Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > GR86 - Second Generation 86 > GR86 General Topics
GR86 General Topics General topics for the GR86 second-gen 86
Old 04-15-2021, 11:08 AM   #43
ls1ac
ls1ac's Avatar
I also did not like the second speedo either as it is skipping many numbers and holding for a very long time. The other difference between the old and new is the type of readout. the old were red led's and had a slower rate and were not darkening as quickly.
Old 04-15-2021, 03:02 PM   #44
timurrrr
timurrrr's Avatar
Drives: '17 BRZ with PP
Just because it doesn't skip doesn't mean it's accurate. Increases in velocity are not necessarily linear. If you go from 0 to 60MPH in 3 seconds that does not necessarily mean you pass through every xMPH in between 0 and 60MPH.
With a 60 Hz display (commodity) you can show every single mph number during a one second 0Ė60 launch.
That's way faster than even a Tesla Roadster.
Even in km/h you can show every single km/h number in a 1.7s 0-100 km/h launch.
you need to eat up cycles covering all the number between 0 and 10, so that by the time you show the 10, you have already accelerated past it, and the display is lagging.
Do the math and estimate what rate of acceleration is required to "lag" behind a 0...10 count?
I don't think anyone here specifically wants to see every single number during the acceleration.
I'm sure 10Ė20 Hz data refresh rate will be enough for everybody on this forum.
However, if at the same time you are using an analog gauge, it will appear to go through each phase out of necessity [...] Now mind you we may be talking microseconds differences here, but there is a difference and programming choice has to be made.
Are you sure there's no latency in how an analog gauge works?
Any sensor, whether analog or digital, will have a certain "response time",
and then the needle in the gauge also has some inertia.
We are indeed talking about micro- or milliseconds here, and honestly I don't
think there's enough evidence to say whether analog or digital is going to be
more responsive. When was the last time you've seen an analog gauge in
an F1 car? Those guys surely care about both precision and latency.
There's nothing particularly inferior about what you can see on digital gauges,
other than just mediocre software engineering in this particular implementation.
timurrrr is offline   Reply With Quote
The Following User Says Thank You to timurrrr For This Useful Post:
Blighty (04-16-2021)
Old 04-15-2021, 03:27 PM   #45
1st86 Driver!
I didn't intend to say there was no lag in an analog gauge, only that it can't "skip" numbers so it appears to show smooth measurement even though it may not be.
We are indeed talking about micro- or milliseconds here, and honestly I don't think there's enough evidence to say whether analog or digital is going to be more responsive.
My note was strictly about the programming of the digital display not comparing analog to digital.
There's nothing particularly inferior about what you can see on digital gauges, other than just mediocre software engineering in this particular implementation.
That was my point, its all down to the software, but that producing what appears to be a smooth increase in velocity on the speedometer does not mean it is any more accurate than the less smooth "skip number" method, and in the right circumstances could actually be less accurate.
Old 04-15-2021, 03:47 PM   #46
timurrrr
timurrrr's Avatar
... producing what appears to be a smooth increase in velocity on the speedometer does not mean it is any more accurate than the less smooth "skip number" method, and in the right circumstances could actually be less accurate.
That would be a correct point if the underlying data was only 2 Hz,
the digital display was already doing the best it could do,
and we were talking about artificial smoothing.
But as I mentioned above, the data from the sensor is transmitted digitally at 50 Hz.
As this data is used by the ESC and ABS systems, I'm sure it's pretty high resolution both when it comes to timing and readings.
Based on a lot of data I collected at the track, it is definitely good enough to be displayed at 10+ Hz.
So they could totally avoid skipping numbers without introducing any artificial delays due to smoothing.
Dadhawk (04-15-2021)
Old 04-16-2021, 02:55 PM   #47
Dake
Based on GPS data, my digital speedo is consistently 1 mph fast and my analogue is about 2 fast (GPS says I'm going slower than car indicates), so "eh". Even when I'm flying I'm held to +/- 5 kts. Anything closer than that is showing off
What I'm saying is: I've yet to hear why this refresh rate matters in any remotely practical way.
Dake is offline   Reply With Quote
The Following 2 Users Say Thank You to Dake For This Useful Post:
Dadhawk (04-16-2021), Transport3r (04-16-2021)
Old 04-16-2021, 04:05 PM   #48
1st86 Driver!
