BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
09-30-2013, 03:44 PM | #15 | |
Drives: '21 Civic Type R
"Give a man a match and he'll be warm for a minute. Light a man on fire and he'll be warm for the rest of his life."
Follow me on Instagram! |
09-30-2013, 03:48 PM | #16 |
Drives: Subaru BRZ Limited
The TSB was for older BRZ's. He said my VIN already has the new pump. Since Subaru found that replacing the pump does not fix issue they've determined the sound as normal are not looking into it any further.
09-30-2013, 05:51 PM | #17 |
Drives: 13' Subaru BRZ Limited SWP 6MT
I call BS.
If chirping was normal, it would have happened when new. Also FT86 isn't the only Direct injection car with HPFP...but it is the only one that chirps. Defective design plain and simple. Either Toybaru redesigns, or they payout after class action law-suit. |
09-30-2013, 08:53 PM | #18 |
Drives: BRZ Limited 6MT
I bet the continues chime is to indicate that you opened the door while the engine is running and there is a bug that does not turn it off when you turn the engine off.
OK. never mind. It happens after you turn the engine off. Maybe to remind you that you need to take the keys with you. |
The Following User Says Thank You to Zoti For This Useful Post: | theneptune86 (10-03-2020) |
09-30-2013, 09:46 PM | #19 | |
That's what the tech said also. I demonstrated this scenario. I took the keys out of my pocket and put them in the cup holder. Then I turned off the car and then opened the door. Oops, I forgot my keys because there's no chime to remind me about the keys. What happened to the key reminder? Wait a second.... Let me put my keys in the cup holder>Open Door>Turn off Car. All of a sudden the car wants to remind me about my keys? Doesn't seem likely. If it was a "Key Reminder" then it would chime in both scenarios. The tech agreed. The tech also said, "It's chiming because the door is open." As you've figured out for yourself it's not triggered by opening the door. It's from turning the car off with a door open. Not a door warning. Not a key warning. And furthermore you can then close and open the door and the chime is gone. You're sitting in the car with the exact same scenario (Open door, Car Off) but no chime all of a sudden? At this point I'm not looking for a solution to fix the chime, I'm looking for information on if someone can explain it's purpose to me. I've already realized the dealership can do nothing about the chime. It's here to stay. The least someone can do is tell me what it's purpose is! Please! The way I see it is: Both scenarios lead you to a car that's OFF and a door that's OPEN, therefore the chime should be consistent. The car should either chime for both situations or not chime for both situations. It should not be different just because you did things in a different order. Maybe this was overlooked by Toyota/Subaru. |
10-03-2013, 10:59 PM | #20 |
Drives: 10 Series FR-S #207
It does it because the steering wheel hasn't gotten a chance to lock, not the noise coming from the steering wheel once the door is closed?
Its a weird Toyota/Lexus keyless entry thing, my mom's 2011 Rx does it and my 2013 10 Series FR-S does it too. |
10-04-2013, 01:46 PM | #21 |
It seems you are correct but as opposed to cars with a key, turning the wheel with the ignition off will not lock it. Closing and opening the door does.
05-03-2021, 12:11 AM | #22 |
Drives: 2017 Brz
I have had a 2017 now for three weeks and the chiming has been bugging the hell out of me. I hadn’t yet figured out what sequence causes the chiming, was just confused why I happens sometimes I turn off the car and not others. I just figured there is some sort of software error.
This thread helped me realize that it is t just me that finds it annoying. |
05-03-2021, 10:49 PM | #23 | |
Enigmeerkat
Drives: 2015 Toyota 86 GTS
2015 Toyota 86 GTS - Ecutek w/ Flex Fuel, Xtreme Stage 1 Organic Clutch - PSR UEL Header, Invidia R400 Catback - Whiteline Swaybars, 18" ROH Blue Evo R |
05-10-2021, 11:56 PM | #24 | |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
It's kind of an odd feature when the lights have an auto-off setting. |
Similar Threads | ||||
Oil consumption? Please chime in | OnTheFence | Issues | Warranty | Recalls / TSB | 48 | 10-01-2019 08:42 PM |
seatbelt chime | drei | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 07-14-2015 04:09 PM |
Engine mounts, please chime in if you have them currently or have experience | nakamur21 | Engine, Exhaust, Transmission | 2 | 08-19-2013 08:02 AM |
Houston Locals Chime In!! | itsibarra | Southwest | 12 | 08-05-2013 11:44 PM |
Factory shift light/chime | Wonderbar | Electronics | Audio | NAV | Infotainment | 29 | 04-05-2013 03:30 PM |
