08-02-2020, 10:34 AM | #10879 | |
2013 Series 10 FRS #553
08-05-2020, 08:41 PM | #10880 |
Drives: SWP BRZ
hi guys, how do you know when i need to change my batteries? ( I have ESC v.3)
when i engage boost, my volt meter drops but it slowly right back up to 28.3 even i am pushing my gas pedal all the way to the floor. this means i need new batteries? my starter battery is fine but i never replaced 2 dump batteries since i installed. I've been running the kit for 4 years |
08-05-2020, 08:46 PM | #10881 | |
If your going full throttle and the voltmeter is indicating that it's charging back up. Then that's gonna be something else. Can you provide a video? Sent from my GM1915 using Tapatalk |
08-05-2020, 08:54 PM | #10882 | |
Drives: SWP BRZ
I will try to take video tomorrow and post It's like this. from normal --> 28.3 ~28.6 reading engaging --> drops voltmeter around 26 range gas pedal is still on floor and --> voltmeter slowly going up to 28.3 from 26 |
08-05-2020, 09:32 PM | #10883 | |
08-05-2020, 09:37 PM | #10884 |
Drives: SWP BRZ
08-06-2020, 07:13 AM | #10885 |
Drives: FR-S,GTI
If your batteries are 4 years old then there's a real good chance they are past their prime. I usually replace mine about every 2 years whenever my boost reduces. Check the boost with the OFT. At peak it should be almost 5 psi.
08-06-2020, 06:00 PM | #10886 |
Drives: SWP BRZ
yeah that's what i am thinking. i didnt check with OFT but boost is 5psi usually as you mentioned. i will just order 2 batteries and see. i took a video but i will post it later tonight
08-06-2020, 10:37 PM | #10887 |
Drives: SWP BRZ
Here's video
i am engaging boost with gas pedal and holding it. volt meter is going up instead of going down. i am thinking it is battery but sharing the video. i will order 2 dump batteries and see if this resolve the issue |
08-07-2020, 12:22 AM | #10888 | |
08-07-2020, 12:26 AM | #10889 |
Super excited about this guy's! So me and @steve99 are still working on the tune and finally today he said I can go boost now. I hit 7.2psi right around 3500rpm and then at 7000rpm tapered down to 2psi and 1.5 at 7500. The car pulls right away it's crazy! I'll post a quick vdyno to compare with my last vdyno when I had only one phantom.
The Following 3 Users Say Thank You to BlOody_BoOger For This Useful Post: |
08-07-2020, 07:20 AM | #10890 |
Drives: FR-S,GTI
Great to hear.
It Works! |
08-07-2020, 09:50 AM | #10891 | |
08-07-2020, 10:17 AM | #10892 | |
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
