Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-07-2018, 04:40 AM | #29 |
Drives: brz 2017 hksv2
if your am was logging 0 you obviously had a out to date template , so it your (the user) fault, not oft's
it takes 2 minutes to update template to the latest one with oft manager i m mapping 2 cars with oft and they log everything good, just the command afr is a bit offset in the positive side (something like +0.2/0.25, not so relevant when you know it) it's a logging AND flashing device, it feels incomplete only if you are so accostumed to ecutek that you miss logging 30+ values at a time, but again, not incomplete to not allow you to reach exact same performance as ecutek, racerom features aside. it logs everything you need, just not more than 14 at a time because of the hardware limitations, you have this comfortable but small and not expensive tablet instead of a windows laptop that is 10 times bigger minimum so oft costs around 500$ and that's it, for ecutek you need a windows laptop (cost variable)+ cable (350$)+ licence (300$)+ racerom package to benefit the extra features (350$) and/or a tuner (350$) actually, there are pretty important submaps that ecutek doesnt define, but oft does, like timing compensation per cylinder, and throttle minimum tip in enrichment activation, and many others. and that bothers me a lot hope you remember i have ecutek and racerom package, i just don t like your denigration about oft, because it sounds to me at this point that's just you that can t use it properly, but the truth is another story Last edited by tomm.brz; 05-07-2018 at 04:54 AM. |
05-07-2018, 06:54 AM | #30 | |
Drives: '15 BRZ RA
I was not disatisfied only by the OFT. I also mentioned about the sprint booster which I tested it at a different time and it gave too much wheel spin. |
05-07-2018, 07:14 AM | #31 |
well i dont know when you tried the oft, but can t be everything perfect super quick, it takes time to do reverse engineering and software developing
i also had to wait a bit that ecutek completed defining k00g roms to tune my my17 as today the logging problems with oft are gone anyway sprint booster sounds stupid anyway, nothing that a good tune of the accel to torque and throttle maps tuning can t do |
05-07-2018, 11:23 AM | #32 | |
The Dictater
Drives: '13 Red Scion FRS
The Following User Says Thank You to Spuds For This Useful Post: | Tristor (05-08-2018) |
05-07-2018, 01:13 PM | #33 |
Huge E85 fan!
Drives: 2016 Scion FRS
IF you have access to E85 AND emissions testing isn't a problem, the best combo of cheap and easy and power is to gut the cats, get OFT and retune on E85. Hands down, by far the best bang for the buck. Only Tactrix is cheaper (though I'm only going by what I've read). But Tactrix is not easy, OFT is very easy to is.
I got my OFT for $350 and my fuel cost has gone down about 10% because E85 is a lot cheaper here. Putting down right around 200HP 160ft-lbs to the wheels |
05-07-2018, 01:34 PM | #34 |
Drives: Crapcan
OFT and E85 as others have mentioned. I'm always jealous of you guys that get e85, I don't have it anywhere near me.
It is not an HP mod but dropping the FD to a 4.30, 4.44, or 4.56 would be a big gain in acceleration and feel. |
The Following User Says Thank You to NoHaveMSG For This Useful Post: | whataboutbob (05-08-2018) |
05-07-2018, 01:40 PM | #35 | |
Quote i d really love to switch to at least 4.3 to get a nice gain in wheel torque, but that s not so cheap to do unluckily |
05-07-2018, 01:46 PM | #36 |
Drives: Crapcan
Yeah I agree it is not cheap, but even if you buy a cusco 4.56 fd and then labor to install, it is about the same price as an OFT, header, and catback.
05-07-2018, 01:56 PM | #37 |
i d still prefer the oft & exhaust combo .. but all is better :P
The Following User Says Thank You to tomm.brz For This Useful Post: | NoHaveMSG (05-07-2018) |
05-07-2018, 02:31 PM | #38 | |
Drives: '15 BRZ RA
(*) Toda Racing includes a new standard length belt with their kit. They say that installing a new belt is important to improve reliability. Last edited by nikitopo; 05-07-2018 at 02:41 PM. |
05-07-2018, 02:38 PM | #39 |
The Dictater
Also +1 on OFT, drop in filter, and headers (and E85 if it's available) for cheapest power increases. I don't have headers yet, but that's next on my list.
My butt dyno likes a lighter wheel/tire combination if you want to go down that road. |
05-07-2018, 02:53 PM | #40 | |
The Dictater
A thicker drive shaft flexes less and therefore has better response because there is a greater moment of inertia to counter the flexing. Completely different mechanic than what you were trying to describe. I was giving you the botd in terms of pulleys losing energy to more vibration since the loss would be low in this case. |
The Following 5 Users Say Thank You to Spuds For This Useful Post: | CSG Mike (05-07-2018), tomm.brz (05-07-2018), Tristor (05-08-2018), Ultramaroon (05-08-2018), weederr33 (05-10-2018) |
05-07-2018, 04:53 PM | #41 |
Drives: BRZ 2018
A friend of me with MY02 STI has had engine failure (main bearing) that was probably due to lightweight flywheel + pulleys, no other mods to his car but maybe it was irrelevant, who knows!
Back to our case what I suggest you is what I am going to do to my own MY18 BRZ: aftermarket UEL headers, ECU remap (OFT, Ecuflash or Ecutek) and later a closer final drive say 4.56:1! It all depends from where you drive, what are your goals and finally personal preferences, each mod has its pros and cons, ECU remap with tactrix cable and Ecuflash is the cheapest power money can buy! |
05-08-2018, 08:12 AM | #42 | |
Drives: '15 BRZ RA
Similar Threads | ||||
Easiest way to prime oil system | mhiscott | Engine, Exhaust, Transmission | 12 | 03-18-2017 01:52 PM |
Which SC kit is easiest to install? | tzbang | Forced Induction | 51 | 11-10-2015 12:25 PM |
Easiest oil change | tzhu07 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 51 | 04-18-2014 10:27 AM |
easiest color to keep looking clean? | fatoni | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 25 | 10-10-2013 07:21 PM |
Easiest way to get to the over-pipe? Doing an install... | seven | Engine, Exhaust, Transmission | 7 | 02-03-2013 07:38 AM |
