Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
10-19-2022, 10:48 AM | #29 |
Drives: FR-S,GTI
Why is everyone here talking about voltage? The problem is current. A car battery can have 13 volts but hardly any current. That's why batteries are load tested not voltage tested. In a firehose analogy voltage is the water pressure. Current is the water volume.
The engine takes a lot of volume to turn over where lights take very little. Ohm's law: E=I x R. Voltage is E, Cuurent is I and Resistance is R. |
10-19-2022, 11:16 AM | #30 | |
10-19-2022, 11:26 AM | #31 | |
Drives: Crapcan
Going back to the OP's first post, it doesn't sound like the battery to me. It sounds like something like a clutch switch as soundman98 said. Doesn't mean you shouldn't check the battery and if you are going to do that you should load test it which means the battery should be fully charged. So while you put a charger on the battery, that isn't going to stop you from checking other things, especially if the issue is indicating something else. By checking the starter terminal like RZNT4R said you are isolating where the issue is(which a test light is good for). Light comes on-weak battery, fuse, or bad starter/starter solenoid. No light- it's on the switching side. Clutch switch, starter relay.
10-19-2022, 11:54 AM | #32 | |
Drives: FR-S,GTI
Have no idea how that works. All my cars have had a manual start feature. (Turn the key untill it starts.) |
10-19-2022, 11:56 AM | #33 | |
Drives: FR-S,GTI
10-19-2022, 01:16 PM | #34 |
Even the keyed Twins are operating the same as the button ones. It just feels old school to put a key in a slot. Both are actually just a control that sends a signal to the modules that electronically unlock the steering and tell the starter to spin. The key is not working like switch and directly sending power to the starter.
10-19-2022, 04:14 PM | #35 |
Oh boy, even an a perfect circuit you will have a voltage drop across the conductor. In a defective circuit you will have a voltage drop across the defective component(wire, relay, fuse, ect) due to its resistance. This will lower the voltage to the end component (load). Yes the current will vary with load however the current will be the same throughout the entire circuit. Now the voltage will be divided up across all components in the system. If you have 12v at the battery and the relay has high resistance and has a 4v drop across, plus in a high current situation you have a 1v drop across the wire that means only 7v is getting to the starter motor.
The Following User Says Thank You to Grady For This Useful Post: | FR-S2GT86 (10-19-2022) |
10-19-2022, 04:28 PM | #36 | |
Master Collaborator
Yes, and with these push-button start cars, the ECU actually sends the 12 volt signal to the starter solenoid circuit after all of the checks are made such as the clutch switch, the park position or neutral safety switch on an automatic transmission car, the passive auto immobilizer circuit, the minimum operating voltage check, etc. if and when those pass the self check, which happens in milliseconds, THEN the solenoid will finally get the 12 volt signal it needs to energized the contacts to the starter motor. One key thing, the minimum operating voltage check is there to protect the ECU from an under-voltage condition. If the ECU doesn't detect the minimum voltage as it gets the signal from the push-button for a start cycle, in order to protect itself, it will not attempt to energized the starter solenoid circuitry. Very low voltage on modern vehicles is equally, if not, even worse than high voltage conditions. This explains why I often see issues such as someone leaving their vehicle parked for weeks at a time with a failing battery and coming back to start it up to find a dead battery. After the battery has been recharged or replaced, they start having strange electrical issues. Low voltage conditions for extended periods is normally the cause of these strange issues. |
10-19-2022, 07:40 PM | #37 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
An incandescent test light is still used in some manufacturer supplied troubleshooting workflows right up to now, chrysler uses it A LOT, and yes, even in engine performance DTCs on circuits going straight into the ECM. |
10-20-2022, 07:39 AM | #38 | |
Drives: FR-S,GTI
And as far as voltage vs. current goes: Suppose I have 8 AAA cell batteries in series and connect them to the starter. What do you think is going to happen? You have 12 volts. Why won't the car start? |
The Following User Says Thank You to WNDSRFR For This Useful Post: | Tcoat (10-20-2022) |
10-20-2022, 10:42 AM | #39 |
Because when you close that circuit you will not have 12V at the battery any more. Why because of battery internal resistance.
10-20-2022, 11:45 AM | #40 |
Drives: FR-S,GTI
OK
Let's say we replace the car battery with 8 AAA batteries. Turn on the key and all the lights on the dash light up. Now turn the key to start the car. What happens? Nothing. The lights on the dash go out because the starter is drawing all the current from the batteries. So let's try it with 16 AAA batteries in series (24 volts). Turn the key on and the lights on the dash don't light. Because you just blew them up with 24 volts. Now turn the starter. What happens? Nothing because you don't have nearly enough current to do squat. Battery internal resistance? Let's try lithium batteries. They have almost no resistance which is why they like to burst into flames. The results will be the same because you don't have enough current. |
10-20-2022, 12:27 PM | #41 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (10-20-2022) |
10-20-2022, 12:52 PM | #42 | |
You don’t have to hold the key either. You can just turn it and let go and it will automatically start if thing are working right. The only difference between the two is how the switch is allowed to activate. The key uses tumblers and the button is a security signal. That is all. Hell even a physical key without the chip won’t work. These are not a 55 Buick where turning the key physically allows current to run through the switch to activate the solenoid. The ECU does all that. Either way you are just letting it know you are ready.
Similar Threads | ||||
2013 Scion FR-S cranks but no start!!! | Btborja | Issues | Warranty | Recalls / TSB | 43 | 10-29-2023 09:30 PM |
Car cranks but won't start after openflash custom tune install | kyu01186 | Software Tuning | 1 | 10-05-2021 07:28 AM |
Long cranks and engine struggling to start. Please help! | pakunodafie | Engine, Exhaust, Transmission | 17 | 09-08-2021 02:32 PM |
HELP! Cranks but won't start P0102 P0113 | Sum10clever | Issues | Warranty | Recalls / TSB | 2 | 09-05-2020 11:46 PM |
Car cranks but wont start | yablonskiy11 | Issues | Warranty | Recalls / TSB | 15 | 01-02-2019 12:18 PM |
