Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
08-23-2021, 12:11 PM | #1 |
Drives: 2015 frs release series 1
Oil temps/pressure after installing blitz oil cooler
Hi all, I recently installed the blitz br oil cooler kit (https://www.blitz.co.jp/products/coo...cooler_br.html) and from what I can tell it seems like my oil pressure might be a bit high.
So far I have only done back and forth high way traveling. my oil temp stays at around 80 degrees C, and when I push the car it only gets as high as 92 degrees C. When driving at 2-2.5k rpm the oil pressure rests around 400-480kpa. At 3k-3.5k the pressure jumps up to 600-680kpa. Idle is 100 kpa, redline is about 850kpa. The pressure will go down at those rpms when I get the oil warmed up to 90 degrees, I don't think there is a problem with the system but I am wondering, are those pressure safe to drive at? Also, I am tracking the oil temp and pressure with the jdm trd oil pressure and oil temp sensor/gauges that I installed into the oil sandwich plate. Oil temp is being recorded before oil gets into the oil cooler, and oil pressure is being recorded on the top of the plate right under the oil filter (after oil goes through the cooler when thermostat plate is closed). I am also running royal purple engine oil. |
The Following User Says Thank You to Mortsgreb For This Useful Post: | jcw99 (08-23-2021) |
08-23-2021, 12:19 PM | #2 |
I wouldn't be concerned about high pressures. Those engines have some crazy pressures when the oil is cold and stuff. It's only a coven if it gets too low IMO. Especially since you're using a pre engineered cooler from a respectable company
Sent from my ONEPLUS A5010 using Tapatalk |
08-23-2021, 12:40 PM | #3 |
Drives: Crapcan
No way are those pressures are at operating temp. Those sound like cold pressures.
08-23-2021, 03:35 PM | #4 |
Drives: swp mt '14 brz premium
sound pretty normal to me
I converted some of your numbers to F and psi and they sound normal. My idle psi is 12.5 and yours is 14.5 psi-the 2 pound difference is due to your cooler.
08-24-2021, 11:55 AM | #5 |
Cool thanks for the help everyone!
Tags |
blitz, oil cooler, oil cooler kit, oil pressure, oil temperature |
Similar Threads | ||||
Engine Oil Temps after Oil Cooler | ryoma | Engine, Exhaust, Transmission | 31 | 03-23-2016 09:21 PM |
Great tips on oil temps, pressure, and weights for the track | stockysnail | Tracking / Autocross / HPDE / Drifting | 5 | 01-25-2016 06:17 PM |
HKS Oil Cooler Kit - Keep those oil temps down. - Photos | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 23 | 08-10-2015 03:08 PM |
Oil temps with JR SC and JR oil cooler | dp1 | Tracking / Autocross / HPDE / Drifting | 87 | 11-14-2014 12:35 AM |
