09-06-2020, 11:02 PM | #22317 |
Welp, maybe alignment machines just won't adjust that far out to give you what you want -
09-07-2020, 12:08 AM | #22318 | |
Sent from my ONEPLUS A5010 using Tapatalk |
The Following User Says Thank You to Ashikabi For This Useful Post: | humfrz (09-07-2020) |
09-07-2020, 07:08 PM | #22319 |
Drives: 17 Asphalt 86
While leaving the cottage I heard a "tink" noise come from the left front, then I heard a metallic grinding noise. It sounded like a rock touching the rotor, and would come and go based on brake pressure, steering angle.
Drove it home, took it apart and found that the hardware clip on the caliper was damaged. The clip bent which was causing it to rub against the venting on the rotor. Luckily I had a spare clip on the shelf, so I swapped it out |
09-07-2020, 07:36 PM | #22320 |
Maybe you outta fix that road back to your cottage? -
The Following User Says Thank You to humfrz For This Useful Post: | soundman98 (09-07-2020) |
09-07-2020, 07:44 PM | #22321 | |
Drives: 1993 Caterham HPC Evo
09-08-2020, 11:22 PM | #22322 |
Wash
Sent from my iPhone using Tapatalk Pro |
09-10-2020, 03:59 AM | #22323 |
Drives: 86 GT
Finally took my car - and myself - to drive on track for the first time.
I had gone in without expectations, and being my first time I was fearing the worst with all the higher powered cars cutting me off several feet apart and pushing me out of the racing line, but I eventually got the hang of it. Lap times were way higher than the average 86 could attain but I was still learning to use all the brake and grip capacities I had. All in all, it was great fun - can't wait to get back out there again. |
The Following 8 Users Say Thank You to Compelica For This Useful Post: | Bobharp (09-14-2020), Cedric (09-10-2020), DarkSunrise (09-11-2020), Kaotic Lazagna (09-10-2020), MJones_RB (09-10-2020), new2subaru (09-10-2020), Quentin (09-11-2020), saltywetman (09-10-2020) |
09-10-2020, 05:40 PM | #22324 |
Weight Weenie
Drives: 15 FR-S
Toasted my first wheel bearing on track. Replacement comes tomorrow.
It sent a bunch of heat into the tire and expanded it to 43psi. Mangled it a bit. There was no noise or grinding. Even when off it was only slight. |
The Following User Says Thank You to new2subaru For This Useful Post: | MJones_RB (09-11-2020) |
09-11-2020, 01:53 PM | #22325 |
How are your Whiteline sway bars holding up? Any clunking noises?
09-11-2020, 04:43 PM | #22326 | |
Weight Weenie
Drives: 15 FR-S
No noise or clunk on the front. I had a lot of noise on the rear, It sounded like spring bind added squeaking. I tightened/adjusted everything 3 times and it still wouldn't go away. I removed it a week ago and the noise is gone. Now I know it's the bar/end links for sure. I'll try to reinstall and see what happens :/ If I didn't like the setup so much I'd say screw it... The wheel bearing is done and ready to squeeze in a few more track days! |
09-11-2020, 05:17 PM | #22327 | |
The Following User Says Thank You to MJones_RB For This Useful Post: | new2subaru (09-11-2020) |
09-11-2020, 08:59 PM | #22328 | |
Weight Weenie
Drives: 15 FR-S
The weak stock mount was my next move lol I already greased the crap out of the bushings. The holes in the sway bar are oversized and sloppy but I don't see how that could be making noise though. A guy at work suggested drilling it out and putting a collar in. I'll post if I find anything. Good luck to you too! Last edited by new2subaru; 09-12-2020 at 08:26 PM. Reason: spelling |
The Following User Says Thank You to new2subaru For This Useful Post: | MJones_RB (09-12-2020) |
09-12-2020, 04:08 PM | #22329 | |
09-12-2020, 08:26 PM | #22330 | |
Weight Weenie
Drives: 15 FR-S
I have SPL and they're tight in those too. That could be the issue. |
The Following User Says Thank You to new2subaru For This Useful Post: | MJones_RB (09-14-2020) |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
