Forced Induction Turbo, Supercharger, Methanol, Nitrous |
09-24-2020, 08:22 PM | #15 | |
Drives: 2017 Subaru BRZ
I have the limited model just like you. So I got the premium cover (without the foglight cutout) and cut out the inner plastic of the cover (see image). My hks oil cooler comes with a metal mesh for venting out air post oil cooler where you'll have to cut out a section of your wheel well (see image). I still have the foglight on the driver side :P |
09-25-2020, 05:22 PM | #16 |
I think vents behind the fenders to let hot air out would be my next. Cheap and easy mod
2013 Series 10 FRS #553
09-25-2020, 06:22 PM | #17 |
Drives: '13 Whiteout
What track? I know when I run Big Willow i run hotter by 20 degrees than Streets or Laguna.
The Following 2 Users Say Thank You to TommyW For This Useful Post: | MotoX16 (09-28-2020), Sisko's_Baseball (09-26-2020) |
09-28-2020, 10:04 AM | #18 |
Drives: Track preped NA FRS
30 weight oil, open up the front (fog light), the rear (inner liner of fender) and the top of the fender (fender vents) and you should see a drastic decrease in oil temps and a good gain in pressure.
The Following User Says Thank You to Icecreamtruk For This Useful Post: | MotoX16 (09-28-2020) |
09-28-2020, 08:10 PM | #19 |
Track was Brainerd International Raceway in MN
2017 Subaru BRZ PP
FBM Turbo Kit: GTX3076R - HRI FlexFuel Tune - 3" Turboback Exhaust - ID1000cc Injectors - Walbro 485 Fuel Pump - FBM Oil Pan - FBM Oil Cooler - Killer B Oil Pickup - FBM Catch Can - FBM Radiator w/Fan Shroud - Clutch Masters FX400 - Verus Clutch Fork/Pivot - IRP Shifter - Cusco Engine/Trans Mounts - RCE Yellow Springs - PS4S 245/40/17 |
11-08-2020, 06:25 PM | #20 |
Well I took the time today to get to work. I removed the foglight and added a piece from Verus's brake ducting kit to direct air towards the cooler. And I added an exhaust vent in the wheel well. Hopefully this helps some with my oil temps
2017 Subaru BRZ PP
11-08-2020, 06:57 PM | #21 |
AutoX-10/10ths every run
The inputs and outputs you've implemented probably will help, but you really need to maximize the air flow across the heat exchanger. Kits like the Greddy and HKS for the 86 provide a path in from the opening in the front of the bumper to the input side of their oil coolers. That's a good starting approach, but you need to make sure that the path out the backside is flowing air as well. If the air doesn't have anywhere to go after passing through the heat exchanger it will inhibit the overall flow of air. To get this setup you may have to cut more out of the fender liner behind the bumper.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
The Following User Says Thank You to whataboutbob For This Useful Post: | MotoX16 (11-08-2020) |
11-09-2020, 09:43 AM | #22 | |
I could try cutting open some of the slits on my fog light bezel, but I'm open to other suggestions
2017 Subaru BRZ PP
The Following User Says Thank You to MotoX16 For This Useful Post: | whataboutbob (11-09-2020) |
11-09-2020, 03:45 PM | #23 |
I'd use an approach similar to what @Bunchh did. Maybe order another non-foglight bezel and modifiy it? Also, if you can fabricate a shroud on the entry side to the heat exchanger to force in input air into the exchanger, and not allow it to have a route around it, that would probably help.
The Following User Says Thank You to whataboutbob For This Useful Post: | MotoX16 (11-09-2020) |
11-09-2020, 03:49 PM | #24 |
This is what I did for my AT cooler, similar to what you might do for your oil cooler.
11-13-2020, 08:15 AM | #25 |
Drives: Blue BRZ
wow are you guys in built engines or stock? my 2nd built motor by andrewtech blew up at 235degF
11-13-2020, 09:05 AM | #26 | |
The Following 3 Users Say Thank You to jflogerzi For This Useful Post: |
11-13-2020, 09:26 AM | #27 |
Rust bucket enthusiast
The Following User Says Thank You to DarkPira7e For This Useful Post: | jflogerzi (11-17-2020) |
05-16-2021, 06:40 PM | #28 |
Alright got one step complete today, opened up the front a good bit more. Just need to open up the back more, also picked up a fan I might try on the cooler.
I was able to adjust how the cooler was mounted and moved it further up (towards the headlight), out (towards the fender), and forward (towards the foglight opening). Looking at it I already see room for improvement, but its a big step up from where it was.
2017 Subaru BRZ PP
The Following User Says Thank You to MotoX16 For This Useful Post: | DarkPira7e (05-16-2021) |
Similar Threads | ||||
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo | tampaSi | Brakes, Suspension, Chassis | 4 | 05-27-2017 02:31 PM |
MVP Track Time 2013 Great Lakes/Midwest Track Dates | Feffman | Great Lakes | 5 | 09-07-2013 01:39 PM |
GPS Track Time /Nine Lives Racing Track Day and Auto Show (Sun. 9/8) | Chicago | Great Lakes | 0 | 08-13-2013 08:42 AM |
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning | AZP Installs | NY / NJ / CT / PA | 11 | 08-20-2012 11:31 PM |
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning | AZP Installs | Tracking / Autocross / HPDE / Drifting | 0 | 08-14-2012 06:46 PM |
