Old 01-15-2018, 04:12 PM   #1
xenarc
xenarc's Avatar
Drives: 2017 SUBARU BRZ
FOG LIGHT SWITCH FOR 2017 BRZ
I recently installed the Winjet fog light kit on my BRZ Premium and I noticed all the OEM wiring harness is already on the car. I went ahead and used the winjet wiring and switch. Do any of you know if I can use the winjet switch with the OEM harness? I tried taping into the black & yellow/ white & grey wires using the winjet switch but NO CIGAR.
I also followed the following video:
Here are pictures of the wiring. The winjet is red, yellow and black.
OEM fog light wiring(as shown on video):
xenarc is offline   Reply With Quote
Old 01-15-2018, 04:28 PM   #2
xenarc
xenarc's Avatar
Maybe I just need a 2 pin switch like shown on the video ???
Old 05-10-2019, 12:35 AM   #3
BRZ_Alan
Drives: 2017 BRZ
did you solve this issue? i got the same fog lights
BRZ_Alan is offline   Reply With Quote
Old 09-05-2020, 03:01 AM   #4
ChrisV11
Drives: 2017 Toyota 86 (Black)
So I got a kit off of eBay. I have a 2017 Toyota 86 and luckily the pre wiring fits they headlights... I needed some hardware to mount, but that’s not a big problem. Anyway the two wires in the video are pretty much the hot and neutral. The other wires may be for dimming (I really don’t know). But a 2 way switch should work, just get some wire taps like the video and hook it up to your 2 way switch of choice. I hope that helps.
ChrisV11 is offline   Reply With Quote
Old 09-05-2020, 02:19 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
You should be able to get a switch off ebay. I did from another toyota.
Do not just use a 2 pole switch. Half of the wires are for button illumination, the other half are for fog light power/control. A 2 pole switch will short the illumination portion.
Did you check that the fuses exist in either fuse box?
So where will the fog light switch go... Asphalt Scion FR-S / Toyota 86 GT86 General Forum 19 04-08-2019 07:09 PM
Frs stalk with fog light switch chriscross_tnt Audio/Visual, Electronics, Infotainment, NAV 1 04-09-2015 06:36 PM
FS OEM Light switch/stalk Trashed675 Interior Parts (Incl. Lighting) 0 04-07-2015 03:31 PM
Where is your Fog light switch? SillySaxon BRZ First-Gen (2012+) -- General Topics 10 07-11-2014 10:51 AM
How to wire a fog light switch to Diode Dynamics fog light kit *SOLVED tiz22 Cosmetic Modification (Interior/Exterior/Lighting) 6 06-04-2014 01:16 AM
