GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
07-14-2022, 02:35 PM | #15 |
My 2022 brz rear sway bar bracket will be here tomorrow. Once my car stops being so broken down I’ll attempt to install and post feedback
07-14-2022, 04:15 PM | #16 |
Drives: 22 BRZ limited
Take some good pictures of it please.
08-06-2022, 02:45 PM | #17 |
Just wanted to mention that I have successfully put the 2022 bar mount on my 2013. The biggest difference by far, as mentioned, is how quickly the bar responds to steering input. I took the car on a backroad last night and found that I needed to start my steering input later than expected, and once the car settled on fully on its left or right side, the car would turn very hard. Overall, this is a pretty awesome upgrade for ~$80. Extremely easy to install too, once the stock mounts are cut out of course.
I would say it should come like this from the factory, but it already does! |
The Following 3 Users Say Thank You to norcalpb For This Useful Post: |
08-08-2022, 10:17 AM | #18 |
Drives: '20 Tundra, '84 SpecE30
Can anyone share if the difference in ride quality between GR86 and BRZ is that significant? Concerned about Racecomp Engineering's post discussing the competence the BRZ might have over bumps vs the GR86, as most of my driving is on pot-holed bumpy roads.
I understand they're likely talking about stability on track after hitting curbs and such, but curious if the difference while street driving will be noticeable? The BRZ has a few things I like: the aluminum hubs (I live in the rustbelt), revised suspension that many claim gives a better ride, world rally blue paint. But the big things the GR86 has that I like are some aesthetic choices I prefer, the digital oil temp readout (vs BRZ bar slider), supposedly more propensity for oversteer, and the free track day. |
The Following User Says Thank You to raisingAnarchy For This Useful Post: | PBR (03-04-2023) |
03-03-2023, 02:10 AM | #19 |
Drives: '04 STi, '12 Mazda 3 Hatch
This is what I'm thinking but for the rear bar I'd like to keep Subaru's mounting but run Toyota's spring rate. Who makes a bar that feels like the GR's 15mm, while fitting the Subaru's mounts?
03-03-2023, 06:18 AM | #20 |
Why not just run the stock Toyota/Subaru 15mm bar? It fits like stock.
The Following User Says Thank You to dragoontwo For This Useful Post: | DocWalt (03-08-2023) |
03-03-2023, 08:27 AM | #21 | |
Drives: '23 BRZ Limited
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
03-03-2023, 10:12 AM | #22 |
I thought the stock BRZ bar is 14mm and the stock GR86 bar attaches differently. At first I was going to get the GR86 bar and mount hardware but I've been convinced that the BRZ mounting is better.
03-03-2023, 10:27 AM | #23 |
What I meant was a 1st gen BRZ 15mm rear bar or the GR rear bar and mount it like the stock bar. They fit just like the 14mm stock bar.
03-04-2023, 01:28 AM | #24 |
So even though the bushing connects to the car differently on the BRZ vs GR86 the bars are the same shape and the bushings are in the same locations?
The Following User Says Thank You to Lelandjt For This Useful Post: | DocWalt (03-08-2023) |
03-04-2023, 01:39 AM | #25 | |
Drives: Toyota 86
The same bar mounted using both methods.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller HKS GT EL header, 17MY intake manifold */ |
03-06-2023, 07:11 AM | #26 |
Here's a 2020 15mm sway bar laid over a 2022 14mm bar.
The Following 2 Users Say Thank You to dragoontwo For This Useful Post: | DocWalt (03-08-2023), Ohio Enthusiast (03-06-2023) |
03-06-2023, 12:59 PM | #27 |
Lovely. I thought getting GR suspension on my BRZ was going to be a production but looks like I only need to buy the rear bar & springs and the bar swap is something I can do in less than an hour. Including the bumper and paint my conversion should cost <$1000. Combined with the BRZ purchased at MSRP that's less than a GR86 would have cost me and I have the assurance that I'll have it by summer.
What's everyone's favorite online Toyota parts source? Last edited by Lelandjt; 03-06-2023 at 01:13 PM. |
03-07-2023, 08:36 PM | #28 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
Another thing you can notice, and as a few people have eluded to, the steering response is faster on the BRZ, while again its a small change, its actually much more than the tiny added stiffness from the front bar compared to the GR86 should in theory provide. As others have pointed out this is likely due to how the rear bar connects directly to the chassis, allowing them to make the suspension softer through vertical deflection and twist of the smaller diameter bar, but actually improves the moment of inertia because it laterally acts faster (well almost instantly) than through the subframe/bushing. That said if I was making the perfect twin, I would certainly have the suspension arrangement from the BRZ and the front bumper from the GR86 (but with the cheap little under spoiler part the BRZ front has - that thing is taking up all of my driveway scratches and is cheap to replace!) - All down to personal preference. However, all these things pale into comparison to actually just owning either twin, its a wonderful platform. Just get one, any of them. I'd even include the old one in that conversation as well - just great cars designed really well for driver enjoyment. Last edited by Blighty; 03-23-2023 at 07:51 AM. |
The Following 2 Users Say Thank You to Blighty For This Useful Post: | diga (03-08-2023), raisingAnarchy (03-08-2023) |
Similar Threads | ||||
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport | Blighty | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 37 | 07-18-2021 03:38 PM |
WRX swaybar | horrorbiz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 03-14-2016 04:48 PM |
FS (MI): Front strano swaybar, rear wrx swaybar | Aznsky | Brakes, Suspension, Chassis | 4 | 11-04-2014 02:09 PM |
Swaybar Noise? | dizzario | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 06-25-2014 11:46 PM |
REVIEW | DC Sports rear subframe brace / rear subframe lateral brace | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 04-10-2014 08:59 PM |
