12-06-2016, 01:02 PM | #113 |
My 2013 A/T is completely stock except a drop in K&N filter. I run 93 octane and am looking for a bit more 0-60 speed. Is it possible to safely do with the OFT or do I need to change the diff gears?
12-07-2016, 05:00 PM | #114 |
Huge E85 fan!
Drives: 2016 Scion FRS
Is this a troll or real?
08-01-2017, 01:05 AM | #115 | |
Drives: 2014 whiteout, scion fr-s
i know im firing up an old thread, but how do you know where the 2k-3k rpm area is in the tip in table? sorry, im a noob! |
08-02-2017, 11:47 PM | #116 | |
Make sure your fueling and maf scaling is good Id probably try adding a bit more retard in the transient ignition retard tables if you getting knock on throttle transients. try whats in the 2017 roms the tip in tables had little effect on knock reduction for me see below for transient retard tables http://www.ft86club.com/forums/showp...1&postcount=18 |
The Following User Says Thank You to steve99 For This Useful Post: | mizzta21 (08-03-2017) |
08-05-2017, 02:01 PM | #117 |
When using the OFT for tuning and on a dyno, what's the best procedure after loading a tune and before making a power pull?
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily 2013 BRZ limited - new toy |
The Following User Says Thank You to nocoolname For This Useful Post: | Teseo (08-05-2017) |
08-05-2017, 04:28 PM | #118 |
Prime your fuel trims. Make several slow (as slow as you can without feeling unstable) climbs to 5500rpm. I usually do this in 3rd or 4th. Once your LTFT has stabilized, and if your IAM is still at 1, let 'er rip.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
The Following User Says Thank You to phrosty For This Useful Post: | Strife26 (01-08-2018) |
12-12-2017, 04:19 PM | #120 |
Drives: 2017 860 SPRINTEK
12-13-2017, 09:54 AM | #121 | |
Drives: 2017 Halo 86
Some time after installing Perrin inlet hose, I noticed a dent in the tube on the stock intake box (#17701), and instead of getting it replaced for $90 I figure why not just get the Perrin cold air intake (the regular one, not the 3" big MAF) for $280. I don't mind spending the money, and I already have the Perrin inlet hose anyway. But I want to ensure I don't have any loss. I know a lot of people saying "don't use CAI, its pointless, it sucks for daily - only good for track, stock box with dropin is better, CAI too restrictive, etc" - but if apparently if you tune it with the proper MAF scaling it can come out on top? That's what I would like to do. Plus it cleans the engine bay up a lot by removing the air resonator, snorkel, and probably also drops a couple grams of weight. So I gotta learn how to do MAF scaling, or else I gotta get a custom tune.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact Last edited by Lakitu; 12-13-2017 at 10:05 AM. |
01-08-2018, 12:04 AM | #122 | |
Drives: 2015 Subaru BRZ Series.blue
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks. |
01-29-2018, 08:40 PM | #123 |
Drives: 2017 BRZ w/PP
dumb question but i that all of these are 91, is there a reason for that? it would be nice to have a 93 map
01-30-2018, 05:26 AM | #124 |
Huge E85 fan!
I run the Stage 2 93 Octane EL map with an Injen (1st Gen) intake. Fuel trims are great, AFR is great (maybe a bit fat, but I think the tune is conservative). I've modified the setup a little for better intake temps, and I am very happy with this. The 93 tune is solid, if you can find 93 in your area.
01-30-2018, 04:33 PM | #125 | |
03-15-2018, 05:45 PM | #126 |
Drives: Toyota Gt86 2012 orange
Hello,
Need oft custom tuner , who can tune overseas, i am from bangladesh. I got OFT for tuning. Toyota gt86 2013 Greddy T518z turbo setup. 3 bar map sensor Stock injector and stock fuel pump. Now running 7psi boost. Please suggest custome tuner. Thanks Saikat |
Similar Threads | ||||
Drift Office Tune vs Visconti Tune | mechaghost | Engine, Exhaust, Transmission | 109 | 07-03-2014 12:57 AM |
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
difference between vortech tune and perrin tune? | Frs32907 | Forced Induction | 7 | 12-05-2013 02:49 PM |
Information I did not want to know. | K2 | Great Lakes | 19 | 07-23-2012 08:18 AM |
