GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#15 |
May be worth while in that case then.
#16 | |
Drives: GR86 RC
If there ever was a doubt. I cross referenced the new GR86 FLCA with the previous gen and its the same. https://parts.toyota.com/p/Toyota_20...U00310055.html https://parts.toyota.com/p/Toyota_20...U00310056.html So i guess the difference in part number for the 2022 brz vs the previous gen is due only to the ball joint being likely longer (and you cant buy that ball joint separately). So i guess the question is whether the ball joint for the usual aftermarket FLCA fits the new alu knuckle. Anyone tried that? EDIT: I emailed SPL and this is their reply: We did redesign our ball joint stud for the FLCA FRS to fit the new 2022 BRZ, our FLCA FRS will fit your 2022 BRZ with alu knuckle! Last edited by Jianlun; 09-09-2022 at 09:56 PM. |
#18 |
Drives: BRZ 2018
Reducing front unsprung weight by 16lb is definitely worth the money and effort. I achieved similar weight saving by using a super-light wheel (Volks Racing TE-37 at 12.5lb each), 2-piece brake rotor (saving about 6lb each), light weight lug nuts, and hollow front sway bar.
The effect is noticeably positive on my 2018 BRZ. Of course the ride is much less jarring, and the steering feedback also improves. Now I can focus on the road ahead, rather than looking out for all the rough patch/pot hole to avoid. I am now looking at replacing the front knuckle for another 3lb savings per corner. |
The Following User Says Thank You to Yoniyama For This Useful Post: | Jianlun (09-10-2022) |
#19 |
Drives: 2015 Brz
not trying to answer the question. it's great you can import RC trim from Japan, just wondering do you get air conditioning from RC trim this gen? I remember the 1st gen RC deleted basically everything like AC/speaker/sound deadening material/Catback exhaust etc. it's the lightest stock gr86 already, but the price increased by 800k yen IIRC
#20 | |
Drives: GR86 RC
1. No Active sound 2. No head unit 3. Lesser underfloor sound insulation (havent found out which/where is less) 4. 16x6.5 steelies and 205/55r16 5. No trunk door liner and no trunk light. 6. No floor mats 7. Fabric seats, PVC for instrument cluster top and door cards. Leather steering and handbrake lever and gear knob. 8. 2 speakers (dashboard ones) only. 9. No wheel jacks 10. No cover on engine (the one that says D-4S Boxer). 11. No vanity mirror light, no puddle light. 12. No Cruise Control |
The Following User Says Thank You to Jianlun For This Useful Post: | Rainy (09-11-2022) |
#21 | |
LMGTFY
Drives: 13 FRS, 91 Miata
WTF are the speakers for then? |
#22 | |
Drives: '23 BRZ Limited
So potentially as much 52lbs out of is pretty nice.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
#23 |
Drives: GR86 RC
Basically allows you to put whatever aftmkt HU.
#24 |
Drives: GR86 RC
Just to finish the conversation on aftmkt FLCA. Emailed most to check on fitment and these are some replies:
SPL FLCA https://www.splparts.com/products/fr...-brz-ft86.html They replied saying they redesigned/re-specced the ball join to cater for the Alu knuckle. Cusco FLCA. https://www.rhdjapan.com/cusco-wide-...6-zn6-zn8.html Generic part for all gens and no report of compatibility (nor non-compatibility) with alu hub but marketed to be compatible. P2M FLCA. https://www.phase2motortrend.com/pro...lca1086-hc.htm they replied saying they will check fitment with the alu knuckle, cannot confirm at this time. Hardrace FLCA. https://www.hardracesuspension.com.a...er-control-arm looks like new part number specific for 2022 BRZ. Megan racing FLCA https:// meganracing.com/suspension/type-suspension-arms/scion-subaru-arms/mrs-sc-0624-ii usd605 https://meganracing.com/suspension/t...-sc-0624-v2-ii Looks like new part number specific for 2022 BRZ. RacerX FLCA https://racerxfabrication.com/frs-br...r-control-arms they replied saying they will check fitment with the alu knuckle, cannot confirm at this time |
The Following User Says Thank You to Jianlun For This Useful Post: | Jdmjunkie (09-12-2022) |
#25 |
Drives: 2012 Toyota 86 GT
That's great that the SPL FLCA's would fit the alu knuckles, but would the stock FLCA from the '22 fit an FR-S? Surely the SPL's would be lighter, but not sure about the ride comfort with rose-joints, would prefer bushes.
#26 |
Also, in your front caliper weight for OEM, it does not look like you're including the weight of the caliper bracket.
https://www.ft86club.com/forums/showthread.php?t=7881 - Andrew |
#27 | |
Drives: GR86 RC
Assuming there is a 20% reduction unsprung weight in the front but none in the rear, would the balance of the car change? Eg the front tyres are able to "follow" the road surface better and doesnt "fly off" the small bumps on the road, does this give more front grip leading to better turn in, higher braking/lock up headroom, maybe a more oversteery car on steady state sweepers cos the front end ultimate grip is more than the rear? Also, I been reading on this topic a lot more the past few days and it does seem there is all good no bad and thus no such thing as too much unsprung weight reduction. And moreover the metrics to look at is actually the unsprung to sprung ratio. And the 20% reduction is absolute weight actually only means 2% reduction in the unsprung:sprung ratio which is insignificant. Edit: just to complete the picture. Lightening potential for the rear limited to the RUCA. And i have the cusco one but more for camber fine tuning. No magical savings unlike the front. Stock RUCA 8lb. RacerX RUCA 4.1lb Cusco RUCA 5lb Last edited by Jianlun; 09-13-2022 at 10:15 PM. |
#28 |
LMGTFY
Weight Reduction!...On yourself. | spcmafia | Off-Topic Lounge [WARNING: NO POLITICS] | 223 | 01-16-2023 03:54 PM |
Low Dollar Brake Upgrade unsprung weight reduction | RuyGuy2 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 37 | 04-21-2020 11:58 PM |
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 12:38 PM |
Weight reduction in the front only | KevinBRZ | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 04-12-2013 01:25 AM |
the weight reduction of FR - S? | raiden8383 | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 11-30-2012 07:10 PM |
