06-17-2019, 01:29 PM | #1 |
Drives: 10Series 0945
Back up camera options
I would like to have an OEM back up camera installed on my 2014 but not sure if I should just go straight to Subaru and have them install one for a lot of money or have a shop do it. Or are there better third party options to choose from?
Suggestions? Thanks |
06-17-2019, 02:14 PM | #2 |
Drives: 2013 BRZ Limited SWP
Do you want it on the display or rv mirror?
06-18-2019, 12:46 PM | #3 |
Is not fast.
Drives: 2014 Whiteout M/T
$13 Reverse Camera
Reverse cameras can be extraordinarily cheap. I installed this one and it works perfectly. Granted, the install was a little tricky and there were some workarounds I had to do, but overall I'm very satisfied with the camera. There's a very helpful DIY on the forum if you want to do it yourself. The camera itself didn't have quite enough angle by default so it was pointed too much at the ground. To remedy this, I picked up some toilet leveling wedges (yep, that's right) and ground them to the right shape.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
06-18-2019, 01:54 PM | #4 | |
Drives: '13 BRZ
If not, any car audio/electronics shop will be much cheaper than a dealership, who may not even do it for you. Try getting a few quotes and pick the one you are happiest with. |
06-18-2019, 07:07 PM | #5 |
I have no electrical knowledge what’s so ever. So it seems like a shop would be the most affordable choice. I want the feed to be displayed on the oem head unit. Any cameras you guys recommend? That $13 camera doesn’t look half bad at all!
06-18-2019, 07:38 PM | #6 | |
Is not fast.
As for camera options, I'd suggest one that you'd attached on that top portion of the trunk. There are a lot of license plate frame style cameras that look nice, but they may be easier to steal. The trunk mounted ones will require you to drill hole through that part of your trunk but it isn't a huge deal.
The Following User Says Thank You to Manic For This Useful Post: | iag48st (06-19-2019) |
06-25-2019, 01:03 PM | #7 |
Drives: 2014 FR-S
I recently completed an install of this camera
https://www.ebay.com/itm/Update-2in1...72.m2749.l2649 looking very much like the one posted by Manic. Turns out it works just fine using the 6V supplied by the 2014 FR-S head unit - no relay required. Too funny: I ended up with toilet shims as well - 4-pack less than $3 from HD. Two above and two below the license lamp housing to keep the mounting surfaces parallel. Here is the best deal ($21) I found for the Axxess AX-TOYCAM1 head unit harness adapter: https://www.ebay.com/itm/Axxess-AX-T...72.m2749.l2649 |
06-25-2019, 02:05 PM | #8 | |
1st86 Driver!
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
06-25-2019, 09:43 PM | #9 | |
ProCrastinationConsultant
The Following User Says Thank You to soundman98 For This Useful Post: | Dadhawk (06-26-2019) |
06-27-2019, 10:20 PM | #10 | |
Drives: 2014 FR-S
Many of the cameras actually only require 3.3 - 5 or 6 volts, including the factory cameras. These will also operate with the 12V if using the relay, but do not require it. Did my homework, then tested the setup without a relay before installing. I believe the specs for the camera I purchased stated 6V minimum. (Power: DC12V±6V) Last edited by tarzan_nojane; 06-27-2019 at 10:22 PM. Reason: enhanced |
The Following User Says Thank You to tarzan_nojane For This Useful Post: | Dadhawk (06-28-2019) |
Similar Threads | ||||
Has anybody tried this back up camera | Ornelas66 | Electronics | Audio | NAV | Infotainment | 3 | 03-12-2015 04:12 AM |
Back up Camera? | sixthree | CANADA | 1 | 05-20-2014 08:41 AM |
Back Up Camera | mrhemi | BRZ First-Gen (2012+) -- General Topics | 7 | 04-22-2014 09:09 PM |
FS: JDM BRZ Back-Up Camera | Beyer Subaru | Audio/Visual, Electronics, Infotainment, NAV | 3 | 06-21-2013 10:55 AM |
