Software Tuning Discuss all software tuning topics. |
08-10-2014, 01:52 AM | #29 | |
You have likey caused the problem by shorting something out and blowing a fuse or blowing something in the cars computers. undo all your wiring mods, check all fuses and the obd port fuse ,pray and you may be ok. |
The Following User Says Thank You to steve99 For This Useful Post: | afishl1 (08-10-2014) |
08-10-2014, 02:35 AM | #30 |
Drives: Raven FRS MT
How come when query the rom it shows the stock name rom and not my renamed new one or is that how its supposed ro be, been a while since I flashed
08-10-2014, 03:38 AM | #31 | |
If your usuing you cable to query your ecu and is comming back with something like ZA1JB01C then it a good sign ie the ecu is responding andcthats the ROM calid or type number. You can name rom files whatever you like but all the ecu knows is the calid. maybe read the link below on ecu flashing it will give you an idea of the process. As for working of ecutk software sorry dont use it, but the flash process is same regardless of the flashing toll used |
08-10-2014, 03:47 AM | #32 |
Gotcha, do u have any idea how to know if I've blown the BIU?
08-10-2014, 05:10 AM | #33 |
Unfortunatly tying to diagnose complex electrical issues via internet messages ain,t going to work.
Check what works and what does not on the car will give some lclues as to where to look Check the connections you were messing with return it back to stock Check for blown fuses , loose connectors or cut wires if something not working Remove battery terminal for 5 minutes to reset all control units After that you going to need TechStream diagnostic software the dealers use a full shop manual and good electrical knoledge. ie it time for dealer or auto electriian |
08-10-2014, 06:07 PM | #34 |
Well I think I would have to get an auto electrician because I dont see how I can bring my car to the dealership at this point with e85 and an intake in it and without the ability to flash back to stock. Heck, I'm too nervous to try to even run it right now after the flash failed while downloading.
Anyone know of a good electrician in the LA area? |
08-10-2014, 06:17 PM | #35 |
Drives: UK GT86
[QUOTE=afishl1;1892416]Well I think I would have to get an auto electrician because I dont see how I can bring my car to the dealership at this point with e85 and an intake in it and without the ability to flash back to stock. Heck, I'm too nervous to try to even run it right now after the flash failed while downloading.[/ QUOTE]
Car won't start on a failed flash. Any chance you've just drained the battery? If you have power, have you tried to re-write a new ROM to it by manually selecting vehicle? When programming the ECU: "ROM File To Program" will be the file on your PC/Laptop "ECU Version" shows the ROM type & version "Comment" is what is stored in the comment of the Keying screen of the ROM "Licenses in ECU" will show whether the ECU has a valid license. As said before, disconnecting the battery will have no affect on the ECU apart from giving it a reset.
.: Stealth 86 :.
08-10-2014, 06:22 PM | #36 |
New update works great for me !
08-13-2014, 08:03 PM | #37 |
Well I'm back up and running, was either charging the low battery or cutting short the long tapped wire leading to nothing.
05-18-2015, 05:23 PM | #38 |
Drives: 2014 BRZ Limited [6MT/SWP]
I'm having the exact error as the OP, except this is the first time I am using Ecutek on this vehicle. Which means it took my license from me, and never finished the flash. I haven't driven this thing in over a month now, I have ran into just about every issue possible during the FI install, and this is right on track. When and if I get my tuner to reapply my license, any advice besides updating ProECU? Given the time frame of posts I'm guessing Ecutek already has fixed that issue for good by now, but I can't risk losing another license again and getting stuck halfway through the flash.
05-18-2015, 06:34 PM | #39 |
Drives: UK GT86
It's not something daft like a low battery causing the issue? This hasn't been an issue in quite some time.
.: Stealth 86 :.
05-18-2015, 06:58 PM | #40 |
Being that I haven't driven it in so long, it might be. I just assumed as long as the power worked it would be good. It's testing at 12.10 volts right now, that considered low? I have to email my logs over to my tuner so they can contact Ecutek to give me another license so prob another day or 2... I'll throw the charger on.
05-18-2015, 10:47 PM | #41 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Did you try flashing again? Do make sure the battery voltage is good and the connection is secure on the usb/odb2 port. Sitting for a month is often times enough for the battery to get weak enough to not support a flash. Otherwise you'll want to contact your tuner (not sure if it us or not), not EcuTek for support of this issue.
05-19-2015, 09:58 AM | #42 | |
Similar Threads | ||||
Moto-East EcuTek RaceROM and Tune Update! | Xero-Limit | Software Tuning | 50 | 10-30-2015 02:03 PM |
PS3 (GT6?) won't update 1.03 | ZionsWrath | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 01-22-2014 01:33 AM |
Ecutek reads ecu as unsupported after rpm tsb update help please | Frs32907 | Software Tuning | 14 | 12-20-2013 10:19 AM |
Where can i get an ECUtek license update? | ag144 | Engine, Exhaust, Transmission | 2 | 07-25-2013 08:32 AM |
Ecutek gas gauge issue fixed | maj75 | Engine, Exhaust, Transmission | 1 | 03-23-2013 11:49 AM |
