Old 01-09-2019, 04:11 PM   #15
504
504's Avatar
Drives: 2014 86 GTS
Originally Posted by tomm.brz View Post
What kind of custom maps do you guys set up, with accelerator pedal as output?
I'm more concerned with overrun timing as output rather than base timing
504 is offline   Reply With Quote
Old 01-09-2019, 04:17 PM   #16
tomm.brz
Drives: brz 2017 hksv2
Yes also that, because I can t find the overrun Timings on the output on neither racerom 9 or 10
Old 01-10-2019, 12:20 PM   #17
Tor
Tor's Avatar
Drives: Toyota GT86
Originally Posted by Kodename47 View Post
Why not lower the zero point to 13 in your instance? I have to say that I have not noticed your issue but then I have not logged this after a long period of running.
The problem is the whole scale moves a bit. So if I need 18 to produce 3% accelerator at a fresh flash, that 18 I put in the tables won't consistently produce 3%.
Traction control, rev limiter, pops.
You can't change individual tables with Racerom. You are neither changing e.g. base or overrun. You can subtract/add/multiply the overall timing using racerom. If you only want it to subtract/add/multiply at a specific phase (e.g. overrun), you need to be creative with how that map activates/deactivates - e.g. use accelerator input to decide when it's active. But as said it's not without flaws.
Tor is offline   Reply With Quote
The Following User Says Thank You to Tor For This Useful Post:
504 (01-10-2019)
my first turbo tune Ecutek aquaman Software Tuning 4 03-08-2017 11:55 PM
Ecutek Tune tyler_win_photo Software Tuning 2 10-26-2016 05:37 AM
B01D 6AT SBD Turbo Tune Questions *Tune Attached* Pro60modman Software Tuning 6 09-05-2016 09:04 PM
