08-27-2014, 10:35 AM | #169 |
If you're lowered, you'll have a lot more than 0* in the rear. I was at -2.1* rear on swift sport springs. You'll be a bit under that because your springs don't lower quite as much (1" vs 0.8"), but you'll definitely have at least -1.5*.
08-27-2014, 11:17 AM | #170 | |
- Andy |
08-27-2014, 04:32 PM | #171 |
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
Yeah its weird. I'm going to leave the rear camber alone.
According to the last alignment which didn't touch it, rear left was -1 while rear right was -1.6
08-27-2014, 04:47 PM | #172 |
08-28-2014, 11:22 AM | #173 |
Lol yeah, I'm going to use a friend's shop next week and tweak it with their help. Hopefully the rears wont have such a huge difference.
05-26-2015, 08:30 AM | #174 |
Drives: GT86
Just read this thread, one question - why do you need a stiffer spring for a lower drop? If you're looking at about a 30mm drop what spring rate would you want?
05-26-2015, 09:47 AM | #175 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Since you are closer to the ground, you want to make sure your car does slam onto the road (that's an over-exaggeration) when going over bumps. By making it siffer, you are increasing the spring's resistance to compress (more force is required to move the same distance)
The Following 3 Users Say Thank You to drewbot For This Useful Post: |
05-26-2015, 10:00 AM | #176 | |
2. Suspension geometry. Things get worse (roll couple and camber curve) when you lower that much, so stiffer springs help minimize the effect that geometry has on the car. Taken to the extreme...a car without body roll does not need to worry about geometry much (but does have to worry about a whole of other things). As for what spring rate for a 30mm drop, the answer is it depends. Tire choice, usage, other mods, etc. - Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | DeaconRoc (05-27-2015) |
05-26-2015, 05:27 PM | #177 | |
Drives: 2014 Scion FR-S
question please
Member Join Date: Mar 2014 Drives: 2014 Scion FR-S Location: South Carolina Posts: 13 Thanks: 0 Thanked 11 Times in 4 Posts Mentioned: 0 Post(s) Tagged: 0 Thread(s) Trader Rating: 0 reviews I recently had TRD springs put on my 2014 FR-S, I believe they lower the car 1 inch if I remember correctly. Have I unknowingly compromised the handling capability of the car if I change springs only? I also planned down the road to get lighter wheels and the Sprint BBK for weight savings and tracking the car. I was planning on using the OEM tires because I like them. Are there negative effects to the suspension due to the drop and reduction in weight??? I honestly did not consider this until reading this thread |
05-28-2015, 09:58 AM | #178 | |
Señor Member
How much stiffer is the ride with the TRD springs? Is it a huge difference? I've been going back and forth in my head over and over about getting these.
05-28-2015, 07:40 PM | #179 |
The car feels great with them on and obviously aesthetically it clearly looks better than before. I had the car up on the tail of the Dragon recently and it handled great with the TRD springs, but I never pushed the car that hard with the original springs so, I cant honestly say how much better it is or isn't. If by lowering the car I disrupted the geometry of the suspension in a negative way I cant tell it. I believe its just as good, if not better, but I'm not an expert.
05-30-2015, 07:40 AM | #180 |
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
Like Colin Chapman said about the massive spring rates they had to run on ground effects F1 cars "Any suspension design will work if you don't let it".
The Following 3 Users Say Thank You to Talus1 For This Useful Post: |
06-29-2015, 07:54 PM | #181 |
Drives: 10 Series Scion FR-S
I'm probably commiting a sin, but I must say, I installed Swift Spec-R springs, OEM bottles up front still, Koni Adjustable at the rear to compensate for that 5.3K springrate. 1.1" drop front and 1" drop rear.
My laptimes improved by 1.5secs all else equal. I'm quite happy, but I think I still have room to improve. Only running 1.1 degrees up front since thats the max the camber bolts will give, and I have no idea at the rear since I don't have LCA yet, but I have Toe set to 0. |
07-06-2015, 11:00 AM | #182 |
Summertime bump.
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
Similar Threads | ||||
BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures) | runny_yolk | Electronics | Audio | NAV | Infotainment | 120 | 01-29-2021 06:18 PM |
step 1 :buy frs in phx, step 2: drive to pikes peak | haymaker | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 08-21-2012 10:44 AM |
[StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:38 AM |
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:27 AM |
