03-28-2015, 07:41 PM | #253 |
I wanna go fast
Drives: 2013 FR-S 6MT
you mean low opacity?
The Following User Says Thank You to 2much For This Useful Post: | Captain Snooze (03-28-2015) |
03-28-2015, 07:58 PM | #254 |
Because compromise ®
Drives: Red Herring
03-28-2015, 08:01 PM | #255 |
Member of the year - 2016
Drives: Scion FRS
I hope this thing can make some gains...
03-28-2015, 08:09 PM | #256 |
Drives: Raven Fr-S
What does the CAD say about weight gain vs stock?
FR-S Mod target: 200 BHp / Tonne 4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff |
03-28-2015, 09:04 PM | #257 |
Drives: BRZ, STI, GT350R, Supra, 987.2
Last time I checked, I remember somewhere between 10-12 lbs on the aluminum intake. I don't fully remember if that was including the SS hardware or not... but that gives you an idea. Bathroom scales says a bare bone stock one is 6-7lbs.
03-28-2015, 10:09 PM | #258 | |
Drives: 2013 FRS
The Following User Says Thank You to Tbird232ci For This Useful Post: | Hyper4mance2k (03-30-2015) |
03-29-2015, 08:32 PM | #259 |
Drives: Lightening Red BRZ Ltd.
It would be amazing if this was the missing piece for NA power gains. I'm really rooting for you guys!
03-29-2015, 08:51 PM | #260 |
900hp at the wheels!
03-31-2015, 04:52 PM | #262 |
Updates?
03-31-2015, 05:19 PM | #263 |
Drives: 13 GBS BRZ
Rome wasn't built in a day.
04-01-2015, 07:23 AM | #264 |
Drives: GT86, SQ5, RS3
Stock manifold doesn't run equal air distribution and the stock ecu mapping is offset on each cylinder to compensate for this. So technically each cylinder will now need mapping individually to make this run right. Cool looking product
04-01-2015, 06:00 PM | #265 |
04-01-2015, 10:22 PM | #266 |
Señor Member
This is the first I have heard of the cylinders receiving different amounts of fuel. I know the ignition timing is different between the cylinders. Are the cylinder fuel trims defined in romraider?
1974 TA22 Celica
2013 86 GT |
Similar Threads | ||||
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 236 | 06-20-2019 01:42 PM |
Intake Manifold | Bu-Tang | Engine, Exhaust, Transmission | 29 | 12-06-2014 01:43 PM |
Intake manifold | viking | Engine, Exhaust, Transmission | 6 | 09-23-2014 11:08 PM |
Oil on/around Intake Manifold | Wepeel | Issues | Warranty | Recalls / TSB | 2 | 05-12-2014 11:40 PM |
WTB: intake manifold | carlitosway6891 | Engine, Exhaust, Bolt-Ons | 0 | 06-22-2013 02:24 PM |
