Old 04-24-2019, 11:18 PM   #631
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Originally Posted by elBarto View Post
Is it an old OFT?
I also had the dev121.dll error. Only solution was to flash back to stock, erase the tablet and start over.
But before you try the erasing part, try updating the template file
old thread 1
old thread 2
Thank you, turns out i had to download vcredist_x86 to get things to work.
Do you by any chance know the difference between v1 and v2 template file?
Carlitoz3 is offline   Reply With Quote
Old 04-26-2019, 09:30 AM   #632
DonnerParty
DonnerParty's Avatar
Drives: 2019 BRZ Limited PP
I wanted to wait a week before asking for help, hoping the ECU needed to adjust but something doesn't feel right.
2019 BRZ stock besides a new Corsa cat back exhaust. Every gear feels more sluggish, third gear has drastically less power. I've had a couple friends who own BRZ's drive it, and they feel the same way. Any Idea on what could be happening?
DonnerParty is offline   Reply With Quote
Old 04-26-2019, 09:35 AM   #633
tomm.brz
Drives: brz 2017 hksv2
DonneParty, you need to log your car. Log a small drive with low. throttle driving and one WOT pull in third from2k rpm to redline and upload to datazap and put link here or even better in the Data Logs thread
Old 04-26-2019, 02:58 PM   #634
elBarto
elBarto's Avatar
Drives: Toyota GT86
V1 is for the old OFT tablet (the first one)
V2 is for the newest tablet (with the bigger screen)
Do not mix them, or your screen is going to be unreadable.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 05-10-2019, 01:56 PM   #635
Bisofication
Bisofication's Avatar
Ok it important to understand whats going on
1. the tunes/rom is fine
2. the V4 manual tunes 2012-2016 cars are all actually A01G roms
3. the problem is in the definition it got an error
4. don't alter that table with the supplied definition as bad stuff may happen including bricked ecu. as the def is not accessing the correct area in the rom for that table.
If someone needs to access that table I can post up a correct def
I'm trying to get the Overrun pop tune to work but it's highlighted in red
I have the B01C definitions
Thanks!
Bisofication is offline   Reply With Quote
Old 05-10-2019, 05:54 PM   #636
steve99
Thanks!
Did you get my definition from first pist in this thread ? , Then mske the cakid mod as per instructions in first post The standard oft def has some errors in tabkes people use for pop tunes
When ever you male a change in romraider it highlicghts cels in red.
Jist make sure the numbers and axis values in the table your changeing are not corrupted or incorrect before you start modifying table see image above for example corruptions, this means your definition is incorrect
Old 07-13-2019, 09:36 AM   #637
LancePower
Drives: 2020 BRZ tS
Anyone know the difference between the v4.01 and v4.03 tunes?
Can find Release Notes anywhere.
LancePower is offline   Reply With Quote
Old 07-14-2019, 05:45 PM   #638
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Second this!
Ernest72 is offline   Reply With Quote
Old 07-14-2019, 07:16 PM   #639
steve99
Originally Posted by Ernest72 View Post
Second this!
No difference in tunes, they just added support fore more ecu calid
Their is a difference between V1 v2 and V4 tu es though
Like V2.03 to V4.03 yeah thats different
mgarcia707 (07-15-2019)
Old 07-18-2019, 02:02 PM   #640
nastynate88
nastynate88's Avatar
Drives: 2014 BRZ
Hi all, I upgraded to the 4.03 tune. LC works fine but FFS doesn't seem to work? Is there a particular way I should be driving that's not obvious to me? I just keep my foot down while hitting the clutch and the revs jump (luckily I caught it before over-revving).
nastynate88 is offline   Reply With Quote
Old 07-19-2019, 06:23 AM   #641
ermax
ermax's Avatar
It only works above a specific RPM if I recall. If you open it in RR you should see the parameters.
BTW, our cars have rev limiters.
Old 07-20-2019, 07:30 AM   #642
steve99
FFS is disavled by default in all v4 tunes. You will need to edit tune to activate
Old 07-23-2019, 04:34 PM   #643
nastynate88
Drives: 2014 BRZ
Understood, thanks!
Old 07-25-2019, 01:38 PM   #644
CSPTK
Drives: 2014 FR-S
For upshifts. Downshifts can still be
CSPTK is offline   Reply With Quote
The Following User Says Thank You to CSPTK For This Useful Post:
wparsons (07-25-2019)
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 07:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 04:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 02:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
