09-16-2014, 07:31 AM | #2507 | |
Drives: FR-S Firestorm 6MT
09-16-2014, 09:29 AM | #2508 | |
Drives: white gt86
I'm just concerned with the poke mostly, props to your set up btw I'm also thinking of running 17x7.5 fronts and 17x8.5 rears et42 for both (xd9s) as a mate has a set he's willing to sell to me. I would much rather be safe than sorry with the law over here. I have a set of 215/45/17 lying around, would they be alright to use for both front and rear? Sorry for all the noob questions |
09-16-2014, 09:43 AM | #2509 | |
Ideal size tire for those wheels would be 225/45R17 and 245/40R17. |
09-16-2014, 10:44 AM | #2510 |
Drives: frs
18"x9", +45 square with 245-35 18 on stock suspension (eventually lowered 1")?
09-16-2014, 10:55 AM | #2511 | |
You will need a +35 offset or 10mm spacers if you want to run these either stock or dropped on springs, but will fit with coilovers. I would still try getting something closer to a +35 to +38 offset. |
The Following User Says Thank You to Slick For This Useful Post: | twag4 (09-16-2014) |
09-17-2014, 12:34 PM | #2512 |
Drives: frs
Will I only have trouble on rear, or front too? As far as suspension, maybe coil overs, not looking for a large drop as I hit now with the large drainage they build into streets here in the Deep South if I'm not careful.
09-17-2014, 12:50 PM | #2513 |
You should be clear on the rears but I would still run a spacer if you are running the same wheels up front, otherwise it will look strange running flush up front and tucked in on the rears.
If you run coil-overs, then you'll be okay upfront with a +45 offset. So, options: Running springs - use 10mm spacer on fronts and rears Coilovers - no spacers required Other option is to run staggered with a different size wheel up front: 18x7.5-8" up front (offset range +40 to +45) and the 18x9 +45 wheels in the back. |
The Following User Says Thank You to Slick For This Useful Post: | twag4 (09-19-2014) |
09-18-2014, 08:58 PM | #2514 |
Boooooosted
Drives: Turbo FRS
Will this fit? (width, offset and tire size Qs)
18x8.5 +48 rota g force wrapped in 225/40zr18 okay? Stock suspension. Eventually either sport line or pro kit drop.
RocketBunny FRS // Phantom ESC // OFT x E85
09-21-2014, 07:13 PM | #2515 |
i kill cones.
Drives: around cones in a parking lot
I'm looking to get Enkei Kojin 18 x 8.5 et45 front and 18 x 9.5 et45 rear
I'll be running stock suspension for the time being to stay in my autocross class (i'll be switching to stock wheels for c street) for tires I was thinking 235/45 for the front and 255/40 for the rear The reason I want these sizes is to get as much sidewall as possible to fill the wheel gap So i have two questions (hopefully someone can answer): 1. Will these wheels fit with out hitting the stock springs? 2. The overall diameter of the two tires will be off by 7mm (1/4''). Will this effect abs/tc? thanks
2013 SSM BRZ Limited 6MT
09-21-2014, 07:55 PM | #2516 |
Drives: Subaru BRZ - GBS
Looking at used xxr 527's. I'm not fimiliar with sizes and fitment so maybe you guys can help me out. Square set of 18x9.75 +20 running 245/40ZR18 tires. Will they fit with stock height? What about a 1in drop?
09-23-2014, 11:34 PM | #2517 |
Drives: 2013 Subaru BRZ
18x8.5 +44 Volk RE30's, lowered on RCE Yellows, stock strut bolts, HVT camber plates (running -2 camber up front).
Right now I have 225/40R18 Michelin PSS's...look pretty stretched and wondering if I could/should fit something wider all around. 245/35 looks real close to stock diameter...but will it fit without issues up front? There really doesn't seem to be much room between the 225/40's and the spring perch of the stock struts...I can fit a fingertip by my fingernail in there, but that's pretty much it. Thoughts? |
09-25-2014, 02:51 PM | #2518 |
Run Away!
Drives: 2015 Subaru BRZ Limited
I've searched a bit and I've came to the conclusion that this will fit via posts and the wheel app but I would love a reassurance on the specs below:
Front: 17 x 7.5 +48 w/ 215/45/17 (Lowered 1 inch) Rear: 17 x 9.0 +35 w/245/40/17 (Lowered 1.3 inch) Also, would a 1.5 difference staggered setup cause any trouble? |
09-28-2014, 11:42 AM | #2519 | |
It will fit only on stock suspension and camber, but with very limited clearance. As soon as you drop it, you'll need to be on coilovers or use spacers (~10mm) to gain clearance. |
09-28-2014, 12:36 PM | #2520 | |
Tire sizes listed are too tall. Options: Fronts: 225/40, 235/40 or 245/35R18. Rear should be 245/35, 255/35R18. Think 265s are gonna be too tight. You shouldn't have any ABS issues as long as tire sizes are similar overall diameter. |
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
