03-21-2018, 10:02 PM | #113 | |
All roms pre 2017 now based on A01I rom so should work. IAM initial on e85 roms is stil! 1 |
The Following User Says Thank You to steve99 For This Useful Post: | Weigaldo (03-22-2018) |
03-21-2018, 10:05 PM | #114 | |
Basicly any 2012-2016 manual car will run on an A01G based map |
The Following User Says Thank You to steve99 For This Useful Post: | XCO (03-22-2018) |
03-21-2018, 10:16 PM | #115 | |
If you just want to flash your just flashing the entire block of code so you dont need def, just a device that knows how to flash the ecu with the block of code. All ecu the code block is same size and gets flashed to same location in ecu. |
03-21-2018, 10:22 PM | #116 | |
Use text editor search fir the bad table name and compare between defs http://www.ft86club.com/forums/showp...&postcount=107 |
03-21-2018, 11:35 PM | #117 |
Drives: 2017 Subaru BRZ Limited
has anyone with 2017 push button model 86/BRZ successfully used the V4 tunes yet?
03-21-2018, 11:36 PM | #118 |
03-21-2018, 11:54 PM | #119 |
Drives: 2013 frs red
It took my car roughly 25 miles of short hop driving (after flash) to regain throttle response and for idle to stabilize. V4 e85 has a nice shove around 3500 rpm that aids acceleration and I don't need to go over 5k now to be amused
03-22-2018, 12:27 AM | #120 |
Drives: '17 BRZ PP
Good to know, looking forward to this setup soon
03-22-2018, 12:41 AM | #121 |
Drives: 2013 FR-S Series 10
seems like the vvt is not as loud as it used to be ?
03-22-2018, 01:37 AM | #122 |
Drives: '15 BRZ RA
So now you have a single rom file? Wow! A bit risky if there are small differences in uncharted areas on the roms ...
03-22-2018, 04:22 AM | #123 | |
the ecu hardware is same in all cars There are some small differences in external connections like for evap purge connection, but these are non critical. Only connected on usa cars, hence why euro roms used |
03-22-2018, 08:37 AM | #124 |
Drives: 2013 BRZ Limited
Flashed the car yesterday with Stage 2+ for 91/93 and it definitely seems quieter. Less than 25 miles on it so I haven't tested power but so far everything seems to be working well. It was nice not having to adjust the cold start tables.
03-22-2018, 10:22 AM | #125 |
Drives: frs
Tried to download latest open flash manager but doesnt download
03-22-2018, 10:58 AM | #126 |
Drives: Scion Frs
Has anyone with a 2013 scion frs AT upgraded to the new tunes yet? any difference at all from the old ones? Im still using the v2.076 tunes just want to know if it's even worth updating...
Similar Threads | ||||
Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Software Tuning | 130 | 08-25-2020 07:29 AM |
The latest EU/AU OFT tunes (D00G) don't come with launch control | jamesev93 | Software Tuning | 4 | 03-12-2018 04:14 PM |
Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Engine, Exhaust, Transmission | 3 | 08-27-2016 02:04 PM |
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 54 | 06-11-2014 06:29 PM |
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 03:35 PM |