Originally Posted by Dake View Post
Based on GPS data, my digital speedo is consistently 1 mph fast and my analogue is about 2 fast (GPS says I'm going slower than car indicates), so "eh". Even when I'm flying I'm held to +/- 5 kts. Anything closer than that is showing off .
That's about normal.
US regulations require the speedo to be accurate to within +- 5 MPH at 50MPH. However, UK and some other countries say the speedometer cannot show you going slower than your actual speed.
Because of this most cars have a bias where your speed is under-reported.
Old 04-16-2021, 04:15 PM   #49
timurrrr
timurrrr's Avatar
Based on GPS data, my digital speedo is consistently 1 mph fast [...] I've yet to hear why this refresh rate matters in any remotely practical way.
As long as it is consistently off (based on my experiments, it is consisten), it can still be used as a pretty good reference when track driving.
soundman98 (04-16-2021)
Old 04-17-2021, 09:33 AM   #50
ermax
ermax's Avatar
Drives: 2013 FR-S 6MT Raven
This has probably already been said but the current analog gauge is actually digital and driven off the same CANbus data that the new gauge will be. If anything I would think the new gauge would have less lag because it isnít physically moving a needle.
The Following 2 Users Say Thank You to ermax For This Useful Post:
soundman98 (04-17-2021), timurrrr (04-18-2021)
Old 04-17-2021, 10:21 AM   #51
Kronk
Drives: Planning for GR86
If you look Here and zoom in, you can see a slow update of the instant speed, with no needle.
Hoping this is a pre-production version...
Kronk is offline   Reply With Quote
Old 04-17-2021, 10:44 AM   #52
Transport3r
Drives: -
Sounds like youíll have to look for a different car that has the exact digital speedo smoothing rate you want. Good luck.
Transport3r is offline   Reply With Quote
The Following 5 Users Say Thank You to Transport3r For This Useful Post:
Blighty (04-17-2021), NoHaveMSG (04-17-2021), Red-86 (04-18-2021), soundman98 (04-17-2021), Sport-Tech (04-17-2021)
Old 04-17-2021, 11:00 AM   #53
soundman98
threadwrecker
soundman98's Avatar
Drives: '14 brz limited
at that rate, it'd be easier to just run your own speedo cable off the drive shaft. every MFG is moving to canbus instrumentation because it's easier to implement, and allows them to run their own custom variation of code to protect odometer data. gauge refresh rate is an afterthought.
my '14 brz limited "the return to normal" (or is it?)
led mods-10%(planning/designing/sitting on hands)audio mods-99%(done is never done)
hidplanet build log
Old 04-17-2021, 11:26 AM   #54
Kronk
Itís just a thread on a cons to pass the time waiting for more news.
Take it easy.
Iím still interested in buying it.
Old 04-17-2021, 01:55 PM   #55
ermax
ermax's Avatar
Oh sorry I was talking about the tach when the thread title says speedo. My mind said tach because who on earth would care about anything other than the tach.
The Following User Says Thank You to ermax For This Useful Post:
Old 04-18-2021, 07:54 AM   #56
Blighty
Drives: Pegasus White Toyota 86 GTS
Erm, not likely.
Its done on purpose (the rest of the display is real-time) to make it easier to read.
I can tell you that its very effective and not uncomfortable in practice - they strike a good balance.
Originally Posted by Jordanwolf View Post
Yeah, da fast lane. Stay in the slow lane, you holding up traffic, and stay out of da figure eight, thats only for the real 'Gs'.
Blighty is offline   Reply With Quote
Search this Thread:
Advanced Search
In-dash digital speedometer vaer Electronics | Audio | NAV | Infotainment 4 04-14-2020 10:19 AM
Does the BRZ get same refresh? snezze21 BRZ First-Gen (2012+) -- General Topics 74 03-24-2016 01:51 PM
Convert the digital speedometer from Kmh to MPH? Jastation Electronics | Audio | NAV | Infotainment 10 09-28-2015 05:46 AM
Digital speedometer in base GT86? rhysmcinerney Electronics | Audio | NAV | Infotainment 25 01-22-2014 06:18 PM
Fast car Fast driver vinyl decal I need help francosolracer Cosmetic Modification (Interior/Exterior/Lighting) 18 10-20-2012 03:43 AM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
