Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
02-05-2013, 08:25 PM | #29 |
Senior Addict
Drives: 86 GT
Slight difference in drop, the ProKit gives 25mm drop whereas the Sti items are 15mm. But yea the eibachs are much cheaper.
The Following User Says Thank You to Fizz For This Useful Post: | DNAPoPo (02-05-2013) |
02-08-2013, 06:47 AM | #30 |
Drives: 86 GTS
02-08-2013, 11:19 AM | #31 |
Wannabe JDM Type S
Drives: 2013 BRZ Limited
no issues. What's captive w/o compression mean?
My Wannabe JDM Type S build: http://www.ft86club.com/forums/showthread.php?t=24702
02-08-2013, 05:54 PM | #32 |
Drives: 86 GTS
Spring is trapped in the top of the shock when it's hanging free (isn't loose on the shock body before you fit it to the car.)
02-08-2013, 06:33 PM | #33 |
Wannabe JDM Type S
Yes c wo c
The Following User Says Thank You to ZC6BRZ For This Useful Post: | Panman (02-08-2013) |
02-08-2013, 07:29 PM | #34 |
Shift Down
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
Im buying your RCE Yellows soon for my FRS i find them to be the best springs out right now. and they wont mess up the factory struts. i read something you guys posted anything more than 20MM can cause damage to the factory struts so i like the 20mm drop and the 250LBS spring rates on them plus i like RCE A lot keep up the good work guys!
The Following User Says Thank You to DanoFA20 For This Useful Post: | Racecomp Engineering (05-03-2013) |
02-08-2013, 10:05 PM | #35 |
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
That looks great! Just what I'm looking for too! I'm not trying to slam my car but do want to get a little bit of a drop. Anything over an inch is just too much.
02-11-2013, 07:04 PM | #36 |
Drives: 2012 F25 X3 xDrive35i M-Sport
Where did you buy the spring?
02-13-2013, 11:13 AM | #37 |
Mine are arriving tomorrow from japanparts.com . I believe this is the only source of them in the US for now.
02-17-2013, 01:21 PM | #38 |
Drives: GT86
Does anyone know the rates of these springs? (particularly the higher rate)
03-04-2013, 12:08 AM | #39 |
Drives: 86 GTS
Installed these in my 86 - Definitely a good upgrade. Certainly rotates quicker, ride is not compromised and drop is noticeable but not excessive as I have the factory Aero kit (Australia) and cant drop too much.
The Following User Says Thank You to Panman For This Useful Post: | Jaylyons1 (03-23-2013) |
05-03-2013, 03:30 PM | #40 |
Would those of you with the STI springs kindly share how much they affected your wheel alignment?
Did you install any other suspension parts or just the springs? |
05-03-2013, 11:10 PM | #41 |
Drives: 86 GTS
I had mine aligned when I had them fitted - back to factory specs which it did with no problems. No other parts in mine except the springs at this point.
The Following User Says Thank You to Panman For This Useful Post: | BRZebra (05-27-2013) |
05-04-2013, 08:55 AM | #42 |
Drives: Toyota 86 Turbo, Lexus NX300H
front : no camber change
rear : -1.5~1.8. I installed Pink springs with STI flexible tower bar. (& front camber bolt too) definitely better handling with good ride quality. |
The Following User Says Thank You to Yobiwan For This Useful Post: | BRZebra (05-27-2013) |
Similar Threads | ||||
OEM BRZ springs? | jm1681 | Brakes, Suspension, Chassis | 1 | 11-03-2012 08:14 AM |
Anyone use the JDM/Sti springs? | G4mb17 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-25-2012 08:10 PM |
HELP:Q about springs | Obja | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 10-08-2012 02:12 PM |
trd springs or no? | FT86R | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 09-30-2012 03:52 PM |
STi Springs | illmatic | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 08-14-2012 01:19 PM |
