01-13-2021, 07:06 PM | #99 |
Drives: Bone stock
The Following User Says Thank You to Joveen For This Useful Post: | DarkPira7e (01-14-2021) |
01-14-2021, 12:18 AM | #100 |
Rust bucket enthusiast
Thank you! I actually changed my mind; I stayed with Boostlab but picked up the BL58X and got the T51R compressor housing option. The shop I help out at has been installing some Boostlab turbos and I want to show my support for a company that my shop trusts and get their name out there just that little bit more. That, and I decided I'm not just doing this half ass- this is full send
I appreciate that! With the FRS as its base, it can only be excellent
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
01-14-2021, 05:30 PM | #101 |
Little update-
Lots of parts in! Engine gasket set ARP head studs KillerB oil pickup Fluidampr pulley Boostlab BL58x (.82 hotside, T51R compressor housing mod) PTP turbo blanket 4 direct injectors fresh from seal replacement and cleaning by FIC I changed turbos because honestly I want this build to be everything I've got. I've gone through too much to just have it be OK. This turbo should be good for 500+ on pump gas at around 25psi. I plan to sit low to mid 400s I won't be upgrading the transmission right now. Replacements are cheap and power can be backed off if transmissions and axles gets wasted too quickly. Still needed- Timing chain kit I think that's it. We'll see
01-14-2021, 06:24 PM | #102 |
Drives: Crapcan
Before you put sealant in the oil pan and assemble it, install the pickup and set the oil pan on dry to make sure it fits. Mine was made way too long and I made a mess of the sealant and had to redo it.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | DarkPira7e (01-14-2021) |
01-14-2021, 07:13 PM | #103 |
Thanks for this, I'll be sure to check!!
The Following User Says Thank You to DarkPira7e For This Useful Post: | NoHaveMSG (01-14-2021) |
02-03-2021, 12:46 PM | #104 |
Drives: Crystal White BRZ
just started lurking, keep it up! can't wait to see the finished build
The Following User Says Thank You to Limitless_BRZ For This Useful Post: | DarkPira7e (02-03-2021) |
03-18-2021, 12:28 PM | #105 |
Bought new timing components for the heads! Just need to see what we need for shims.
03-18-2021, 02:07 PM | #106 |
Drives: Bone stock
Bout time you updated us. We hitting the meets this year or nah?
Sent from my SM-G998U using Tapatalk |
03-18-2021, 02:26 PM | #107 |
Drives: Crapcan
Still running 13" spec head?
03-18-2021, 05:41 PM | #108 |
Hopefully!
Yep. Using my original heads that were good, not re-using the ones on the used replacement engine.
03-25-2021, 09:18 AM | #109 |
Drives: Mitsubishi Evo IX MR SE
New here, but also in Vermont and interested in getting an 86...looks sick. I'll keep an eye out for ya!
The Following User Says Thank You to screamer_chaotix For This Useful Post: | DarkPira7e (03-25-2021) |
03-25-2021, 10:54 AM | #110 |
Awesome! I'd be more than happy to give you a ride sometime when it runs. I have a friend with a 2017 performance pack BRZ that would probably be willing to give you a ride, too (if you want to feel what a bolt-on car drives like)
04-15-2021, 05:32 AM | #111 |
Drives: 2016 scion frs
Awesome build! Cant wait for the finished car
Also you got your heads decked and resurfaced? |
04-15-2021, 09:03 AM | #112 | |
Edit- nvm, machine shop can't do the FA20 heads yet, we're making a bracket for his machine the will bolt to the exhaust side. He uses the intake sides on EJ heads but the casting protrudes out further than the bolt holes
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block Last edited by DarkPira7e; 04-15-2021 at 11:22 AM. |
The Following User Says Thank You to DarkPira7e For This Useful Post: | jrhudson (04-19-2021) |
Tags |
brz, frs, iag, jdl, turbo |
Similar Threads | ||||
Joel's BRZ - Low Budget Time Attack Build | DIY | Member's Car Journals | 403 | 12-11-2023 05:59 PM |
Cxracing turbo problem | Kalebhall | Forced Induction | 10 | 11-16-2017 07:57 AM |
Tony's Budget Turbo Build | glorydays | Member's Car Journals | 22 | 01-25-2015 11:02 PM |
My boosted build...on a budget | PineappleFriedRice | Member's Car Journals | 95 | 08-17-2014 09:29 PM |
Aznsky's budget STX build | Aznsky | Tracking / Autocross / HPDE / Drifting | 13 | 05-12-2014 08:44 AM |
