Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-22-2016, 02:09 AM | #29 | |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Yes, there is something you can do about it
Buy a sheet of memory foam, or a mattress-topper. Shred it into chunks. Remove the floor and side panels from the trunk. Stuff those chunks into the openings above the rear wheel wells till they won't take any more. Stuff chunks into any other openings between the trunk and cabin. Much quieter now isn't it? That fixes your exhaust noise problem. Your exhaust is fine, the noise is the problem, since the only thing between your ears and your exhaust tips is the fabric of the seat back, and the rubber seal of the trunk lid, insulation is the cure for it.
If I say yes, will that make you think I understand?
The Following User Says Thank You to KoolBRZ For This Useful Post: | ajcarson11 (04-29-2016) |
04-22-2016, 02:49 AM | #30 |
I love my series blue brz
Drives: 2010 335d
either it is your header causing the noise, or you have exhaust leak.
I have Invidia Q300 on my car installed last year, it was just a bit louder than stock. So today i have tanabe overpipe and invidia front pipe installed and there is almost no difference of noise level. performance gain is barely |
04-22-2016, 08:13 AM | #31 | |
Drives: 2013 Subaru BRZ Limited (Black)
Thanks! |
04-22-2016, 08:14 AM | #32 | |
04-22-2016, 09:32 AM | #33 | |
Drives: Crystal Black BRZ(Sophia)
04-22-2016, 09:43 AM | #34 |
Take a look at the TopSpeed Pro-1 (which is what i'm using here).. Should be a copy of the Greddy SP Elite, but if you read this thread it sounds like there is some question into which is louder.
The Following User Says Thank You to ajcarson11 For This Useful Post: | Yoda (04-22-2016) |
04-22-2016, 09:49 AM | #35 | |
Update: Just ordered it. Last edited by Yoda; 04-22-2016 at 10:43 AM. |
The Following User Says Thank You to Yoda For This Useful Post: | FRSBRZGT86FAN (04-22-2016) |
04-22-2016, 05:30 PM | #36 |
Kouki-Monster
who makes a really SHORT and very effective resonator / muffler I can put inline on my midpipe? The Vibrant one I like is just too long to fit by about 4-6 inches.
http://vibrantperformance.com/catalo...products_id=46
Rich Anderson
EMPOWER AUTO |
04-22-2016, 09:51 PM | #37 | ||
It's best to put it in the front pipe for the very fitment reason you are having(especially the stock front pipe so you have a cat and a resonator), Vibrant doesn't sell any shorter resonators than about 12 inches. The shortest race mufflers they have however do fit you're size request: http://vibrantperformance.com/catalo...1022_1032_1257 However the inner diameter is .5 inch too big, unless you want to fabricate a cone on both ends
04-23-2016, 05:53 AM | #38 |
Drives: 2014 GT86
Resonators not just reduce specific frequencies noise, they also do that depending on shape/size. I'm not sure it's worth to hunt for absolutely smallest .. will it do what you expect from it?
04-24-2016, 07:04 PM | #39 |
Drives: '15 red FR-S SSC
"...This is not the case however. In my opinion it is quite loud in the cabin. I'm running Gruppe-S UEL, stock FP, stock OP, Greddy SP Elite. During acceleration it is challenging to have a conversation."
A conversation, in an 86, during acceleration??? The idea never even crossed my mind. Single exhaust track pipe here. |
The Following User Says Thank You to lonborghini For This Useful Post: | ajcarson11 (04-29-2016) |
04-27-2016, 11:00 PM | #40 |
Installed and love the sound! I see what u mean about it being a bit loud but it's manageable. Those bolts were rusted on there good couple of cuts but worth it. My only issues is that it's not perfectly aligned. The right exhaust needs to stick out maybe a 1/4". I will play with it in a few weeks and see.
04-28-2016, 11:05 AM | #41 | |
The Following User Says Thank You to KoolBRZ For This Useful Post: | Yoda (04-28-2016) |
04-29-2016, 11:21 AM | #42 | |
Just to clarify on that. |
Similar Threads | ||||
Bring the Noise with FRSPORT's 2014 Exhaust Blowout! | FRSport.com | Engine, Exhaust, Bolt-Ons | 0 | 09-05-2014 12:40 PM |
Front pipe variations and exhaust volume | Vmax911 | Engine, Exhaust, Transmission | 9 | 03-05-2014 04:04 PM |
Exhaust volume | twag4 | Engine, Exhaust, Transmission | 17 | 09-24-2013 04:12 PM |
Cold Start Exhaust Volume | SilentMike | Engine, Exhaust, Transmission | 15 | 04-04-2013 10:49 AM |
Bring your intake and/or exhaust! | bdanisi | Engine, Exhaust, Transmission | 8 | 01-09-2013 01:07 PM |
