GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
09-30-2022, 06:44 AM | #29 |
Drives: 2018 BRZ
That seems fine at that level... you are probably not the first to do this, but I'd be curious to know what DOES happen if it is way overfilled.
09-30-2022, 07:00 AM | #30 | |
The big one is that if there is too much in the pan then it will make contact with moving parts that is shouldn't. This will aerate it and create bubbles (thousands of little bubbles) and since the system is not supposed to have bubbles it can cause pressure and pump issues. The other isn't as scary but can be super messy. The system is only made to holds X amount of oil. If you try to run it with Y amount the oil IS going to come out someplace. The aeration makes this even worse since it allows the oil to pass through places it normally can't. If you are lucky it will come out on the outside of the engine. Worse case it will push past rings and seals and end up inside the engine in places where it is not supposed to be. I had a buddy once that over filled filled his Celica by 3 quarts. After a couple of miles it started to smoke like hell and then just quit. We drained the oil but when we pulled the plugs they were literally dripping in oil. No permanent damage was done though. Now, this is in the case of extreme overfill. The OP here is fine and like some said they will add an extra quart or so on purpose.
The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (09-30-2022) |
09-30-2022, 09:00 AM | #31 |
Drives: 2017 BRZ PP, 2004 WRX
If anything, that's pretty much exactly where you want to be on the dipstick from what I can tell. You do want to be at or just over that top hole enough that oil fills through it. This is "full" and the lower one is "low". I almost consider anywhere in between low in my head at least. There's a range, but you shouldn't be keeping it in the middle of the two dots. The engine won't explode if it's there, but you want it full at all times due to consumption, hard cornering, etc.
OP, yours looks right on the money. I run mine in both my BRZ and WRX right at that level. I have for years.
The Following 2 Users Say Thank You to cmiovino For This Useful Post: | soundman98 (09-30-2022), Tcoat (09-30-2022) |
10-01-2022, 12:01 AM | #32 |
ProCrastinationConsultant
it was mentioned earlier, but worth repeating:
there's the oil pan, then an upper oil pan, then the motor. so 'overfilled' in the lower oil pan still is under the upper part. it'd take a lot more than a quart to hit high enough to get aerated oil, or into the cylinders. i would guess at least a total of 3-4 quarts more, but no one's really tried it yet...
The Following User Says Thank You to soundman98 For This Useful Post: | x808drifter (10-01-2022) |
10-01-2022, 02:33 PM | #33 | |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
The Following User Says Thank You to 2020BRZtS For This Useful Post: | soundman98 (10-01-2022) |
Similar Threads | ||||
Rookie in need of suggestions! Please help. | Artxjr | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 03-01-2019 03:51 PM |
Subaru ROOKIE | BRZParee2019 | BRZ First-Gen (2012+) -- General Topics | 29 | 10-15-2018 11:40 AM |
Spacers rookie mistake | Impureclient | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 09-03-2016 01:55 PM |
Help out a rookie? | Outride | Forced Induction | 37 | 02-04-2015 01:04 PM |
Adventures of a rookie in Autocross | djfuller | Tracking / Autocross / HPDE / Drifting | 9 | 04-01-2013 09:30 PM |
