Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
12-17-2015, 03:35 PM | #43 |
Drives: frs
If i lift the clutch suddenly, car's jerk and make strange noises
12-17-2015, 04:17 PM | #44 | |
12-17-2015, 05:48 PM | #45 |
The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (12-17-2015) |
01-15-2016, 05:46 AM | #46 |
Drives: 2015 Turbo FR-S
I learned how to drive on a manual transmission when I was a teenager (I'm 35) and I've owned 5 manual transmission cars, 3 of which were at 200K+ miles when I got rid of them. I have never completely worn out and replaced an OEM clutch on any of those vehicles. I see these posts about leaving the car in neutral at stoplights - I've held in the clutch at almost every stoplight in just about every vehicle I've every owned with zero issues.
Now, for the first time I switched to an aftermarked ACT clutch in my FR-S since I'm going forced induction soon. Hopefully I'll continue having good luck. |
06-14-2017, 01:50 PM | #47 |
Drives: 2013 Raven FR-S
The clutch on this car isn't a problem, but the throwout bearing is. It's such a PITA to replace though, you might as well just replace the entire clutch while you're at it. Sorry, I'm still salty about Toyota refusing to fix my failing TOB under warranty and then getting stranded a few days later. For what it's worth though, my original clutch still looked nearly new after almost 60k miles when I took it out.
06-14-2017, 02:19 PM | #48 | |
Drives: 10 Series #974 6m/t
06-14-2017, 03:41 PM | #49 | |
Drives: 2014 Porsche Cayman S
Ditto...been driving manual for 31 years and have never had to replace a clutch...always holding clutch in at red lights and using engine braking every chance I get. Only replaced brake pads once as they never get used
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
06-14-2017, 05:58 PM | #50 | |
Drives: White Out FR-S
This is something that would get you automatically failed in a road test. |
The Following User Says Thank You to ST185RC For This Useful Post: | Mister (04-08-2018) |
06-14-2017, 09:07 PM | #51 | |
Drives: 4wd zooks
Even though my brz is in neutral and i have to select 1st , i can still move off quicker than all the auto stop/start eco cars. |
01-25-2018, 06:26 PM | #52 |
My car has seen a few track days. I heel/toe every day, but I'm a little hard on the daily. I don't keep my clutch in at stops. I have found that resting your foot on the clutch does engage the clutch slightly (causes some minor wear i'm sure).
I got 68,270 out of the clutch. $1500 to replace through dealer. I need the car so I couldn't do it on my own and save about $1000 on labor. FML |
01-25-2018, 07:56 PM | #53 | |
Senior gif poster
Drives: 2013 Asphalt FRS
Your TOB will wear out before the clutch does most likely and since the labor for that can be sort of costly might as well drop $220-$250 for a brand new clutch. I had my TOB replaced around 70kish my clutch still had some life left and likely would have lasted me a while longer. But after that new clutch was installed I forgot how buttery and smooth shifting is. Don't sweat it and drive the car how you want, when it's time the TOB will make noise to tell you it's time for a new one and have a new clutch kit installed at the same time. Side note my flywheel was still like new so that wasn't replaced. |
01-25-2018, 08:28 PM | #54 |
Drives: 2013 FR-S Series 10
While on the subject, i usually just let the clutch out in reverse to, well, reverse, instead of adding any gas. basically moving at idle like you would in an auto... am i causing a lot more wear on the clutch?
01-25-2018, 08:42 PM | #55 | |
Senior gif poster
11-27-2020, 05:37 PM | #56 |
Drives: 2015 BRZ Ltd 6MT
Here's 1 data point for reference
I'm pretty surprised of how much clutch life I have left.
I drive pretty spiritedly and I remember after my break-in period I was chirping tires every day. I've never launched my car, but I did learn stick shift and heel-toe in this car. Smelled that burning clutch smell plenty of times. I read somewhere that out of the either or (assuming you can't drive perfectly): dropping the clutch or slipping, dropping probably has less wear. Here's some pics of comparing new vs old clutch. My car has 82k miles on it. I guess I would've been the type where the clutch would've lasted the life of the vehicle. Keep in mind on my old clutch I didn't clean off the rivets to get a super accurate reading, and I was using my left-hand and taking pics with my right. Take these measurements as reference. I measured 3 spots of each side. Measured from top of rivets to clutch face on all 6 measurements. Overall though, the hub-side and flywheel side have different thicknesses: New FW-side: 1.65 mm (avg) New Hub-side: 1.85 mm (avg) Old FW-side: 1.4 mm (avg) Old Hub:side: 1.68 mm (avg) I noticed more inconsistently on the old clutch, but again, I didn't clean off the rivets. So ~0.15 mm or ~9% of the clutch life in 82k miles, guess my clutch should last 800k miles Of course TOB loses it's lube at 30k miles though.... That technical service bulletin should've been a recall... |
Similar Threads | ||||
Average Gas Mileage | Bach415 | Northern California | 57 | 07-18-2017 09:18 AM |
Average MPG in SoCal? | PradiG | Southern California | 64 | 07-30-2013 05:41 PM |
Garage Life: We bring your dreams to life! | Garage Life | Southern California | 0 | 08-17-2012 07:33 PM |
WHATS YOUR AVERAGE MPG? | imravenit | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-10-2012 01:10 AM |
What will the average MPG be? Poll! | SOB | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 04-22-2011 05:48 PM |
