Old 06-24-2019, 11:25 AM   #141
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Originally Posted by GrabTheWheel View Post
What are your local autoX courses like? Mine seem to be a bit less technical than others I’ve seen. Speeds over 70 MPH on the straighter sections is not uncommon from the faster cars.
This weekend's autocross, first with the 3.73
Got up to about peak of about 55-57 for a quick second, this course was lacking any good straights, but was pretty smooth, I struggled to keep speed at the last corner before the finish. Had a great driver ride along with me and pointed out that I need to work on scanning ahead better, and turning in sooner. Took 1st for SM class.
I'll be a booth car for WiringSpecialities at LS-Fest East in September if anyone wants to find me/the car.
spitsnaugle is offline   Reply With Quote
The Following 6 Users Say Thank You to spitsnaugle For This Useful Post:
GrabTheWheel (06-24-2019), gtpvette (06-24-2019), Lonewolf (07-10-2019), MJones_RB (06-24-2019), Sportsguy83 (06-24-2019), Summerwolf (08-23-2019)
Old 07-23-2019, 07:06 AM   #142
spitsnaugle
Got AC installed. It worked until I floored it and it threw the belt.
I'll detail the wiring to make it work later.
The Following 4 Users Say Thank You to spitsnaugle For This Useful Post:
DustinS (07-23-2019), MCTeeJ (07-23-2019), Sportsguy83 (07-23-2019), Zer0 (07-28-2019)
Old 07-23-2019, 12:11 PM   #143
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I'll detail the wiring to make it work later. Basically take the blue/orange stripe relay wire from fuse box, run it to AC trigger on GM ecu. Done.
Thats awesome!
Old 07-25-2019, 05:59 PM   #144
Merc
Drives: Subaru brz 2013 LS1 swap
Very nice as always sir. Looking forward to a few more pics and details on the ac. Im looking to hook something up soon. I have a Pontiac GTO compressor but haven't checked clearances. What was the cost on the lines? Thanks in advance again your build page is one of the main reasons I was able to make my swap happen.
Merc is offline   Reply With Quote
Old 08-17-2019, 06:04 PM   #145
all4spl
Hey I tried to use that ram adapter for the slave cylinder and it doesn't fit into the slave itself. interesting. thoughts?
all4spl is offline   Reply With Quote
Old 08-18-2019, 09:26 PM   #146
spitsnaugle
photo?
Old 08-19-2019, 08:10 AM   #147
all4spl
photo?
Found the issue. I think you’re using a 2010+ slave. I’m using a 2002 camaro which uses a different type of adapter. :/
Old 08-19-2019, 08:12 AM   #148
spitsnaugle
My slave cylinder and quick connect are original to a 2004-2006 GTO.
Old 08-19-2019, 09:23 AM   #149
all4spl
Mine slave cylinder and quick connect are original to a 2005-2006 GTO.
do you have any pictures your slave? Is the adapter getting put in the slave itself? It wouldn't fit onto my slave after pushing out the pin and taking the oem adapter off.
Old 08-19-2019, 09:53 AM   #150
all4spl
Actually if you are using the OEM gto hard lines that connects to the slave and attaches to the exterior of the trans, that's the difference. The Camaro and every other slave doesn't have that little hardline adapter.
Old 08-21-2019, 11:56 AM   #151
spitsnaugle
Here it is, I pivoted the hardline forward from its original rear-facing direction, and inserted the adapter:
Old 08-23-2019, 01:47 PM   #152
spitsnaugle
Updated my first post with changing my AC mount parts.
I threw out the Dirty Dingo AC mount.
After spending many hours myself, and hundreds and hundreds of dollars of getting an AC specialist trying to get it to align and keep the belt on, and work right.
I found Holley made an cast aluminum mount (part #20-159) for the same sanden small AC compressor. Put that on and had ZERO problems since.
Right now the FRS in the body shop getting a new front bumper and side skirts, and most of the body resprayed because I'm a bit picky. I just ordered a VERUS front splitter and rear diffuser. Prepping for running NCM road course here September 7-8 during LS fest.
Some exciting bits-
Talking with Pete and Dave sounds like Speed.Academy might do a special on the car at Toronto Motorsports Park, Apex Race Parts is using it for promotional work, and a photo/video crew is doing an interview with me about it later next month. Its getting pretty popular.
The Following 2 Users Say Thank You to spitsnaugle For This Useful Post:
GrabTheWheel (08-23-2019), wparsons (08-23-2019)
Old 08-23-2019, 02:06 PM   #153
all4spl
why not use oem gm ac compressor? Just curious.
Old 08-23-2019, 02:52 PM   #154
spitsnaugle
The GTO compressor I had sat too far forward for my liking, it's clutch sat infront of the pulley vs the Mini Sanden is flush, it wouldnt clear the lower rad support.
cx racing, ls swap, ls2, pure automotive
2017 BRZ VORSHLAG/PURE AUTOMOTIVE LS SWAP ILLSMOQ Engine Swaps 172 11-24-2022 07:01 PM
LS2 swap by KAB Customs with Pure Automotive Motec Sportsguy83 Engine Swaps 254 10-17-2018 12:45 PM
Pure Automotive's MoTeC Plug and Play V8 Swap Thread Pure Automotive Engine Swaps 51 11-25-2017 11:10 AM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 23 05-15-2016 04:21 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 01:03 AM
