Old 07-21-2020, 02:29 PM   #1
nwgabrz
Drives: BRZ Limited
Tein EDFC with Subaru Rubber Trunk Liner
Does anyone have experience with the EDFC and the factory rubber trunk liner? Will it clear or will it have to be cut or removed, or will it be flexible enough?
Rubber liner:
EDFC (but need to know if the block in the rear is compatible with the liner:
nwgabrz is offline   Reply With Quote
Old 07-21-2020, 02:49 PM   #2
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
I was looking into this as well. It will definitely going require cutting the liner. The rubber mat "might" have some flex to it to work around it but you probably don't want to put the motors in a situation to have pressure on them. Best to cut both.
04 Scion xA > 13 FR-S stg 2 UEL E85 > 16 WRX stg 1.5 > 15 Audi S3 > 18 BRZ Limited UEL E85
JonAvalon is offline   Reply With Quote
The Following User Says Thank You to JonAvalon For This Useful Post:
DarkPira7e (11-23-2020)
Old 11-22-2020, 11:50 PM   #3
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Random question but where are y'all gonna tap for the vehicle speed sensor wire?
Jyn is offline   Reply With Quote
Old 11-23-2020, 12:18 AM   #4
sachu
Drives: rocketship
Am using the GPS module, but i might re-do this and tap into the vehicle speed cable taht's available with the maestro iDatalink module. Not entirely sure if it'll actually work or its just a dummy cable.
sachu is offline   Reply With Quote
Old 11-23-2020, 12:28 PM   #5
Jyn
Noob
Jyn's Avatar
Yeah I had heard there's a vehicle speed sensor cable and even canbus high and low signal behind the headunit.
I have a monogram FR-S though... I bet BRZ has it lol
Old 11-23-2020, 04:58 PM   #6
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Rubber liner:
You could probably bend it out of the way, but the Tein coilover tops already sit high and need clearance
EndlessAzure is offline   Reply With Quote
Subaru Trunk Lid liner Trojan_SC Interior Parts (Incl. Lighting) 4 05-26-2019 04:24 AM
FS: Weather Tech Mats & OEM rubber trunk liner Sterling Doc Interior Parts (Incl. Lighting) 4 07-12-2015 12:45 AM
WTB Subaru Trunk Liner leoh007 Want-To-Buy Requests 2 04-29-2015 01:06 PM
Rubber Mats and Trunk Liner TeamTFR Interior Parts (Incl. Lighting) 9 09-25-2014 06:56 AM
FS: Subaru Cargo Liner (Rubber) that_guy Canada Classifieds 7 05-13-2014 01:26 PM
