07-16-2018, 12:32 PM | #519 |
Drives: 2013 pearl white FR-S
i just flashed the stage 1 v4.03 tune and have driven it for abt 70 miles now... one thing i noticed is that there seems to be unburned gasoline smell during cold starts.. is that normal now that the cold start function is gone?
The Following User Says Thank You to DarkSideFRS For This Useful Post: | mgarcia707 (09-17-2018) |
08-03-2018, 12:01 AM | #520 |
Drives: 2014 Asphalt FRS
So does the cold start delete still idle higher than a stock tune?
08-03-2018, 01:24 AM | #522 |
Ah I see. Wouldn't this affect/damage the cats since it's not heating up to operating temp as soon as possible? Also when winter comes along wouldn't this be a bigger problem? Sorry for the questions.. I'm still on v3 tunes and Im debating if I should go v4 lol..
08-03-2018, 01:33 AM | #523 |
Drives: 2014 GT86
It won't "damage" cats. They just won't be heated quicker to working temps (reason why primary cat is that close to cylinders and why cold starts in tune exist) and thus emissions, if measured right after cold start, tests will be worse. If that matters to you, where you live, it's up to you. I'm not familiar with emissions testing in cali to advise something.
The Following User Says Thank You to churchx For This Useful Post: | Madara (08-03-2018) |
08-03-2018, 09:00 PM | #524 |
Tried to download V4 but im getting this error..."Error 404 - Page not found!" on the website.
This is the link im trying to open http://www.openflashtablet.com/downl..._USDM_ONLY.zip -EDIT- Figured it out D:..geez the website looks so different from before Last edited by Madara; 08-03-2018 at 09:15 PM. |
09-15-2018, 06:32 PM | #525 |
Download page indeed takes you to 404.
I think OFP wants you to buy it now (for $0) and sign a few liability forms http://www.openflashtablet.com/shop/...-us-6mt-v4-03/ |
09-17-2018, 01:53 AM | #526 |
Drives: WRB BRZ
Flashed my 2013 BRZ manual with v4.03.
https://support.openflashtablet.com/...4-us-6mt-v4-03 After 200miles, I'm getting consistent idle dip when the AC is on. I had the deal apply the TSB for this fix awhile ago when it became available and it seemed to fix the problem. After flashing to stage 1, the problem is back....any ideas? |
09-17-2018, 09:17 AM | #527 | |
09-17-2018, 09:51 AM | #528 |
Drives: brz 2017 hksv2
mostly.of.the dip is when AC goes on and it catches cells of 35% or more of PI
try to zero 0.2 and 0.3 engine load column in the three PI/DI ratio tables |
09-17-2018, 04:28 PM | #529 |
Drives: WRB BRZ
I’m not sure if this will help but I’m planning to downgrade from v4.03 OTS to the older v2.
09-17-2018, 11:48 PM | #530 |
Drives: WRB BRZ
Just flashed the brz back to stock. The idle dip is gone. I'll have to try out v2.076
09-18-2018, 02:31 AM | #531 |
Drives: WRB BRZ
A couple weird things I noticed while I was flashing it back to stock
I got the 4.03 firmware from the site Stg-1-v4.03-LC-FSS-ZA1JB01C.bin My cars orig Cal code is ZA1JB01C After flashing to v4.03 it changed to ZA1A01G Is this normal? Wasn't there a safety mechanism to stop flashing the wrong .bin? |
09-18-2018, 02:47 AM | #532 |
v4.03 pre restyling are all a01g hacked, like k00c is k00g actually
Similar Threads | ||||
Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Software Tuning | 130 | 08-25-2020 07:29 AM |
The latest EU/AU OFT tunes (D00G) don't come with launch control | jamesev93 | Software Tuning | 4 | 03-12-2018 04:14 PM |
Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Engine, Exhaust, Transmission | 3 | 08-27-2016 02:04 PM |
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 54 | 06-11-2014 06:29 PM |
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 03:35 PM |
