Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
03-12-2024, 12:18 PM | #1 |
Drives: 13 Scion Frs
Temp all the way up, error codes p0125 and p0128 - Resolved
On my way in to work this morning, a minute into my drive my traction control light, and check engine came on, noticed the temp was all the way up and pulled over.
Is this just an obvious thermostat that's stuck? Bad idea to drive until it's fixed? A few months back I had an issue with the heat not blowing but it went away after one night. Same issue happened again yesterday, didn't think anything of it Also when I checked the codes, the engine fan is blowing louder than I've ever heard. Not sure if it's relevant but figured I'd add Update: Car was super low on coolant. After refill it wouldn't turn over at all, tried it three times. Cleared the engine codes,radiator fan shut off immediately, and gave it another shot and everythings been working fine now. Followed how to's to get rid of the air bubbles and whatnot. Thankful this happened when it did, and it doesn't look like any engine damage happened. Last edited by Alfrz; 03-18-2024 at 02:29 PM. |
03-12-2024, 12:21 PM | #2 |
Drives: 2015 midnight blue limited edition.
If the heat is not blowing then the water pump is done!! So probably leading to overheating issues. Yeah stop driving and get it checked before you blow the heads.
Sent from my Pixel 6 Pro using Tapatalk |
03-12-2024, 01:10 PM | #3 | |
How sure are you here? I was driving for at least an hour, to the point that I just turned off the AC since it would only blow cold. The engine temp was fine all through that and yesterday, and the lights/temp only went high today after literally just a minute of driving |
03-12-2024, 06:39 PM | #4 |
Update, went and added some coolant, but now the car won't turn over. Haven't done anything else since I turned the car off this morning
03-12-2024, 07:40 PM | #5 |
Drives: Toyota GT86
If you remove the oil cap what color is the oil ?
2014 GT86 Orange 6 Speed https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
03-12-2024, 08:35 PM | #6 |
03-12-2024, 09:11 PM | #7 | |
Drives: Toyota GT86
So what fixed your problem ?
The Following 2 Users Say Thank You to autoracer86 For This Useful Post: | Alfrz (03-13-2024), whataboutbob (03-12-2024) |
03-12-2024, 11:23 PM | #8 |
AutoX-10/10ths every run
Where did the coolant go should be your question. You need to answer this, before you need a motor.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
The Following 2 Users Say Thank You to whataboutbob For This Useful Post: | Alfrz (03-13-2024), Ultramaroon (03-13-2024) |
03-13-2024, 01:27 AM | #9 |
03-13-2024, 01:53 AM | #10 | |
義理チョコ
Wow
03-13-2024, 03:12 PM | #11 |
Just looked like normal oil that was probably about due for a change, so just dropped it off for a change while I'm workin
Similar Threads | ||||
Header, Error Codes, Emissions | FT86OLDMAN | Engine, Exhaust, Transmission | 2 | 08-19-2019 09:42 AM |
Car throwing error codes and goes into limp mode | Yehia23 | Issues | Warranty | Recalls / TSB | 9 | 09-06-2018 09:28 AM |
Help! Battery died, charged battery now getting all sorts of error codes! | jermyzy | Issues | Warranty | Recalls / TSB | 12 | 11-25-2015 12:35 PM |
P0128 CEL | Slow_86 | Issues | Warranty | Recalls / TSB | 3 | 08-31-2015 11:55 AM |
Error codes + traction light after body shop | Drewbie | Issues | Warranty | Recalls / TSB | 46 | 05-04-2015 10:08 PM |
