12-09-2012, 10:03 PM | #127 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Sent you a PM...
@ebphoto BTW is this o-disk all around? Honestly thinking about running the same size up front. Not even sure if the A disk will clear a STI brembo caliper so if it doesn't guess I roll o disk all around with stock calipers or find a Wilwood setup that clears.
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
12-09-2012, 10:56 PM | #128 | |
KCCO From Canada
Drives: Asphalt FRS
What did these wheels weigh? i'm thinking of getting 18x8.5 +40 front and +30 rear (not wanting to be too aggressive) don't wanna roll fenders. (im gunna be running 245/35 tires as well, a little wider than your 225s. love your setup though! :happy0180: |
12-09-2012, 11:24 PM | #129 | |
My FR-S has 5 gears
Sent from my PC36100 using Tapatalk 2
Omar GC
The Following User Says Thank You to OmarGC For This Useful Post: | FreshFRS (12-09-2012) |
12-10-2012, 09:32 AM | #130 |
Drives: Rx7
18x9.5 - 23 lbs
18x11.5 - 24.4 lbs |
12-10-2012, 09:33 AM | #131 |
Drives: Rx7
A disk will clear Brembo caliper. O disk for stock caliper.
12-10-2012, 11:39 AM | #132 |
Drives: FR-S, NA8, S13
im running O disk... but it looks like a decent amount of room for brakes in all honesty... need to try them out on a local car that has sti calipers.
12-11-2012, 10:14 AM | #133 |
My FR-S has 5 gears
My fronts are going to be 18x9 +28. Waiting to back from Work USA because if I can roll O disc up front and slip on a 5mm spacer and clear the brembos that's what I'm going to do
Omar GC
12-11-2012, 11:58 AM | #134 |
Drives: Rx7
O disk need at least 10mm spacer to clear.
But A disk will clear. |
12-11-2012, 12:29 PM | #135 | |
My FR-S has 5 gears
18x10 front & 10.5 in the rear. From other pics looks like O disc front & rear... I find it hard to believe hes running a spacer on top of that width and judging by the dish still low et rim itself Sent from my PC36100 using Tapatalk 2
Omar GC
12-12-2012, 11:24 PM | #136 |
Drives: 97 DB8
Love the look EB...
12-12-2012, 11:27 PM | #137 | |
Drives: Rx7
It's only 10mm of caliper and lip size differences between the two disk. Caliper clearance for meister s1r are based on disk type, not offset and width. Mark |
12-13-2012, 03:44 AM | #138 |
Drives: Ford Focus RS & Toyota 86 GTS
Dude forget about the people hating on your car... You possibly have the best wheel selection and fitment out of the majority of cars on here and I think the majority of people reading this would agree. Well done.
Want to see MOAR!
12-13-2012, 05:03 PM | #139 |
Drives: 16 FRS
Can we see more pictures?
12-13-2012, 05:40 PM | #140 |
Similar Threads | ||||
Wheel Directory: Advan TC III 18x9.5 +40 | PRORICAN | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 53 | 03-20-2020 12:03 PM |
Work Wheels: CR-Kiwami / XD-9 / Meister S1R / Meister S1 3pc | Touge Factory | Wheels and Tires | 141 | 06-09-2015 07:35 PM |
Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 | PradiG | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 48 | 12-12-2013 03:15 AM |
FS/TW : Work Meister S1R -aggressive - 18x9.5 +25 w/225/40 | ebphoto | Wheels and Tires | 40 | 08-09-2013 01:58 PM |
Wheel Directory: Work Meister M1R 18x8.5 +?? / 18x9.5 +?? | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 08-03-2012 02:45 AM |
