Old 12-30-2020, 04:21 PM   #1
rns294
Drives: 13 BRZ
Rear Sway Bar Bracket Bolt Size
Anyone know what size the rear sway bar bracket bolts are approximately? I know they are part number SU003-00015 but can't find an actual size. I'm looking for the ones that are circles in this image:
I made the same mistake as
. So now I need to replace the bolts and fit some additional nuts behind them. I'd like to get as close as possible to the original OE size bolt when I replace it.
rns294 is offline   Reply With Quote
Old 12-30-2020, 04:36 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I believe they are 8X1.25, probably about 25mm long.
rns294 (12-31-2020)
Old 12-30-2020, 05:27 PM   #3
EndlessAzure
EndlessAzure's Avatar
What size socket fits on the bolt head and are they OE? @rns294
You can just get something roughly the right length from the hardware store to get you going and drop by the dealership and get actual replacements later
EndlessAzure is offline   Reply With Quote
Old 12-31-2020, 09:34 AM   #4
rns294
Drives: 13 BRZ
A 12mm fits the OE bolt. I looked up the size of an M8x1.25 and I believe that is the correct size or at least very close to it.
I was planning to just get a replacement from a hardware store but I wanted to get a bolt that was roughly the same size/pitch for the sake of strength.
Old 12-31-2020, 09:49 AM   #5
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Whatever the size, make sure its 10.9 rated.
If MSG is correct these would work
https://www.amazon.com/M8-1-25x25-Me.../dp/B01GUEO53W
Old 12-31-2020, 10:31 AM   #6
Racecomp Engineering
www.boltdepot.com
good source for nuts/bolts/etc.
- andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
Capt Spaulding (12-31-2020), NoHaveMSG (12-31-2020), x808drifter (12-31-2020)
Old 12-31-2020, 03:35 PM   #7
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
You probably have some vestigial threads left in the original captive nut(s). Cleaning those out with a drill will make the reassembly easier.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 12-31-2020, 09:24 PM   #8
EndlessAzure
That's correct. JIS 12mm Head Bolts correspond to an M8x1.25 thread pitch. For the sake of a temporary replacement, get the highest grade strength bolt you can get from hardware store.
Order a direct replacement from Toyota/Subaru and that will get you what you want. It's a lot more work to sieve through the repair manual to pull the grade up.
010910200 Front sway bar Bolt size? Four_wheel_drifts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-12-2017 04:04 PM
Rear sway bar bracket bolts Somerandom18 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-10-2017 11:03 AM
Tow hook Rear/Front bolt size?? Scion FR-S pnaysh0rty Cosmetic Modification (Interior/Exterior/Lighting) 25 04-28-2016 09:26 PM
Rear Sway Bar Stabilizer Bracket Bolt replacement? Books Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-19-2012 04:55 PM
AMT rear sway bar bracket adamturbo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-13-2012 12:06 PM
Copyright ©2000 - 2022, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
