Old 05-09-2019, 01:57 PM   #1
Droness
Drives: Black 2017 Toyota 86
Smile Joying 10.1" Android 8.1 4gb+32gb Intel 8-core +DSP
Hi Everyone,
I wanted to post a review of Joying 10.1" android 8.1 headunit.
The specs are
SKU:JY-UO134N4GS
CPU:Intel Airmont eight-core 1.8GHz SC9853i
Ram:LPDDR4 4GB
Rom:Samsung 64GB
Support Apple Carplay, Android Auto, Bluetooth, WiFi, DVR, OBD2, Back Up Camera, Digital Sound Processor, and 4g LTE
I've been using it for the last two months and its been awesome. It fits the car dash perfectly in my opinion. Also it supports Apple car-play without the use of a dongle using Z-link. Also the screen is massive and you can install your normal android apps on it if you like. Most importantly is that it doesn't block the vents and I was able to get it to fit mostly perfectly on the 2017 Toyota 86 dash. It does block the digital clock however there's a clock in apple car play. See the attached images
It's mostly plug and play if you get the Toyota wiring harness. The only thing is to run the OEM backup camera you will need to get a step-down to go from 12v to 6v. Everything else was a plug and play. Also you will need an adapter if you want to support the oem usb connector and 3.5mm audio jack.
If you do decide you want this, you need to order the Toyota wiring harness otherwise it won't be mostly plug and play.
Droness is offline   Reply With Quote
The Following User Says Thank You to Droness For This Useful Post:
kevaughan (05-10-2019)
Old 05-09-2019, 10:19 PM   #2
Jeff3345
Drives: Black frs/86
Originally Posted by Droness View Post
Hi Everyone,
The specs are
SKU:JY-UO134N4GS
Ram:LPDDR4 4GB
Rom:Samsung 64GB
Wow, that fits pretty good. Link to headunit and plug&Play harness please! Can you do a quick 360 type video?
Jeff3345 is offline   Reply With Quote
Old 05-10-2019, 01:06 AM   #3
blown
Drives: ft86
no longer on amazon? where to purchase?
blown is offline   Reply With Quote
Old 05-10-2019, 11:16 PM   #4
Droness
Hey, Sorry for the late reply. I order the JY-UO134N4.
URL: https://www.joyingauto.com/joying-ne...-4gb-32gb.html
I reached out to joying. If you use the promo code "Adam" they are willing to give you 12% percent off plus they will include the Toyota harness free of charge so it will be plug and play except for the backup camera, USB port and aux. You need to make sure you get the Toyota wiring harness otherwise this will not be a simple install.
Once you've placed there order let them know you would like the Toyota harness just to confirm and they will make sure you get it inside the box.
Lastly, I'm working on a video. Hopefully I can get it done over the weekend. Thanks
Old 05-10-2019, 11:17 PM   #5
Droness
Hey, you can order it through joying. I order the JY-UO134N4.
r3myx626 (07-01-2019)
Old 05-11-2019, 06:23 AM   #6
blown
Drives: ft86
what do I need to get the oem usb/audio jack input to work? 2013 brz
also I'm noticing they have a 4g version, I wonder if this will work with my spare project fi data only sim card.
https://www.joyingauto.com/joying-10...4g-module.html
Old 05-18-2019, 06:07 PM   #7
Octane
Octane's Avatar
Drives: FRS
Few questions:
Does the OEM mic on the roof still work?
Is it wireless or wired android auto?
Does it have the pesky "safety" where you wont be able to input or watch vids while the car is in motion?
Octane is offline   Reply With Quote
Old 05-18-2019, 08:41 PM   #8
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Did you get your back-up camera working too?
Drifter X is offline   Reply With Quote
Old 06-15-2019, 06:25 PM   #9
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Wow that does look pretty good. Did you need to buy the mounting kit? And does it have a SD card slot?
Nevermind, I ordered it and installed it yesterday. Took me a bit to notice that the DVR seeing was off in the factory settings SMH. I was like where's the damn DVR app lol. This unit is very zippy and damn it looks huge on the dash. I just find it odd that they didn't set this up with quick boot. Even though it starts up from cold boot really fast. I just find that really pointless when these units have been doing quick boot for a bit now. My only setback is that the z link doesn't want to work with my OnePlus 6T but it does work with my moto E4 backup phone. Other than that, I'm loving this HU.
Sent from my ONEPLUS A6010 using Tapatalk
Rican_D is offline   Reply With Quote
Old 06-21-2019, 10:49 AM   #10
Droness
Hey sorry for being gone for a while.
AX-SUBUSB to retain your factory USB port and for the audio jack you will need this Axxess AX-TOY28SWC. I haven't tried wiring the audio and I can't promise that will work.
Old 06-21-2019, 10:50 AM   #11
Droness
Originally Posted by Octane View Post
Few questions:
You have to tap into the oem mic if you want it to work. Also it's wired android auto and nope it doesn't have the pesky safety thing you can disable it in the settings menu.
Old 06-21-2019, 10:51 AM   #12
Droness
Yes I did I had to buy an adapter for the backup camera to step down to the 6v from the factory oem 12v.
Old 06-21-2019, 11:33 AM   #13
Ginotjr
Drives: 2019 Toyota 86 GT
Did you retain your steering wheel controls?
Ginotjr is offline   Reply With Quote
Old 06-23-2019, 04:21 PM   #14
Rican_D
Rican_D's Avatar
Is you capacitive back button working?
android, androidauto, carplay, headunit, joying
Dasaita 7" Oreo 8.0 4GB+32GB PX5 Octa-core 200x100 Head Unit Juzzotec Electronics | Audio | NAV | Infotainment 42 07-29-2019 08:08 PM
Joying 7" Android 5.1 Double Din Headunit ricotheraccoon Audio/Visual, Electronics, Infotainment, NAV 1 10-09-2018 04:56 PM
Joying Toyota DVD Android HU Rican_D Audio/Visual, Electronics, Infotainment, NAV 9 08-05-2017 02:40 PM
Joying Android Head Unit in 2016 FRS? michaelchatten Electronics | Audio | NAV | Infotainment 0 10-30-2016 02:03 PM
Ebay Dual Core Android Head Unit Interflop Electronics | Audio | NAV | Infotainment 1 06-26-2014 12:20 PM
