05-02-2019, 01:58 PM | #211 |
Drives: Galaxy Blue BRZ/Takeda CAI/Mag CatB
Vehicle Mileage: 30,000
Make: Subaru BRZ Miles After Recall: >1 Problems After Fix: Brought the car in because it was having a fuel cut issue when driving over 5,000 rpm's. Car drove great when normal driving, but when getting on it it would simply lose all power but the car would stay on and no CEL's, after a second it would work fine again. Cleaned air filter (Takeda) and gave it Chevron Techron fuel cleaner. Car still did it so I brought it in to dealer since I still have warranty. Dealer says it could be the recall so I say fix it. 5 days later I get a call that car is ready, been test driven, no stalling but needs several hundred dollars in maintentance (tires, brake fluid, ac charge etc.). I so, OK, but first I want to test drive car. I go test drive it with mechanic, first acceleration the car does the same thing bust worse than ever. Was on the gas, only about 35 mph but accelerating, then the whole things stops moving and the gas pedal doesn't work. This time the car dies, never used to, and I pull over. Try to start car but it won't. Wait a few seconds, try again and car starts. It drives normal as I head back to dealer but I don't drive it hard again. Mechanic who was driving with me says it's a fuel starvation issue, he'll diagnose and call me the next day. Three days later I get a call that I need to bring them a stock airbox and pay for fuel injector service. Dealer says mechanic is confused, he called Subaru Tech and they told him this is how to proceed. Im bringing stock airbox to them tomorrow and told them to proceed with the injectors. I don't have confidence that this will fix the problem, super worried. Any thoughts? P.S.-Dealer said that the issue only seems to happen when the the car is below 200 degrees operating temperature, that it doesn't do it once it hits 200 degrees. (not sure what this means, the car does the fuel cut/stall after it's been driven for a while and plenty warm but the dealer says "that doesn't have anything to to with the operating temperature which is between 190-215 degrees") |
05-05-2019, 09:16 AM | #212 |
Drives: 2012
Hi Guys,
First post here. Vehicle Mileage(Km): 75,000Km Make: Toyota 86 Miles (Km) after recall: Approx 100km Problems After Fix: Car has not had any modifications and has been serviced ahead of schedule and has run flawlessly since I first bought it. Thought I would combine major service and valve spring recall in order to avoid having the engine being taken out twice. As soon as I got the car back from the dealers it felt a little "off" in the sense that it just did not feel as responsive as before. In addition there was a little bit of a burnt oil smell when I first started driving. I thought I was being too sensitive and felt that it would all settle down. About a week after the service, as I was coming off the freeway, I noticed a burning smell but could not see any smoke. The engine then began to starting "pinging" and the smell became stronger. There was no loss of power but the pinging became louder and as I stopped at the lights I started noticing smoke start coming out from under the car hood--sort of like when you have a really smokey barbecue. I immediately switched off the car and prepared to leave in case a fire broke out but the smoke died down after a minute. I was about 400m from home and it was downhill so I risked it and coasted down with the motor on, there was continual "tapping" from the motor as I coasted home. When I got home I examined the car: There was a small amount of smoke rising from the region of the right exhaust manifold, there was oil in both exhaust pipes and there was oil along the right hand side of the car. The smoke appeared to be coming from oil being heated on the exhaust manifold and there was a thin film of oil along the entire left hand side of the car. I think I was pretty close to suffering a fire like KimKongs1981's. The dealer arranged to have the car picked up and it was taken away by flatbed to the dealers where it has been for the last three weeks. Initially I was told that a gasket had failed--wear and tear item--and that they would replace it as a goodwill gesture. Now they're saying the motor is not right and they're working on it though they are not sure when it is going to be completed. Engine ticking noise. |
05-05-2019, 03:38 PM | #213 |
05-05-2019, 04:24 PM | #214 | |
Drives: 13 Subaru BRZ
Sent from my PH-1 using Tapatalk |
05-06-2019, 08:17 AM | #215 | |
Drives: 2012
As I said on the Australian forum, the fact that this is now happening in the U.S., Canada and Australia, points towards a systemic problem and not a dealership specific one. Sealant placement seems like a fiddly job that requires a fair amount of concentration. Laps in concentration leads to catastrophic consequences. They--i.e Toyota--should have thought a bit harder about how to apply the sealant so that it wouldn't have caused problem. i.e a tool or jig to assist with the job. I'm not sure what the legal situation is like in the U.S. but I don't think that they would have a leg to stand on if they pushed their luck in the Australian courts. |
05-06-2019, 08:18 AM | #216 |
Drives: 2012
05-06-2019, 10:04 AM | #217 | |
Drives: 2019 Mazda Miata RF
05-06-2019, 12:05 PM | #218 | |
humfrz |
05-06-2019, 12:33 PM | #219 |
So just preparing for the worst case here... but depending on what I find tonight with a misfire I have it may end up being low compression on Cylinder 3.. the vin for the car still shows that it is open for the valve spring recall that has not yet been done.. my question is... if the spring already went..will Toyota still honor the recall? Any experience with this scenario here?
05-06-2019, 12:41 PM | #220 | |||
Drives: 2013 WRB BRZ
05-06-2019, 12:44 PM | #221 |
Thank you! I'll need to do a little more reading into it depending on what I find out when I get home this evening with the compression test. If its valve spring related then I'll need to see if I can have it towed up to Toyota as its no good to drive other than in and out of the garage... Crappy thing is the car isn't even registered yet so I'll need to see what the process would be with regards to that as well.. |
05-06-2019, 12:56 PM | #222 | ||
1st86 Driver!
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following User Says Thank You to Dadhawk For This Useful Post: | Tcoat (05-06-2019) |
05-06-2019, 02:13 PM | #223 | |
05-06-2019, 02:25 PM | #224 | |
humfrz |
Tags |
fa20, failure, recall, spun bearing, subaru, toyota, valve spring |
Similar Threads | ||||
2013 Valve Spring recall - modified (FI) engine thread | shiumai | Forced Induction | 71 | 08-11-2020 06:21 PM |
TSB / Recall thread take over | Sigh-on-Rice | Issues | Warranty | Recalls / TSB | 17 | 02-18-2019 11:24 PM |
CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
PA Monogram Registry! | kazetaro | NY / NJ / CT / PA | 0 | 06-06-2014 06:49 PM |
Another Detonation thread. (DI failure related) Input Please. | Thorpedo | Issues | Warranty | Recalls / TSB | 15 | 08-02-2013 07:23 PM |
