wheels, but to me they look wider than the 249mm shown here, I would have guessed 255 minimum, so... Ran these at New Hampshire Motor Speedway (chicane/chicane) yesterday, did a best lap of 1:19.26, unfortunately not in my time trial... I ran 1:20.20 time trial same car on 245/40-17 RE71R a couple of years ago. |
05-11-2021, 08:26 AM | #5 |
Also, my 255 CR1s are arriving on Monday. I'll let you know when I get them mounted.
The Following User Says Thank You to Breezio For This Useful Post: | Turbo (05-13-2021) |
05-11-2021, 08:51 AM | #6 |
Drives: '23 BRZ
Looking again, 249mm for section width seems about right, the sidewall is a lot more square which makes them look wide. 245/40-17 has 9.8" section width, 9.6" treadwidth, vs. A052 with 9.9" section width, 8.9" tread width.
05-11-2021, 11:00 AM | #7 |
Just saw a YT video on this and they run wide. I'd you want to fit a 255 you should get a 9.5 inch wheel. 245 will fit nicely on a 9 inch wide rim
2013 Series 10 FRS #553
05-11-2021, 07:58 PM | #8 |
Moutain Runner
I have 255/40/r17 CR1 on my 17x9 Rays 57CR. what exactly are you looking for?
The Following 5 Users Say Thank You to Chuckls For This Useful Post: | Breezio (05-12-2021), SCFD (05-13-2021), smg1138 (05-12-2021), strat61caster (05-12-2021), Turbo (05-13-2021) |
05-12-2021, 05:18 PM | #9 |
Wait, the tread width is 9.6"? That seems really wide for a 245/40-17
05-12-2021, 05:47 PM | #10 | |
Drives: Crapcan
My 245 RT660's just showed up and they measure about the same.
05-13-2021, 01:03 AM | #11 | |
Drives: FR-S Turbo
I'm concerned about rubbing issues, mainly. I was fine with 255/40 AR1s and RS4s - just concerned about the CR1s, as I heard rumors the 255's runs especially wide. The 255 AR1s are sized closed to a traditional 265, for instance. I'm also curious about feedback on sidewall stiffness compared to A052s, which are a bit soft. |
05-13-2021, 01:43 AM | #12 |
Drives: Track preped NA FRS
Dont know about CR1s, but 255 Falken Rt660 are wider than 275 Maxxis RC1.
The Following User Says Thank You to Icecreamtruk For This Useful Post: | bslate3 (05-14-2021) |
05-13-2021, 08:41 AM | #13 | |
Drives: '23 BRZ
But enough more grip that I got fuel starvation coming out of turn 6 (180 degree banked left aka "the bowl) at NHMS at 7/8 tank, which has never happened before. Palpably more grip vs RE71R I used to run, or even 8-cycle Hoosiers I ran there last Fall |
The Following 3 Users Say Thank You to ZDan For This Useful Post: |
05-13-2021, 03:07 PM | #14 |
Drives: FR-S Turbo
Similar Threads | ||||
Nankang AR1 | TommyW | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 12-17-2019 12:51 PM |
Nankang NS-2R 120TW | botbs | Tracking / Autocross / HPDE / Drifting | 1 | 04-13-2018 05:01 PM |
FS: 275/35/18 Nankang NS-20 | macaulay7 | Canada Classifieds | 5 | 06-30-2017 12:28 AM |
Nankang tires | FRSure | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 10-20-2016 08:13 PM |
Hankook Ventus Evo V12 K110 - 245/40R17 and 255/40R17 $40 rebate, wholesale | Gruppe-s | Wheels and Tires | 7 | 10-21-2014 02:11 PM |
