04-11-2021, 05:56 PM | #57 | |
Drives: 17 Asphalt 86
I am on the stock primacy wheel tire setup while waiting to install new rubber on other wheels. |
The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | Capt Spaulding (04-12-2021), Thefalls (04-12-2021) |
04-12-2021, 07:18 AM | #58 | |
Drives: Corolla GT
04-12-2021, 02:33 PM | #59 |
Persona Non Grata
Drives: '15 BRZ (WRB)
@RToyo86
That, my friend, was perfect. Thanks a million. PS: I rather like the look of those wheels.
Slow is smooth, and smooth is fast
04-12-2021, 02:53 PM | #60 | |
I find it helps with back wheel nuts and calipers. |
03-08-2022, 03:37 AM | #61 |
Drives: BRZ 2018
I bring back this old thread just to ask again if someone has experience with the B6 and the OEM tS >18 springs
03-10-2022, 02:09 PM | #62 | |
Drives: 2019 BRZ Sport-Tech RS
Body control is far superior to the stock springs and Sachs dampers. The ride is a bit firmer (passengers will notice), but not harsh or crashy. |
03-11-2022, 06:43 AM | #63 | |
Drives: BRZ 2018
By the way how much miles the standard tS Sachs withstand, I already have 50.000kms and they work fine |
03-11-2022, 08:09 AM | #64 |
Drives: 2014 GT86
B6 for me were slightly, but less comfortable then stock (MY2013 GT86) suspension. At least for smaller road imperfections/rougher roads. Due a bit more firmness car, as some may say, is "more composed", and on track when pushed a bit better, but i wouldn't consider them if comfort for DD is the goal.
03-11-2022, 08:42 AM | #65 | |
Drives: '23 BRZ
The Following User Says Thank You to ZDan For This Useful Post: | CSG Mike (03-11-2022) |
03-11-2022, 09:22 AM | #66 |
In general I've found the Bilsteins to be a good bit more comfortable on bigger bumps and potholes. They have just slightly more compression damping, and a little less high speed rebound (depending on which year OEM we're talking about). More digressive. Plenty more rear rebound which does impact ride quality slightly but sure is helpful with aftermarket springs. Adjustable would be nice to tune that a little bit but overall they have a feel that is more reassuring (to put it one way) on the terrible roads I drive on.
Just wish they weren't always backordered. - Andrew |
03-11-2022, 10:25 AM | #67 |
Drives: 2020 Toyota GT86
Is there a better combination (B6 w/OEM springs, B6 w/any particular aftermarket spring, etc) that rides better than the base (non-PP) OEM setup?
I track the car a couple of times a year, but since that is just for fun, keeping the wife happy and willing to ride in the car is more important than track use. Admittedly though it is not just her as I'm getting into the old fart age range and have to admit I care about a more compliant ride than I used to!
This post sent using 100% recycled electrons.
03-11-2022, 01:02 PM | #68 |
TRACKBREAD
I don’t think you’ll find anything that rides better than the 2017-2020 base suspension. Everything else has more damping and/or higher spring rates.
The Following 5 Users Say Thank You to Yoshoobaroo For This Useful Post: | bucketfoot (03-11-2022), churchx (03-12-2022), kevaughan (04-11-2022), marco_mc22 (03-11-2022), Pat (03-11-2022) |
03-11-2022, 02:13 PM | #69 | |
Drives: 2023 BRZ
Director of Rocky Mountain 86CUP
03-11-2022, 11:10 PM | #70 | |
Drives: Corolla GT
The likes of KYB Extage or Cusco Touring A? You can use lowering springs with the Cuscos ....with the KYBs I dont know yet. But they are both adjustable for rebound. And you still use your oem topmounts to minimize NVH. |
Similar Threads | ||||
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 | shattered_memory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 01-04-2017 11:22 AM |
AVCS Explained | Rennmeister | Engine, Exhaust, Transmission | 3 | 03-15-2016 03:12 AM |
STX Bilstein Double Adjustable Package - Bilstein PSS with Dual Bleed Shafts | FRSport.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 02-25-2016 12:50 PM |
Ok, who has stories that can't be explained? | husker741 | Off-Topic Lounge [WARNING: NO POLITICS] | 143 | 11-26-2014 05:25 AM |
Part of the problem explained. | Suberman | CANADA | 95 | 01-28-2014 01:26 PM |
