09-29-2022, 10:25 AM | #4244 | ||
2. Aftermarket isn't always an upgrade. Those parts aren't necessarily bad but they're adding complexity that you don't need. They won't last as long as OE. 3. Understandable. Corner balancing is nice to have. For endlinks, you want the studs to just line up with the mounting holes with the car on the ground. So don't set them with the car in the air. Quote:
- Andrew |
09-29-2022, 10:43 AM | #4245 | |
Drives: 22 BRZ limited
09-30-2022, 11:40 AM | #4246 |
Drives: 2016 Subaru BRZ
Hey guys, which set up would you choose for a daily driver and about 5 track days per year:
Bilstein B6 with lowering springs Tein Flex Z or Flex A |
09-30-2022, 12:20 PM | #4247 |
Drives: 2023 BRZ
All good options. Personally I'd go Bilstein.
Director of Rocky Mountain 86CUP
The Following 2 Users Say Thank You to Pat For This Useful Post: | DAEMANO (09-30-2022), strat61caster (09-30-2022) |
09-30-2022, 12:21 PM | #4248 |
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | flippy (09-30-2022), MyHybridBurnsGasAndTires (09-30-2022) |
09-30-2022, 10:01 PM | #4249 |
09-30-2022, 10:04 PM | #4250 |
Drives: 2023 BRZ
They handle bigger bumps at high speeds better in my experience.
09-30-2022, 10:17 PM | #4251 |
CSG spec or off the shelf ones? 5 track days are enough your gonna want front camber alignment and 17x9 track wheels which you want camber coming from plates vs bolts... Just my 2 cents
2013 Series 10 FRS #553
10-01-2022, 06:26 PM | #4252 |
10-01-2022, 06:28 PM | #4253 |
Off the shelf. I currently have 17x9 +35 wheels and camber bolts, my tyre is VERY close to the shock, but no rubbing. I'm considering camber plates if I go with the bilsteins.
10-02-2022, 12:49 PM | #4255 |
That should be fun.
- Andrew |
10-03-2022, 09:32 AM | #4256 |
Drives: 2023 BRZ
Slightly firmer and more composed.
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
