go_a_way1
Old 08-10-2020, 12:38 PM   #10921
BlOody_BoOger
BlOody_BoOger's Avatar
Originally Posted by 86TOYO2k17 View Post
are you talking difference in ambient temps pre blower, like stock MAF location on traditional ESC setup? or have you relocated the MAF to post blower and compared dyno runs or pull times between post 90F and 50F post blower temps?
ambient temps going into the blower will be much more of an impact to power compared to post blower temps.
Every 5.4F is about 1% less air density. but this would only apply to pre blower.
In the new set up MAF has been relocated to post blowers, so that does have some affect. But unlike the original setup which used the airbox my current setup the blowers pull in air from the bumper. So when the blowers are working it's much more ambient air going in.
BlOody_BoOger is offline   Reply With Quote
Old 08-10-2020, 12:39 PM   #10922
WNDSRFR
Drives: FR-S,GTI
No no
I'm talking about ambient air temp not IAT. The temp as displayed on the dash gauge. You know, the difference between if it's hot or cold outside.
Old 08-10-2020, 12:41 PM   #10923
BlOody_BoOger
Originally Posted by WNDSRFR View Post
No no
Oh sorry yes, the current dynos were done when it was 90 degrees outside and the single phantom dynos were done when it was 60 degrees outside
Old 08-10-2020, 12:43 PM   #10924
WNDSRFR
Drives: FR-S,GTI
No no.
I'm talking about ambient air temp. The temp as displayed on the dash gauge. You know, the difference between if the weather is hot or cold outside.
Old 08-10-2020, 12:45 PM   #10925
WNDSRFR
Drives: FR-S,GTI
I don't know what happened!
Double posted!
Old 08-10-2020, 01:38 PM   #10926
86TOYO2k17
Drives: 2017 toyota 86
I know your setup is different than his. My comment was to him.
All these people talking about IAT are really referring to ambient pre blower air, this is completely different than your IAT temp that is located and reading being post blower. For all him or anyone knows there post blower IATs are the same as yours or possibly even worse.
Pre blower temps will have a bigger impact on performance compared to post blower IAT temps. So not a good comparison.
Old 08-10-2020, 01:50 PM   #10927
86TOYO2k17
No no.
Yeah, those temps are completely different and not what he is inquiring.
Ambient temps or pre blower MAF IAT temps which are usually pretty similar to each other (unless MAF is relocated post blower like his is to get a real IAT reading) will have a much bigger difference on performance, compared to post blower "real" IAT temps going into the engine vs ambient (what he is inquiring about) The question is people who are boosted, what are their before blower (typically at or near ambient) and after blower temps. is a 30-40F delta like his considered normal.
Old 08-10-2020, 02:48 PM   #10928
BlOody_BoOger
I'm gonna try a few things to bring down my temps a bit without hindering the boost. Idk if it will work but I'mma give it a shot. Just to try and make those extra 5 ponies
Old 08-10-2020, 05:50 PM   #10929
86TOYO2k17
Replacing the aluminum MAF housing with a plastic one would help and gold heat wrapping everything from throttle body back will make a surprising difference. Not night or day but still effective.
Space looks limited for a heat plate for the engine bay off boost filter but that would probably drop IAT another couple degrees depending on what you came up with. Which might help lessen MAF heat soak effecting on boost reading.
Not sure how the ESC does with rain/water? Could get hood vents a hood vent near or above the engine bay filter would do wonders for off boost IATs. Maybe a protective shroud for the ESC from rain if it’s close to the vent.
Old 08-14-2020, 09:45 AM   #10930
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I was replacing dump batteries and i accidently did not disconnect cable that goes control unit and touched battery terminal less than 1 sec then boom! I think i shorted that control unit. I am wondering that unit has some kind of fuse to protect its unit? Stupid me didnt think of it. I shouldve disconnect that red cable first. I completely screwed? Or can be fixed?
Sent from my SM-N950U1 using Tapatalk
Old 08-15-2020, 06:50 PM   #10931
BlOody_BoOger
I sent you a photo on your sale post. But this has happened to me before did the boom happen at the batteries or controller because went it happens to me just the batteries went bad not the controller. Keep the batteries for a month and ask for a refund. That's what I did just said hey I've had these for a month and they went bad already and they sent me new ones.
The Following User Says Thank You to BlOody_BoOger For This Useful Post:
zc06_kisstherain (08-15-2020)
Old 08-15-2020, 09:20 PM   #10932
zc06_kisstherain
Drives: SWP BRZ
really? i used multimeter and battery read voltage 13v
yeah i took apart and fuse is fine too~!!
also, just call battery mart and batteries went bad? then i dont have to send replacement? what do they ask?
Old 08-15-2020, 10:35 PM   #10933
BlOody_BoOger
They're going to ask to send the ones you bought just send them back they will test them and confirm they are bad, and send new ones they really don't ask alot of questions.
Old 08-15-2020, 10:37 PM   #10934
BlOody_BoOger
Lol when I did the batteries were already 9 months old I think the batteries have a 1-2 year warranty.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
