Old 04-10-2021, 08:37 PM   #1
Jasper
Jasper's Avatar
Drives: 2023 GR86
AOS/Catch Can Needed for Supercharger Support Mod?
I know this is one of the most debated questions in the 86 community.
I ask this question because CSG Mike brings up the point of an AOS/Catch Can not being necessary due to the differing design of FA20 vs the traditional boxer motors boxer-heads like to focus on (mainly the EJ). So what do the other 86 owners think? I'd like to hear from everyone who has a strong opinion!
Jasper is offline   Reply With Quote
Old 04-10-2021, 09:31 PM   #2
Ashikabi
Ashikabi's Avatar
I trust Mike's judgement. But it's not a bad idea. I had a catch can buy never had anything in it though
Sent from my ONEPLUS A5010 using Tapatalk
Old 04-10-2021, 10:40 PM   #3
Jasper
Jasper's Avatar
Drives: 2023 GR86
Very interesting... Were you boosted or NA?
Old 04-10-2021, 10:41 PM   #4
Ashikabi
Ashikabi's Avatar
NA
Old 04-10-2021, 10:42 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I think it catches vapor. Mine caught some if I was hammering on it a lot. Not certain how much "catching" it helps though. I think it's nice to be able see monitor how much you're getting and not recirculate it
Jasper (04-10-2021)
Old 04-10-2021, 10:58 PM   #6
Ashikabi
Ashikabi's Avatar
A catch can shouldn't recirculate anything but air. That's what it's for. Vapor goes in, air comes out(presumably). I beat on mine pretty good and never got anything. After my LS1 swap I caught shit tons. But the LS1 was really bad about sucking oil through the PCV. Now that I switched to the LS6 valley cover, I'm not hardly catching anything
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
DarkPira7e (04-10-2021), Jasper (04-11-2021)
Old 04-10-2021, 11:31 PM   #7
DarkPira7e
DarkPira7e's Avatar
I meant vs not having one at all, haha. What I was wasn't very clear, I'm overtired
Old 04-11-2021, 10:04 AM   #8
sam69
Drives: GT 86
I would Defiantly put a catch can in as it cost us a new motor when tracking the car due to oil and the result was 4 bent rods !
sam69 is offline   Reply With Quote
Old 04-11-2021, 10:42 AM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
How the heck did that happen? Was it pushing enough oil to hydraulic lock the engine?
NoHaveMSG is online now   Reply With Quote
Old 04-11-2021, 10:49 AM   #10
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
As I said in the other thread.
A catch can is used to monitor engine health.
And as Mike said, you probably don't need one unless pushing the engine hard.
If its catching alot of fluid something is wrong with the engine.
Do you feel the engine is or might in the future have blowby/pcv problems, get one.
Get one if you are going to be pushing the engine hard alot. (Track Use)
Or get one just because you want the peace of mind.
Otherwise on a daily, don't bother.
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
bfrank1972 (04-12-2021), Jasper (04-11-2021)
Old 04-12-2021, 07:23 AM   #11
sam69
Drives: GT 86
It got enough oil through the pcv into the supercharger hence then the engine which bent the rods .
The cornering G forces were very high and yes pushing hard but we did manage to drive/nurse it home from the track.
The Following User Says Thank You to sam69 For This Useful Post:
Jasper (04-12-2021)
Old 04-12-2021, 10:37 AM   #12
bfrank1972
Drives: 2013 FR-S Argento
This. Depends on your setup and driving. If you're running super high boost, if your motor is tired/has a lot of blow-boy, if you track hard and frequently, it's a good safety mechanism and good indicator of how your motor is holding compression. If your motor is healthy, and you're running something like an 8 or 9 psi unit (especially a centrifugal unit), you probably don't need it unless you suspect your motor is tired (high mileage, uses oil). I have catch can on both PCV and CCV, PCV doesn't collect hardly anything, and CCV absolutely nothing. I'm running a Vortech unit that peaks around 11psi. Some motors naturally use more oil than others, so if you want to be safe, just spend a couple hundred bucks and get one for the PCV side.
Old 04-12-2021, 10:45 AM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Me thinks there was another extenuating circumstance. I would 100% run an AOS boosted on track, but I can't imagine it pushing that much fluid to bend a rod let alone multiple rods.
Old 04-12-2021, 01:46 PM   #14
Ashikabi
Ashikabi's Avatar
I think he's saying there was so much oil in the intake air that it reduced octane enough to create so much knock that the rods bent. Something along those lines. I don't believe a hydraulic force is being blamed
The Following User Says Thank You to Ashikabi For This Useful Post:
Jasper (04-12-2021)
aos, catch can, forced induction, supercharger, supporting mods
Radium Dual Catch Can with Jackson Racing Supercharger pabisz23 Forced Induction 3 07-10-2020 09:25 AM
Supercharger and catch cans sqd Forced Induction 3 04-15-2019 09:18 AM
Catch can for supercharger by Jon Bond Performance sroby Engine, Exhaust, Bolt-Ons 0 07-11-2018 10:01 PM
BRZ Supercharger Motorhead info needed Saifalkhalifa1 FR-S / BRZ vs.... 1 08-07-2016 02:41 PM
Anybody catch this? Stout Racing SCCA Scion FR-S w/ TRD Supercharger at SEMA BK025 Scion FR-S / Toyota 86 GT86 General Forum 68 01-30-2013 03:29 AM
