06-02-2018, 03:26 PM | #533 | |
Drives: '15 BRZ RA
In general some European manufacturers are trying to increase again the spring rates, but the big question is how to not sacrifice the street performance and comfort. For example, Sachs is testing currently a new technology of springs that will have +1kg f/r (close to 5k). They'll use a technology called SASC (Side Action Spring by Chuhatsu) that distributes better the forces and provides same comfort even with higher spring rates. On the left a conventional spring design and on the right the SASC spring: The main issue was that such kind of springs were designed for fixed dampers and they had to test how well works on a height adjustable coilover and in particular on the suspension geometry of the 86/BRZ. It looks that the first tests in Japan were passed successfully and now the prototype is being tested on the road and a race track in Germany. I think that their performance coilover product will be offered either with the original springs or the new ones. Let's see ... |
The Following User Says Thank You to nikitopo For This Useful Post: | krayzie (08-21-2018) |
06-02-2018, 06:48 PM | #534 |
Drives: 2018 Subaru BRZ
Agreed! The suspension is like a hybrid. Soft and compliant over hard bumps but firm and planted through the twisties
On my fourth 86... and everything in between
06-02-2018, 07:03 PM | #535 |
Drives: GT86 Cosworth
They have their limits but generally the high speed damping is fantastic if you don't bottom out.
Nice smooth absorption without multiple cycles of ripple. Complete opposite to my BMW X3 M sport lol Sent from my SM-G935F using Tapatalk |
12-02-2018, 04:24 PM | #536 |
Drives: BRZ 2018
Just a quick question for old Ohlins owners, how often you rebuild/service your coilovers, Ohlins suggests 30.000kms/3 years but I don't know how real are those numbers, I mean do they need more often due to track use or increased dust or something else?
Not that 30.000kms are quite often but I drive more than 15K per year my BRZ so I'll need every two years service (car on the ramps)! |
12-08-2018, 03:34 PM | #537 |
Drives: Car
The latest mp21 comes with heavier springs. I ordered the mp20 kit and had intentions to change springs after winter but was pleasantly surprised that I recieved the mp21 with 5k front and rear. The manual still had preload settings for the 4k/3k setup so I had to play around with preload to get it setup right... It was pretty stinkbug with initial recommended preload. New spring part numbers are 48010-11/50 front and rear.
12-08-2018, 07:13 PM | #538 | |
Drives: BRZ 2018
What preload you ended with? |
12-08-2018, 07:43 PM | #539 |
Drives: Car
Instructions called for 27mm front, 38mm rear. I left the front alone and ended up at 20mm preload rear.
12-09-2018, 12:19 AM | #540 |
Drives: Car
Those were just settings to make it look right. I'll be playing with settings to make it feel right once some more ice melts off.
12-09-2018, 03:52 AM | #541 | |
Drives: BRZ 2018
What is the distance from center of wheel to the arch front and rear before and after installation, it should have lowered the car 20mm all around, distance from height adjuster to spring preload adjuster 39mm front and 25mm rear not 27mm front and 38mm rear as you say: "The standard spring preload is 20 mm from a free length of 200 mm, giving 180 mm installed length, see fig 5" https://world.ohlins.com/app/uploads...MI_SUSMP21.pdf By the way forward incline has as result more weight transfer rear and make the car more oversteering while 20mm lowering all around brings center of gravity closer to roll center reducing weight transfer on corners! |
The Following User Says Thank You to JIM THEO For This Useful Post: | remhex (12-11-2018) |
12-09-2018, 01:40 PM | #542 |
Drives: Car
That looks like the manual that SHOULD have come with my coilovers. My instructions were for the lower rate springs. I am measuring preload by snugging the adjustment to the spring then compressing and measuring. It currently has about the same rake as stock, just lower. Thanks for the link, it looks like 2-30mm is adjustment range for preload.
12-09-2018, 01:44 PM | #543 |
Drives: Car
I'll probly end up just about maxing the preload for more bump travel. I don't think increasing preload affects travel unless its cranked to the point of spring bind.
12-09-2018, 05:44 PM | #544 |
Drives: BRZ 2018
Am I miss something, how max preload increases bump, installed spring length will be less at 170mm so it will be more compressed already.
12-09-2018, 06:38 PM | #545 |
Drives: Car
More preload increases bump travel unless you go too much and bind the coil. Travel isn't limited by spring length unless you tighten the preload too much. The shock will limit travel before the spring does. It increases bump travel by pretty much increasing static ride height so the shock can do more work before bottoming out.
12-10-2018, 01:53 AM | #546 |
Drives: Car
I ended up with 30 mm preload in the rear and went down to 24mm in the front.
Last edited by remhex; 12-10-2018 at 02:15 AM. Reason: Bad review...Need to eliminate variables 1st. |
Similar Threads | ||||
ohlins road and track shock absorbers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 11-11-2014 05:00 AM |
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! | Circuit Motorsports | Brakes, Suspension, Chassis | 90 | 08-16-2013 12:39 PM |
Ohlins Road & Track Coilovers - IN STOCK!!! | RallySport Direct | Brakes, Suspension, Chassis | 7 | 05-28-2013 04:11 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
Ohlins Road & Track Subaru BRZ and Scion FR-S | HP Autowerks | Brakes, Suspension, Chassis | 0 | 04-24-2013 03:27 PM |
