Tracking / Autocross / HPDE / Drifting What these cars were built for! |
07-02-2015, 02:34 PM | #15 |
It might be interesting to look at 1 particularly hard corner in isolation with non-averaged values across 5 or so laps too.
- Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | strat61caster (07-02-2015) |
07-02-2015, 03:36 PM | #16 |
Drives: '13 FRS - STX
Sheesh I guess I can't count either so I shouldn't be so harsh.
I dig the responses and look forward to hearing more thoughts from others. |
07-02-2015, 03:40 PM | #17 |
Drives: GBS Limited 6MT
As for the braking Gs vs turning Gs, could this be blamed on ABS? The tires require some slip angle to generate that maximum cornering g force. Likewise, I'd imagine they would require some slip before producing maximum braking force, but perhaps ABS kicks in before enough slip is generated to produce the maximum braking force? It'd be like measuring maximum cornering force but leaving stability control on.
Just a thought, since in my head weight transfer can't account for it. Also, do you mind posting your raw data? I'd like to take a look. |
07-02-2015, 04:08 PM | #18 | |
Drives: 2015 BRZ
As far as sharing raw data, I'm sorry, that's against company policy. I don't mind sharing plots of certain things for the sake of discussion, but considering we're collecting all this data for the purpose of developing parts for sale, we need to treat it as intellectual property. I really hate to say no, but it's above my head. Jake |
07-02-2015, 04:37 PM | #19 |
You'll probably be getting more weight transfer under braking than cornering since the sway bars will adding to roll resistance but not doing anything for brake dive.
It's probably a mix of that, slip "angles", and tire design (different tread patterns are better at different directional loads).
07-02-2015, 08:10 PM | #20 | |
Fair enough. I'll just ask you to do the work for me. Could you show that same plot, with those exact same braking events, but with deceleration on the y-axis (as opposed to the "gain")? And don't average it, take the highest value per braking event. My thought process is this: A small amount of brake fade that simply requires more pedal pressure to achieve the same braking force will not necessarily make you slower. Yes, you will show a lower "gain", but if you are braking at the same rate (deceleration is the same), then your lap time should be the same. If you are actually getting brake fade to the point that the deceleration you are capable of is diminished, you will see that in the plot I proposed above. |
The Following User Says Thank You to u/Josh For This Useful Post: | strat61caster (07-02-2015) |
07-02-2015, 08:19 PM | #21 |
I love educational threads like this!
07-03-2015, 09:08 AM | #22 | |
Drives: 2015 BRZ
A linear trendline does show a decrease across the session, but I wouldn't consider it significant enough to be an indicator. Perhaps if you folded back in peak pressure you MIGHT see something, but I'd bet there's too much noise in the pressure signal. I think until I get temperature data in here, it's going to be tough to quantitatively identify fade. That's definitely the goal, though. |
07-03-2015, 11:34 AM | #23 | |
Two things from this. First, It's interesting that the max braking force doesn't align at all with the max gain (although in hindsight maybe this should have been obvious). And second, if you were to plot simply the highest braking force per lap, you would see it increase for the first three laps, and then decrease for all of the rest. I think maybe that is evidence of your fade. Cool stuff. |
The Following User Says Thank You to u/Josh For This Useful Post: | GSpeed (07-04-2015) |
07-03-2015, 12:38 PM | #24 | |
Drives: 2013 GBS BRZ Limited
I use the innovate TC-4 (sitting here with one in my hand) and it reads 4X thermocouples. A roll of TC wire would be relatively cheap to run one to each caliper. Have you at least tried the temp sensitive caliper & rotor paint that indicates max temps? They have stickers too. It doesnt give you realtime data, but it will warn you if you have overheated or are getting close. If you get the caliper temps above some critical temperature (400 F rings a bell but dont quote me) , you ruin the seals and the pads wont retract. Then they drag and overheat more frequently (thermal runaway). Are these runs with ABS completely disabled? My experience of max braking of .8 Gs is in a car without ABS. It would be interesting to see one of your plots with ABS and one without. |
The Following User Says Thank You to stugray For This Useful Post: | GSpeed (07-04-2015) |
07-04-2015, 07:40 AM | #25 | ||
Drives: 2015 BRZ
ABS wasn't disabled, no. Just the "pedal dance." |
07-06-2015, 12:42 AM | #26 |
Similar Threads | ||||
How to identify different types of brake fade? | jonnyozero3 | Tracking / Autocross / HPDE / Drifting | 8 | 01-14-2019 08:52 PM |
BRZ MPG Data Analysis | housecat | BRZ First-Gen (2012+) -- General Topics | 30 | 02-14-2016 08:32 PM |
system not recognizing my Sansa Fuze MP3 | pantdino | Electronics | Audio | NAV | Infotainment | 2 | 07-27-2014 04:16 PM |
Brake Fade | RAWR BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 09-27-2012 03:56 PM |
Odd brake pedal feel, fade? | yomny | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 09-11-2012 12:29 PM |
