Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > Technical Topics > Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Old 03-30-2021, 12:14 PM   #1
dazhbucked
Drives: Subaru BRZ 2014
Tips to remove poop stains
Any recommendations on how can I get rid of this bird poops stains, Iíve used meguiars ultimate compound by hand but it did nothing, Iím guessing I have to use a polish machine, has any one of you had to deal with this in the past?. Iíll attach some pictures, also the paint feels oxidize to hand touch.
dazhbucked is offline   Reply With Quote
Old 03-30-2021, 12:25 PM   #2
alphasaur
friendly
Drives: 17' 86
How long has the poop been on there? It should come off with some rubbing compound but if it was on long enough to affect the integrity of the clear coat you may need a rotary.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 03-30-2021, 12:46 PM   #3
ls1ac
ls1ac's Avatar
Two things.
Get it off as quickly as possible.
Get your next car ceramic coated.
I know too late.
If it has been on there very long it will etch the clearcoat and possibly stain the surface.
If you are able to buff it out, try one of the spray graphene or ceramic sprays. It may help with future droppings. Waxes will not stop bird poop from getting to the paint.
The Following User Says Thank You to ls1ac For This Useful Post:
DarkPira7e (03-30-2021)
Old 03-30-2021, 12:55 PM   #4
dazhbucked
They stayed on the car for months
The Following User Says Thank You to dazhbucked For This Useful Post:
alphasaur (03-31-2021)
Old 03-30-2021, 02:38 PM   #5
Kaotic Lazagna
Drives: Whiteout FR-S Monogram
That's etched the paint. Only way to "remove" it is paint correction, and even then, it might be too late if it has eaten away through the clear coat.
Old 03-30-2021, 05:26 PM   #6
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
with no teeth, a birds poop is highly acidic.
thomasmryan is offline   Reply With Quote
Old 03-30-2021, 06:03 PM   #7
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ Limited
Please add the word 'bird' into the title. I thought a baby's diaper had exploded inside your car.
That being said, you may not have gone deep enough with the Meguiar's Ultimate Compound - try it on one spot and try buffing it more.
shiumai is offline   Reply With Quote
The Following 2 Users Say Thank You to shiumai For This Useful Post:
Tcoat (04-07-2021), Wally86 (03-31-2021)
Old 04-07-2021, 11:19 AM   #8
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
At this point your best bet is to do a paint correction. After that, ceramic coat it.
ďGod gave me an okay mind, but a really good ass, which can feel everything in a car.Ē Nikki Lauda
spcmafia is online now   Reply With Quote
Old 04-07-2021, 12:21 PM   #9
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
If you can get your hands on a DA or Rotary polisher you can clean that up with the compound you have. I'd stick with foam pads, like an orange or yellow cut.
Finish with a green pad and a polish.
You'd need to use a decent amount of pressure by hand to build up heat needed to correct that. Then you'll need a polish to correct the hazing.
I managed to correct light etching by hand that happened on my deck lid. Poop was only there a day, two tops and it left a hollowgrame effect you could see in the right lighting.
Ceramic coating can help as It'll etch the coating if left on which is probably more desirable than the clear it self. You'd need to repolish the panel and recoat in that situation.
RToyo86 is online now   Reply With Quote
Old 04-07-2021, 01:10 PM   #10
He who smelt it...
I was afraid it was humfrs'!
Tcoat is online now   Reply With Quote
shiumai (04-07-2021), soundman98 (04-07-2021)
Old 04-07-2021, 03:38 PM   #11
radroach
Drives: 13 BRZ
Bird poop is highly acidic. You have to get it off your car asap! You don't have any clear coat left in those spots to save and any polishing you do will probably only spread clear coat failure. You will have to do send it to a paint shop to try to do a spot repair and re-clear coat it. But most shops will probably want to do the whole panel.
Other option would be to put stickers over the spot.
Old 04-08-2021, 06:08 PM   #12
Sam86
Drives: Toyota 86 GTS
I’ve got a first sized splat that looks exactly like birdpoo etching that has seemingly appeared over night. It’s right above where I shut my driver door so I would have noticed it immediately like I did this morning if it had been there before. Never had a bird poo on that particular area and my car was garaged all night so not sure what to make of it
Sam86 is offline   Reply With Quote
Old 04-08-2021, 08:58 PM   #13
driftguy
driftguy's Avatar
Drives: In between cars... 2018 Ninja 1000
I watched a YouTube video of a guy slowly and carefully heating the etched paint with a heat gun. You could also use a hair dryer. Seems to work like a charm.
driftguy is offline   Reply With Quote
The Following User Says Thank You to driftguy For This Useful Post:
Magyarman (04-14-2021)
Old 04-08-2021, 09:49 PM   #14
DarkSideFRS
Drives: 2013 pearl white FR-S
It's done. Bird poop ate through the clear, and the clear on this car sucks to start with. No amount of compounding or paint correction will help fix it
DarkSideFRS is offline   Reply With Quote
Paint stains easily? DarkSideFRS Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 09-28-2017 05:59 AM
Pollen Stains? Please Help! nooserbtf Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 05-14-2014 08:48 AM
[Question] How to remove stains from rustproofing i_4got Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 05-01-2013 04:59 AM
Help: Pecan Stains Under Clear Coat psk Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 10-09-2012 07:31 AM
CARPET STAINS MidnightMonkey Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 06-28-2012 12:56 PM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
