Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
12-28-2016, 04:15 PM | #1 |
Drives: 2022 GR86 (formerly 2014 BRZ)
Alternate location for reverse camera (HowTo)
I mounted up a Rydeen Duo on my Subaru BRZ using this post:
BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures) I found that I didn't like the OEM location much. When parking, the driver side parking lines, or curb, or other cars... strongly favored the passenger side visually. At times, it took a bit of mental arithmetic that I couldn't afford in my rush to avoid inconveniencing others. As a result, I removed it and installed it differently: in the center. Comparison of OEM (top) and centered (bottom): OEM location: Alternate centered location: What it looks like mounted (the back hangs on the ridge): Also, I no longer have a stock headunit. As such, these are the wires to tap in the rear trunk, along the back trunk wall: |
The Following User Says Thank You to rubbercow For This Useful Post: | Chimera (12-28-2016) |
12-28-2016, 04:25 PM | #2 |
The Gunshine State
Drives: '14 BRZ Limited
Great write-up, I'm really interested in adding a backup cam as well.
Current DD: M235i |
12-28-2016, 08:51 PM | #4 | |
The Gunshine State
3M tape is enough to keep it mounted even with the Florida heat? Which model is that?
Current DD: M235i |
Similar Threads | ||||
Reverse Camera Suggestions?? | 5irestormer | Electronics | Audio | NAV | Infotainment | 6 | 11-07-2016 03:33 PM |
FYI - it's possible to add a reverse camera for $20. | SloS13 | Electronics | Audio | NAV | Infotainment | 25 | 09-09-2013 10:03 PM |
Reverse light wire location? | derka-derka | AUSTRALIA | 1 | 05-29-2013 09:19 AM |
Reverse Camera | FT86_Zero | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 08-05-2012 08:05 PM |
Reverse camera? | dorkymork | BRZ First-Gen (2012+) -- General Topics | 28 | 05-21-2012 10:21 AM |
