Old 05-26-2020, 05:08 AM   #57
PorscheUnlimited16
Drives: 2016 Porsche Gt4
Only about 5 percent of Porsche owners actually track their sports car. The other 95% have them as an accessories... like a fancy wrist watch. To take a date to the movie theater, or to pull up somewhere fancy and have it valet.. Hence why it’s an option and not standard on regular models (non Gt/Gts/turbo) trims. ) Standard models without Psm still handle incredibly well with the E version.
PorscheUnlimited16 is offline   Reply With Quote
The Following User Says Thank You to PorscheUnlimited16 For This Useful Post:
HachiRokuX (05-29-2020)
Old 05-26-2020, 10:05 AM   #58
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yeah, kinda lame of Porsche to not have lsd as standard equipment. That said, on street tires (RE71R), given 45F/55R or "better" (i.e. more rearward) weight distribution, limited slip not strictly needed. DRove a student's 981 without lsd, on RE71Rs, I did not miss it at all to be honest. Was going decently quick in it too, 2:09s at Watkins Glen, low 1:13s at NHMS South Oval config. Would have won his class in time trials
On the 987 the optional lsd is a small clutch type with *very* modest ramps (i.e. very little lockup).
https://www.planet-9.com/threads/the...ssected.44005/
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Dirty Harry (05-27-2020), nikitopo (05-26-2020)
Old 05-26-2020, 01:54 PM   #59
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Thumbs up
Originally Posted by Dirty Harry View Post
Re-reading this, I can’t believe some Porsches don’t come with an LSD as standard, Porsche is supposed to be the pinnacle. Is PSM that good that it doesn’t need it? It’d be interesting to see a comparison with a non-LSD/PSM only Cayman.
Mid-engine cars with less than 400 hp do not need LSDs. All it does is add weight. Sure I suppose it might help for autoxing, but on a road course - no difference. An LSD wasn't even an option for most of the 987's production run. I believe it was standard on the 981S, with an option eLSD also available. LSD is more necessary for the 981 to make it feel as nimble as the 987 (it's a bigger car with a longer wheelbase).
BTW PSM stands for Porsche Stability Management. All Porsches built since 2005 have PSM standard.
But yeah, midengine / rearengine cars really don't need LSDs until you get up to insane power levels.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Old 05-26-2020, 02:16 PM   #60
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
@PorscheUnlimited16 means PASM
Old 05-27-2020, 03:57 PM   #61
WolfpackS2k
If he is, then he needs to tell us about the E version, because I've never heard of such a thing.
Old 05-27-2020, 04:15 PM   #62
Yoshoobaroo
TRACKBREAD
I think by E version he means E-diff, aka braking the spinning wheel when it loses traction.
Old 05-28-2020, 08:07 AM   #63
ZDan
ZDan's Avatar
Drives: '23 BRZ
PSM for sure has to be turned off for trackwork with the 987 in the dry, so *if* it includes an e-diff feature I'm sure it gets turned off with PSM. In treacherous wet conditions, however, PSM is *very* good.
A serious track build on Hoosiers or other uber-grippy tires will almost certainly require a limited slip, but an aftermarket unit is a better bet than the dinky optional Porsche LSD. Which apparently wears to the point that it's essentially open after some number of track days anyway.
For street car on streetish tires and suspension, I'd say LSD not required.
*IF* I get another Cayman for street/track, LSD won't be a requirement for me, which opens up the available cars IMMENSELY!
nikitopo (05-28-2020)
Old 05-29-2020, 02:39 PM   #64
WolfpackS2k
The electronic differential Porsche offers on the 718 (and 981 before it) (and 911 I guess) is an active overdriving unit. Specifically designed to improve handling. I highly doubt it is deactived if PSM is "shut off". BTW most Porsche models won't let you 100% turn off PSM. I can turn it off on my Cayman S but it isn't really off. Still kicks back on if things get really wild - found this out when trying to do donuts in a parking lot after a snow storm.
Old 05-29-2020, 03:16 PM   #65
ZDan
ZDan's Avatar
Drives: '23 BRZ
This post is about 987.2
But quick readup on 981 sez that PTV option is a clutch-type limited slip (probably same or similar to the dinky 987 unit with modest ramps and designed for very minimal lockup) combined with electronically controlled braking of the inside-rear on corner entry to improve turn-in. Might be fine for normal "spirited" driving but at the track you might want that feature turned off to conserve rear brakes.
Some have reported having to disconnect a yaw sensor to fully turn PSM "off". In my case I drifted my Cayman around regularly with PSM "off" and got plenty sideways without feeling anything and without the any lights flashing. Might not have been "fully off" but it let me hang it all the way out wihtout interfering Fun...
Old 05-29-2020, 08:25 PM   #66
What if I told you McLarens all have open diffs?
BlueWhelan (05-29-2020), Dirty Harry (05-30-2020)
Old 05-30-2020, 06:39 AM   #67
Dirty Harry
Dirty Harry's Avatar
Drives: 2013 BRZ Satin White Pearl
Didn’t know that until you told me. There goes the idea of a McLaren drift car, unless I get a later model with drift mode, but that’s kind of cheating.
Dirty Harry is offline   Reply With Quote
Old 05-30-2020, 08:25 AM   #68
ZDan
ZDan's Avatar
Drives: '23 BRZ
No reason electronically actuating the rear brake shouldn't allow drifts.
Drift control just turns up or down the volume on all nannies together, apparently. It isn't a "drift mode" exactly. https://jalopnik.com/the-mclaren-720...ink-1794879518
Regarding using brake-diff:
Worth noting that getting a limited slip function by braking the inside rear when it starts to spin is different from using a limited slip diff. Braking the inside rear just throws power away, turns it into heat with zero thrust. With a limited slip the inside wheel trying to spin actually directly adds torque to the outside wheel and contributes to acceleration.
If you have gobs of power and brakes are sized to deal with the added use/heat, and have excellent computer control to accurately and predictably apply the inside rear brake to simulate limited slip, braking the inside rear might be fine. I don't know if it's as good a solution for a car with limited power though.
nikitopo (05-30-2020)
Old 05-30-2020, 06:39 PM   #69
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
What if I told you all 86's have LSDs?
Old 05-30-2020, 08:28 PM   #70
Yoshoobaroo
TRACKBREAD
Eeeeehhhhh, teeeeechnically the base version in japan came with an open diff....
twins vs last gen cayman? perryair FR-S / BRZ vs.... 244 03-31-2018 11:44 AM
FS or trade: 981 Cayman S KRC 9 Cars for Sale/Trade 19 12-03-2017 01:01 PM
BRZ vs Cayman/Corvette Norcalkid FR-S / BRZ vs.... 128 01-31-2017 12:36 PM
Porsche Cayman S misooscar Other Vehicles & General Automotive Discussions 46 09-12-2014 05:15 AM
FR-S vs Cayman colganc FR-S / BRZ vs.... 102 09-13-2012 04:17 PM
