Old 03-29-2020, 07:30 PM   #141
autoxtrackdrift
Drives: Take a guess...
Originally Posted by tony_r View Post
Torsen allows you to get away with bad driving habits on entry. OSG will punish you for it.
On exit it's the opposite.
Yoks let you get away with everything, blending bad inputs is stupid easy.
Could you please explain the bad habits that the OSG will punish on corner entry? Thanks!
autoxtrackdrift is offline   Reply With Quote
Old 03-30-2020, 08:28 AM   #142
M0nk3y
OSG, being a clutch type diff has inherit static lock on decel.
Thus, if you try to come in too hot - OSG can't completely go open like a stock OEM Diff and so the car will want to push a bit more than freely rotate.
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
autoxtrackdrift (03-30-2020)
Old 03-30-2020, 10:54 AM   #143
e1_griego
e1_griego's Avatar
Drives: Many
Mine is set up as a 1 way so no lock on decel.
I have 1.5 way OSG in my s13 and I love it on track (and autocrossed the car for a long time on hoosiers) and yes, a little bit tighter on turn-in though for that car it works perfectly.
e1_griego is offline   Reply With Quote
The Following User Says Thank You to e1_griego For This Useful Post:
FastWhite (03-30-2020)
Old 03-30-2020, 03:43 PM   #144
autoxtrackdrift
Is your OSG set up like Lugod's STX tune?
Old 03-30-2020, 04:26 PM   #145
e1_griego
e1_griego's Avatar
Drives: Many
Yes it is.
Old 03-31-2020, 02:42 AM   #146
tony_r
tony_r's Avatar
Drives: '15 STX
Even with Lugod's updated unit it's still less "free" on entry vs Torsen.
But I'm not advocating one way or the other.
tony_r is offline   Reply With Quote
Old 03-31-2020, 07:59 AM   #147
M0nk3y
To touch on Tony's point...even if it's classified as a 1 way (90 degree decel ramp angles) - you still have inherit static lock.
Depending on who sets this up, can have something low like 30-40 ft-lbs or something high 80-90 ft-lbs+ on static lock. Even a 1 way can change the behavior of the car on how it's configured.
Kyle H. - #89 STX
Old 03-31-2020, 12:25 PM   #148
e1_griego
e1_griego's Avatar
Drives: Many
Alright, fair enough.
Old 03-31-2020, 12:46 PM   #149
racingfool
racingfool's Avatar
Drives: Miata
You're talking pre-load, right?
Anyone know what kind of accel ramp angles various LSDs use?
racingfool is offline   Reply With Quote
Old 04-05-2020, 09:41 PM   #150
KevBRZ
Drives: 15BRZ
Whiteline seems like a mixed bag on here but I've never had a problem and I just pulled my 3 year old set off and they're still fine.
The KLC180-195 are the version I ran which are shorter than the ones they spec for the 86.
I'm trying to sell the bar + links together or else I'd offer to sell the links separately.
I just put Whitelines on and no issues so far!! Thanks!
KevBRZ is offline   Reply With Quote
Old 04-06-2020, 08:27 PM   #151
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
My Whiteline KLC 180-195's seized up after about 3 years. My car is always garaged and I don't deal with road salt either. Just installed some new Racer X endlinks yesterday and hoping they hold up better.
smg1138 is offline   Reply With Quote
Old 04-15-2020, 01:02 PM   #152
racingfool
racingfool's Avatar
Drives: Miata
3rd gear
How often are you guys shifting into 3rd?
Is the 4.3 final drive on later cars a plus or minus?
2019 nationals videos seem to be all 2nd gear.
Old 04-15-2020, 02:22 PM   #153
Mball19
Drives: Toyota 86 TRD/SE
I drove my 2019 at Dixie in CS. I was on the limiter several times both days. I think the the 4.1 rear would have been an advantage there.
Mball19 is offline   Reply With Quote
Old 04-16-2020, 08:49 PM   #154
strat61caster
strat61caster's Avatar
Once or twice on a larger course for sure, the shorter FD cars would've been at a disadvantage very much near/on the limiter at 60+mph in a few places iirc. You can mitigate some of that with a higher redline tune as the later engines have a slightly improved valvetrain. If all your local stuff is small then the shorter gearing might benefit you.
ineedyourdiddly
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 02:21 PM
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 12:44 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 110 02-17-2020 11:27 AM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 11:30 AM
Official Roll Cage/Bar Thread **Show off your setup!** slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-02-2015 10:05 PM
