Software Tuning Discuss all software tuning topics. |
04-20-2020, 05:58 PM | #1 |
Drives: TRD R.S. 1.0 FRS
Delicious flex fuel w/ oft
Im on OFT E85 tune. I am planning on tuning it next month, since i wanted to install it instead of my tuner. $120 labor. Yea no thanks.
My question is, if i install it and im on an OFT e85 tune, will it affect the fuel delivery in any way? Would it even work? Or would i need an ecutek tune and all that? Im not trying to use my e85 oft tune as a flex fuel tune for my kit, just using as a normal fuel line until i actually get it tuned If it does my other solution is, just to install and not install the fuel lines and sensor. Thanks! |
04-20-2020, 06:31 PM | #2 |
Wheels for Brains
The sensor won't do anything and won't affect anything until you get it tuned.
You can install it, leave the sensor unplugged, and continue driving. You can even plug it in if you want to use the app to see your E%. Most tunes already disable the Rear O2 sensor reading (if you're using one that adopts the Rear O2 connector). The ECU won't know what to do with the sensor reading (or even know that it's there) until you get a tune that can tell the ECU how to use it. If you plug the sensor in on a stock tune, you'll get a Rear O2 CEL. |
The Following User Says Thank You to EndlessAzure For This Useful Post: | airrick (04-20-2020) |
04-20-2020, 09:53 PM | #3 | |
just waitin on my JDL 4-2-1 headers. |
04-20-2020, 11:15 PM | #4 | |
Drives: FT86
If you got a rear 02 connect flex kit, you getting ecutek tune for flex ?. Oft tunes only support evap connect flex kits not rear 02 and only pre facelift cars |
04-20-2020, 11:48 PM | #5 | |
TDLR; im being cheap. |
The Following User Says Thank You to airrick For This Useful Post: | steve99 (04-21-2020) |
01-10-2022, 09:54 PM | #6 |
I'm trying to locate the CPC sensor lead to use the FlexFuel OFT Tune. The document they sent doesn't look like anything in the kick well. Any help on locating that CPC lead would be very helpful!
Here is the image of the terminal blocks I can't find! HELP |
01-11-2022, 11:22 AM | #7 | |
LMGTFY
Drives: 13 FRS, 91 Miata
Even worse twice in the same sub-forum. |
The Following User Says Thank You to x808drifter For This Useful Post: | NoHaveMSG (01-11-2022) |
01-11-2022, 03:04 PM | #8 | |
Drives: Crapcan
https://support.openflashtablet.com/...-flex-fuel-kit Connecter A35, pin 20, orange/black wire if using Evap reference. Yes it is a PITA to get to and requires a good amount of car yoga.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | x808drifter (01-13-2022) |
01-16-2022, 11:31 AM | #9 |
Road-hole
Drives: 2013 Whiteout FR-S
Or if you want it to be easier, you can do this... I managed to find one on ebay for $55
https://www.xero-limit.com/brz-gt86-evap-harness.html Jaden |
01-28-2022, 01:10 AM | #10 |
Human
Drives: 2015 BRZ Black
Doesn't the ecutek and oft both support the evap and 0.5v-4.5v and 0v-5v?
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
01-28-2022, 08:12 AM | #11 |
Drives: brz 2017 hksv2
the scaling, you should be able to set in on the table of the patched rom
but OFT only support evap connection, so the signal must go there with ecutek you have no limit, you could remove maf and put flex fuel sensor on the maf connector and it works |
Similar Threads | ||||
delicious tuning flex fuel | solidsnake11 | Software Tuning | 4 | 12-01-2019 05:09 PM |
FS: Delicious tuning flex fuel black stainless steel braided fuel lines | iceblaze | Southern California | 0 | 09-12-2019 03:36 PM |
WTB: Delicious Tuning Flex Fuel Kit MK1+ | Krewcial5050 | Want-To-Buy Requests | 0 | 02-12-2019 09:30 PM |
Delicious Flex Fuel Mk1+ | shaynek | Engine, Exhaust, Bolt-Ons | 3 | 01-14-2019 07:42 PM |
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System | DeliciousTuning | Software Tuning | 20 | 06-09-2016 06:21 AM |
